SOURCE: Infocus LP120 counts down then restarts counting down
this can usually indicate one of several things, a lamp service life issue, an overheating problem, or that the lamp service cover has not been properly secured
SOURCE: panasonic dimension4 genius microwave oven
High voltage parts are suspect. Need to put a voltmeter on the
input (primary) side to the high-voltage transformer (big heavy iron
thing in there) Should be getting 120Vac when it goes to cook
cycle. Don't touch the other (high voltage) side of this
transformer. If the power is there, you are looking at replacing
high-voltage capacitor and diode. If that doesn't solve it, then
it needs a new magnatron. Its affordable if you do it yourself - buy
the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
SOURCE: Our Bosch Dishwasher no longer
Unfortunately that indicates a control module problem. Only fix is to replace that
HERE you can find the parts and drawing
SOURCE: Konica Minolta Pagepro 1350 page count or Print Config sheet?
please go printer utilty option on your pc then you can print a testpage
SOURCE: I'm using d-link dwl-3200 ap
Transmitted Error Count 4734440 Ack Rcv failure Count 15269951
