Where is the oil drain plug on a Z425 zero turn mower 23 hp Briggs Stratton?
  • 41 Answers
SOURCE: Briggs & Stratton 4.5 hp running rough...too much fuel
Hi did you squeze excess oil from filter so it can **** air in??
Posted on Aug 04, 2009
  • 152 Answers
SOURCE: oil appearing at exhaust, smokey, briggs and stratton lawm mower.
You will need to replace or clean the air filter, and probably the spark plug. Do not operate the mower for some hours to allow the oil drain (inside the engine). Check oil level and fill it if necessary. Some oil remaining in the exhaust should be burnt next time the lawnmower operates.You will see smoke at the beginning, that will be normal (burnt oil). Hope this helps!
Posted on May 25, 2010
SOURCE: Need to know where oil
I have the same model...... it should be just underneath the unit.... it will look like a square head recessed. I used the ratchet set extension and it fit just right. I literally had to tilt the darn thing upside down to find it. Then once it was loosen a bit, I put the machine upright on the wheels again, and slip a plastic pan underneath as I finished unscrewing the oil plug, Out came the black goo.
Posted on Sep 26, 2010
  • 407 Answers
SOURCE: unable to locate oil drain
Open the spot where you put the oil in.Now turn the mower so that is comes out the hole it went in.It can be messy so use a large bucket.
Posted on May 30, 2011
hunter19_46m
  • 7482 Answers
SOURCE: weed eater 22" mower with
Hi stnstomper...
Look under the mower for a square plug or allen wrench type plug, this will be your oil drain for the motor.
Some of Briggs & Stratton motors do not have an oil drain plug...
If you do not have an oil drain plug then you will have to run the mower to get it warm, then remove the oil fill plug and tip the mower towards the oil fill plug to drain out the oil thru the fill plug hole.
Free Answer...Please take time to rate me
Posted on Jun 13, 2011
Husqvarna Z246
Husqvarna Z246 Briggs and Stratton Zero Turn Mower ...
? 1:28
https://www.youtube.com/watch?v=Ohx8nxNrgNs
Feb 23, 2015 - Uploaded by SleEquipment
Husqvarna Z246 Zero Turn Lawn Mower 46" - 23 hp Briggs and Stratton Engine: Briggs and Stratton ...
Nov 30, 2015 | Husqvarna Garden
HOW DO YOU CHANGE OIL ON A briggs and stratton diamond i/c 15.5hp vertical shaft ride on mower
find the drain plug on side of engine usually near oil filter take out drain plug drain oil out replace plug remove filter install new one fill oil in filler tube check with dipstick until level reaches safe on the dipstick done
Aug 25, 2014 | Briggs & Stratton Garden
Iput to much oil in a briggs and stratton engine on a wood chipper the engine has seized up what can i do
Drain out the oil, take out the spark plug and see if you can get it to turn. Turn by hand or wrench not an electric starter
Aug 28, 2013 | Briggs & Stratton Briggs Stratton...
How do I drain the oil on a Briggs and Stratton 8hp 191702 ride on mower ? I can't seem to locate the oil drain plug.
if you follow the dip stick tube down to the base of the engine there is a square head bolt that is the drain plug
Jun 27, 2012 | Garden
Weed eater 22" mower with
Hi stnstomper...
Jun 13, 2011 | Mtd 22" Yard Machine Push Mower
Oil appearing at exhaust, smokey, briggs and stratton lawm mower.
May 25, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a troy bilt mower with a briggs & stratton engine. How do I change the oil?
There should be a drain plug on the underside of the mower deck. Raise that side of deck, remove the plug and drain the oil. Replace the plug and add new oil. Hope this helped.
Jul 18, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Where is the oil filter located on the Husqvarna Lawn Tractor, Model YTH2348
if its a 23 hp briggs and stratton it should be on the opposite side from the dipstick where you check the oil down low.
It may be black with a briggs and stratton label or it may be yellow with the same.
Jun 05, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
