Question about Crafts & Hobbies
How old is nikki manaj - Crafts & Hobbies
I have a Nikki Carb two barrel with the numbers 213282-452 & 8943007765 any idea what it was off
I have no idea; just wanted to mention the most popular application of the various Nikki twin chokes were as a bolt-on goodie to boost the performance of some cars (with a suitable adaptor) or as a cheaper than OE replacement for older cars with worn out carbs.
They gave a good account of themselves and were used extensively by repairers and specialists and kits were available to the general public from mail order catalogues.
The Nikki was also an original fitment on many older Japanese cars.
Oct 04, 2017 | Cars & Trucks
Need assembly diagram for nikki Carb 79778
You will find a lot of pictures and diagrams
nikki Carb 79778 Google Search
Mar 31, 2016 | Garden
Briggs and straton 205412-0187e1 runs on full choke only rebuilt carburetor due to surging now it only runs on full choke
This engine came with 2 different carbs. Walbro and Nikki. The Nikki carb has a very fussy float plate! I fight them often! Usually there is a problem with the odd gasket that lifts the flat plastic plate and causes a very low fuel float level in the carb so the only way it stay running is to have the choke on. The main fuel jet on both carbs is up inside the threaded area of the bowl nut. When the main fuel jet clogs...and it only takes a speck of something you also get the symptom of having to use the choke to keep it running.
http://www.partstree.com/parts/dispdiagimg.php?src=r&ilFN=D%3A%5CEMPARTweb_52%5CCatalog+Data%5CEMP_IMG%5CBRG%5Cimages%5C6359%5C0004.TIF&ilSC=10&ilIV=0&ilBR=0&ilIF=G&ilRE=8&ilSH=0&ilEG=0&ilRO=0&ilSC=24
Main fuel jet is item 117 Nikki or Screwed into item 142 Walbro of the of the above link depending on which carb you have.
The plate I am talking about on the Nikki carb is item 135. The fussy gasket is 137A.
THE threaded area is where all the main fuel supply is drawn from the float bowl. All that must be free of obstructions. Until this is clear and orifices / jets are not obstructed; your going to be running on choke....
Thanks for choosing FixYa,
Kelly
Aug 20, 2011 | Briggs & Stratton Power Products 5,550...
I need to remove email contacts under the scanner option on a lanier ld445c
Hi lance lebian
I have the manual for this printer if you would like to download follow the link cheers nikki
http://www.lanier.com/downloads/manuals/Color_MFP/lc435opguide.pdf
Cheers nikki
Jan 20, 2011 | Office Equipment & Supplies
Virus Check
when my F761usa screen turned black just happened I was reading my emails, since then I never can turn on my F761usa, not even get bios reboot. I thought I got deadly virus attacking to kill my notebook. during investigation we found our neighbour invaded our wireless router (we can see Nikky ipod as device name appeared in router, we blocked it then another Nikky phone as device name appeared again), meanwhile we found log files recording naughtyamerica website, we realized our neighbour visited some dangerous websits that's why I kept getting very dirty-emails over past 3 years.
By adjust netgear and notebook parameters setting finally our neighbour can't steal our internet services any more.
Then we spent $10 to convert internal HD as external usb HD and could be accessed by our another HP DV7. I doubt it was virus caused it.
we has att DSL internet services which provides McAfee, we has very old Netgear WGT624 wireless router but can block/data secured and window vista provides network secured setup.
we didn't buy any other virus software but run the free version(advanced systemcare).
Sep 08, 2010 | HP Compaq Presario F730US Notebook
Nikki carbureter have installed new kit but still floods up and runs rough any suggestions
remove the float bowl cover and set the wet float level. There should have been instructions with the rebuild kit on how to do this. If you don't have experience with carburetors, ask an old mechanic to help.
Aug 22, 2010 | Toyota Pickup Cars & Trucks
Won't start...haven't used it in a while...when i plug it in, the battery indicator flashes yellow...
Hi:
There is probably many solutions but, how old is your laptop/battery? Have you been using it often? Well if those questions are right and your PC is older than that probably means you need to get a new battery and switch them up.
- Any more questions feel free to email me at... xoiceybabe21@aol.com
~Nikki~
Nov 04, 2009 | Computers & Internet
Numark tt1625 speed issue
hi nikki,
when you say ages to get back to speed how long is that exactly? even on my technics for cueing i give a slight throw to hit my cue points.
also your slip mat may be an issue. do not use the rubber mats use the soft nylon foam one that came with it only.
Feb 27, 2009 | Numark BATTLE PAK v.4 Turntable
NEC Laptop
use the battery pack, as in how to install or remove it? do you have a manual for that item?
May 04, 2008 | Computers & Internet
Crafts & Hobbies Logo
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Debbie
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
