What does the fs-c5300dn error code f020 mean?
2 Suggested Answers
  • 3278 Answers
SOURCE: I,m getting error code F020, how do I fix this?
Hello.
Often, that error code means:
1. Defective main memory (RAM) on the main board.
2. Defective main board.
3. Defective expanding memory (DIMM) on the main board.
But, try a power reset. Leave the printer powered on. Disconnect the power cord connected to the printer. Then, plug it back in again.
Hope this resolves your problem.
Posted on Jan 15, 2011
What can i do with error 2250:0110409?
There is a problem with the lsu/charger cleaning motor. Maybe one of the four main charger or LSU has stuck. Check the main chargers and the LSUs if their gears rotate properly or they are stuck somewhere. Otherwise, the motor that drives the cleaners is defective. You can isolate the automatic LSU/Charger cleaning by remove the connector from the engine pwb. First you have to check if the lsu/charger cleaners are at home position or not.
Jun 10, 2014 | Kyocera FS-C5300DN Laser Printer
Error Code F46F
Upgrade the system firmware
May 19, 2014 | Kyocera FS-C5300DN Laser Printer
Call service 2830:0142588 how can i repair it myself?
have you solved it ? we had a paper jam and the error is still active, tryed everything, nothin works :(
Aug 31, 2011 | Kyocera FS-C5300DN Laser Printer
My images are printing closer to one margin than the other when it's set to center on the page
check paper glider of ur printer
other wise trying unstalling and installing printer driver
Aug 03, 2011 | Kyocera FS-C5300DN Laser Printer
Error call service 4000:00433933
The codes on this model are the same as on the Kyocera Mita copiers.
ie: 4-digit codes
Call service 0150 engine pcb EEPROM error
Call service 0420 option paper feeder communication error
Call service 1010 lift motor lock error
Call service 1140 lift motor going up error
Call service 1150 lift motor going down error
Call service 2000 main motor error
Call service 2200 drum motor error
Call service 4000 laser scanner unit (polygon motor) error
Call service 4200 laser scanner unit (pin photo sensor) error
Call service 5100 short-circuited main charger output
Call service 6000 broken fuser heater lamp M wire
Call service 6020 abnormally high fuser thermistor M temperature
Call service 6030 broken fuser thermistor M wire
Call service 6400 zero-crossing signal problem
Call service 7000 toner motor lock error
Call service 7410 drum unit non-installing error
Call service F000 communication error between the main controller board and operation panel board
Call service F010 main board (system DIMM board) checksum error
Call service F020 main or expanded memory error
Call service F030 general failure
Call service F040 communication problem between main board and engine board
Call service F226 main pcb video data control error
May 18, 2011 | Kyocera FS-3900DN Laser Printer
Hai, i want to ask for my F020, why my F020 always ask for simcard..?? if i take the battery,it's solve for a second (it wont error again), but sometimes it will error again.. what should i...
hi..
press 3,#,*,continously and press switch off /on button then switch ON it automatically format your phone and then the problem will be rectified..
then again it happened means check the hardware of your phone whether your phone sim insert lock is seated correctly or no chect it that....
good luck
If it's useful for you means plz rate me the 4 Thumbs ....
Jan 06, 2011 | Cell Phones
Error message 20
F020 Main or expanded memory error
1. refix the main board and try.....
2. replace the expanded memory of the printer ........and try.......
3. replace the main board.........
Oct 21, 2009 | Kyocera FS-2000D Laser Printer
Paper fed through the Multi-purpose tray exits from the rear of the machine rather than from the top.
There will be a setting in the printer. Most people have it set to exit straight through as they run card stock from multipurpose tray. Should also be setting in print dialogue box
Apr 24, 2009 | Kyocera Mita FS-C5016N Printer
Kyocera 3900DN Error Code
F030 General failure
Miscellaneous failure with the main
PWB, other than F000, F010, F020,
F040 and F226, above.
Defective main-PWB
Turn the power switch off/on to restart the
printer.If the error is not resolved, replace
main PWB
Sep 04, 2008 | Kyocera FS-3900DN Laser Printer
k24674
jasbo
jasbo
