Question about Dishwashers
Rust in dishwasher - Dishwashers
The metal thing at the bottom of my dishwasher is
I would replace it... they are not that exspensive and not that hard to replace...
How to Replace the Dishwasher Heating Element
http://www.fixya.com/support/r4589084-replace_dishwasher_heating_element
heatman101
May 28, 2010 | Dishwashers
Rust spots on bottom rack
You may need to replace the rack. Dishwasher soap is aggressive and once an area is exposed, it will rust fast. Make sure you don't place sharp objects in direct contact with a rack. The action inside the washer can cause them to move and rub through the metal rack coating.
Dec 06, 2009 | Maytag MDB6650A Built-in Dishwasher
Rust spots on Bosch STAINLESS dishwasher
Debruce Polish is the answer. It is non-toxic and odorless, DeBruce will remove the rust and pacify the finish. DeBruce is perfect for touch ups and great on ceramic cook tops and more. We buy DeBruce polish at debrucepolish.com.
Jul 28, 2009 | Bosch 24 in. SHY56A05 Stainless Steel...
Rust Stain
Try running a cup of white vinegar through your empty dishwasher. If that doesn't work, get the JetDry dishwasher cleaner and run that through.
May 14, 2009 | Dishwashers
How to repair rust on lower basket of dishwasher
Use sandpaper or brillo pad to remove rust, and paint it with acrylic appliance paint
Apr 15, 2009 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwashing machine
there is a new product called the dishwasher filtration system. it filters your water going into the dishwasher. it reduces calcium and magnesium and rust and sediments from your water. this product shoudl definately help you. you will be happy you got it. go to www.dishwasherfitler.com.
May 23, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Stainless steel is rusty/blotchy
Jenn Air makes great products, don't blame them. Your type of stainless steel is a consumer grade that has less nickel-chromium in the mix making it affordable to the consumer. The surface needs to be "pacified", DeBruce Polish will REMOVE THE RUST and PACIFY the surface. We get Debruce Polish at debrucepolish.com.
Jan 02, 2008 | Jenn-Air 24 in. JDB1100AWS Built-in...
Rusty dish rack
Clearly a design or manufacturing flaw. I have the same model and the rack is disintegrating after 6 years. I believe it is a manufacturing flaw. Our previous dishwasher rack lasted over 20 years in the same conditions. Same construction, vinyl covered steel. New upper and lower racks cost over 200.00 and there is no guarantee that this won't happen every six years. I recommend a new non-Maytag dishwasher as soon as you can. Meanwhile, limp along with the defective racks.
Oct 02, 2007 | Maytag MDB7100AWB Dishwasher
Dishwashers Logo
14 people viewed this question
Top Dishwashers Experts
