Question about Samsung 52 in. LCD Flat-Panel HDTV
How do i find the power button on tv cant seem to locate it.looked everywhere
There is no power button on the sides or top or bottom of tv looked everywhere cant find one
2 Suggested Answers
jhinsincity
  • 616 Answers
SOURCE: Samsung 650 LCD picture is cut off top and bottom
select the correct tv format, check your manual
Posted on Jan 01, 2010
Tv needs to be on to tune new remote but tv doesn't seem to have a power button. How can it be switched on without a remote? Thanks.
Read any manuals you may have gotten with your TV, and make sure there is no power button of any kind. (some have touch buttons difficult to locate. Check the top, sides, bottom and back for any power buttons.
If there is none and you can't turn it on try using a remote of the same brand, some have frequencies that can turn on TVs in cases like these.
Hope it helps.
Oct 12, 2016 | Televison & Video
I have a Westinghouse LCD tv and i lost the remote but in trying to run auto scan and it keeps telling me to press enter but I don't know how to
WESTINGHOUSE LCD-TV USER MANUAL Pdf Download.
www.manualslib.com > ... > Flat Panel TV > LCD-T
Westinghouse Digital 27'' Wide-Format LCD - TV User's Manual. ... the analog cable or TV antenna wire (not included) directly to this LCD-TV antenna input. ... a list of video sources using the SOURCE button located on top of the LCD-TV.
images for Westinghouse LCD tv enter button location
Sep 28, 2015 | Westinghouse Televison & Video
Why i cant find power button
There are always buttons on the bezel.they wont be on the back. Not likely on the bottom unless an area sticks out.they will be flush and same color as bezel so hard to see but easy to feel. Run your fingers along the sides and top,bottom if it sticks out anywhere. What model tv do you have?
May 13, 2014 | Sanyo 42 in. LCD TV
Turn power button on green led light on power button comes on for about 5-10 seconds then goes off tv does not come on
CK the Deflection board, Will be Located on Bottom far left hand side,has FBT flyback Transfomer. Look for Bad Capacitors
CP150 2200uf 16v use 25v CP114 CP120 If any of these are Swollen,vented or puffed up on Top they are Bad . Radio Shack should have these Caps.
Oct 11, 2010 | RCA HD52W59 HDTV Projection Television
Can I turn on the samsung flatscreen without a remote? The remote got water in it and will not work. Does the tv have a power button located on the tv?
Yes, channel buttons, sound buttons and power button is located at the side of the screen. Look for it. For most TV's its located behind and for some at the side and for some in the front bottom.
Nov 24, 2009 | Samsung 52 in. LCD Flat-Panel HDTV
I have a 50 inch lg plasma tv and the picture is to big.
Ok take your Vizio remote control go to the Lower section of the buttons and look for the - Zoom + button than decrease the zoom.
Jun 19, 2009 | Vizio GV42L 42 in. LCD Television
Cant find location of Block hearter cord on 99 Chrysler
usually it is routed out near the headlight.... there is a good chance tho that vehicle doesn't have a block heater. look at the sides of the motor for round metal shaped plugs in the block (frost plugs) do you see any with an electrical fitting ?
Robert
Please take a moment to rate this solution thanks
Jan 30, 2009 | 1999 Jeep Grand Cherokee
Replacing lamp for a sony lcd Kdf50WE655
it is located in the front of the set behind either a long metal strip cover or a plastic cover. some sets have wing nuts hoding the cover in place. they would be located on the left and right hand side of the set near the bottom edges.
Jan 08, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Cant find the nameplate
usual places are
in fridge on side or behind salad crispers
in freezer at bottom maybe hidden by a basket
Jun 22, 2008 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
No power
*note it is never safe to open a tv to self service when it is plugged in. it can cause serious bodily harm,injury or death. and is best to leave to proffesionals.
do you see any blown capacitors on the pcb boards. that are puffy or bulged on the top? any fried black singes on the bottom? i assume your tester is a voltometer? if so then you can try to bypass the power button by jumping it from 2 connectors on the board with your voltometer and it should boot up or at least make a noise. if nothing happens then the power is stopping before it even hits the power switch. inwhich case the tv needs the pcb board replaced but it will probably be cheaper and easier to replace the unit as a whole.
Jun 13, 2008 | Toshiba M24F51 24 in. TV/VCR/DVD Combo
Samsung 52 in. LCD Flat-Panel HDTV Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
