Question about EZ Dupe Computers & Internet
No master disc
I am trying to copy from a SD card to a disc. I have the SD card in the machine & I have a blank DVD RW. When I select COPY I keep getting the warning "NO MASTER DISC" and the CD drawer pops out like I am coping from the CD. I selected the Source as 01. What am I doing wrong? I am using V3.10
3 Suggested Answers
Crankstart
  • 696 Answers
SOURCE: mage lynx 7 light scribe duplcator. Where do I get a manual?
First,
If your Copying a disk, yes the disks must be the same kind. -R +R RW not always and issue but it must be CD-CD DVD-DVD and if a DVD master is DL it must be copied onto dual layer blanks.
As for manuals, try looking through the install CD, the company doesn't seem to have a website(except for email hosting). If they are not on the CD try contacting them directly
866-823-9788 or duplicator@megalinx.com as this is the only publicly listed contact info they have.
Hope this helps,
chris
Posted on May 26, 2009
  • 53 Answers
SOURCE: When trying to copy a CD, I get the following error message: Warning - Bad Master Disc!
I assume it means just what it says. The Disc you are trying to copy is faulty?
Clarify what you are trying to copy. If it is copy protected, A duplicator wont copy it. Or the disc was made in a format incompatible with the master drive you are using. Ive had drives read some discs and another drive that cant read the same disc. Some brands of discs work better on certain drives. Try to use top quality reccomended discs such as Verbatim.
Char S.
Posted on May 27, 2009
DVD Fab isn't copying DVDs anymore.
Try. reinstalling your media program.
Nov 20, 2016 | Televison & Video
Target disc not empty
Target disc ( this is what you've selected to burn TO) is not empty(is not a blank disc). You should try a different blank disk, or else you have your source and destination backwards.
Nov 16, 2012 | Acard Technology (ARS-2030LD) DVD±RW...
I have a stand alone dvd/cd duplicator at our church having trouble with. Cant copy onto dvd-r's. Master can be dvd-r or dvd-rw and will copy onto dvd-rw. when i try to copy onto dvd-r's, it will run for...
The two common problems, copier doesn't like color of discs etc, and slowing the speed that leave you've already tried. After those the most likely thing is that one of them has heads that are out of alignment. You could try copying cd's as they have coarser and the heads don't have to be as accurate. If that works then it is very likely it's the heads out of alignment. If they won't record on the cds at all it still can be the heads out of alignment too, but this test may help determine which drive is out of alignment.
Mar 06, 2011 | Computers & Internet
Using Windows XP. Want to copy vidoe from Media
Is the drive you are using a DVD writer or only a DVD reader? The drive that writes to RW disks is labeled DVD/RW or DVD Recordable.
These are the only drive types that will read and write a DVD/RW disc.
Jan 04, 2010 | Acer Aspire E500 PC Desktop
Mage lynx 7 light scribe duplcator. Where do I get a manual?
First,
Hope this helps,
chris
May 21, 2009 | Computers & Internet
Targer drive not ready.
"Target overflow" just means that the disc being used to make the copy doesn't match in size. "4.7GB" to the master disc. Sometimes this occurs when you make a mistake thinking the disc in the copy slot is a DVD blank but it may be a CD-R blank(by accident) or sometimes the Master disc is a BD-R and trying to copy to a regular DVD-R (won't fit)
"Source drive not ready" is when the Master disc keeps spinning in the attempt to read. The "culprit" alot of times is the brand, or scratched, dirty, corrupted discs.
Make a copy of the master again (if possible and on your PC with a different brand of disc) then use the new Master to make the multi-discs you want.
"Target drive not ready"
is when a disc with information already on it, is in the copier (can't copy over it) sometimes we make mistakes and put the Master in the copier and vice versa : )
or no disc in it at all, and or some sort of incompatible blank media.
I have a 7 disc duplicator by Pioneer and I found that in the last few years since I've had it (since 2005)
I ran into the above situations alot.
I use it as a standalone (not hooked up to any PC etc)
It still works great but I find that was having a brand name issue with the discs; certain discs that it used to read in the Master/Source drive like Taiyo Yuden, Memorex, Ridata, SKMAX, and Phillips, suddenly don't want to read properly when inserted. The discs keeps spinning and then when you press "copy" it says "Target overflow" or "Source drive not ready" I found that solution I mentioned above with the changing of the disc brand helps fix the situation. I didn't want to hurt my brain trying to figure out what it could be as I use my duplicator for business and time is money.
Through trial and error I end up just making duplicates from my PC on different brands (cheaper unknown brands work fine) and then using the "new master" made from these is the only way I can duplicate..weird!
P.S sometimes the lens may need an old fashioned cleaning with a lens cleaner or Dust blower.
Once in a while one or two of the doors get stuck even when all 7 discs are completed...just take a q-tip with vaseline and put it on the track wheel for some lubrication and the door will open up easier.
Just some tips from someone who's had their player a long time
Hope this helps anyone in need out : )
Jun 20, 2008 | Acard Technology (ARS-2030LD) DVD±RW...
Video8 to DVD
First erase the DVD and then try...
you can erase DVD by right clicking the drive in my computer and selecting "ERASE DVDRW"
then you try to write onto the DVD-RW
Apr 11, 2008 | Computers & Internet
Writing to a DVD+RW disc
You need to use DVD software such as Nero that supports DVD-RW. from the app is where you would erase and so on
also make sure your blanks are +RW and not -RW
Jan 10, 2008 | Toshiba Satellite A75-S206 Notebook
Trying to copy a dvd
HEY PUT A DISC TO COPY THEN SELECT COPY DVD OPTION  AND SELECT NEXT  DESELECT THE QUICK COPY NOTCH
AND THEN CLICK NEXT MAKE SURE YOU HAVE ENOUHGH DISK SPACE WHWEN THIS PROCESS COMPLETES  IT WILL ASK FOR THGE BLANK DVD INSERT THE DISK AND WAIT
DON T CLICK ANY THING WHEN THE CD EJECTS
IT FINISH BY ITSELF
Dec 31, 2007 | Lite On LH-20A1P (0844149002088) Burner
Samsung DVD Rom drive SD 612B
Its a dvd-rom drive. READ ONLY MEMORY.
That drive will not burn a dvd...it has to say dvd-r/dvd-rw.
or be referred to as a super drive.
Hope this helps.
Aug 21, 2006 | Samsung (SD-612) Internal DVD Drive
Computers & Internet Logo
Top EZ Dupe Computers & Internet Experts
Gene
alwaysreddy
Are you an EZ Dupe Computer and Internet Expert? Answer questions, earn points and help others
