Question about Konica Minolta Office Equipment & Supplies
I have an old K.M. Dialta Di 450 How do I add access codes?
  • Konica Minolta Master
  • 6,680 Answers
What code ? what do you wan to do??
Posted on Dec 29, 2015
jqsababa967
  • 145 Answers
SOURCE: code erreur
CAUSE: Adjustment mode 11 is not set to correct value.
SOLUTION: To set Adjustment mode 11 to proper value, perform the following:
1. Enter Tech Rep mode (Counter, Stop, 0, 0, Stop, 0, 1).
2. Press Stop and then Start. AJ- will display.
3. Enter 11 from the keypad.
4. Press Start. Current value will display.
5. Press Clear.
6. Enter a value of 1 from the keypad.
7. Press Start to save the setting.
8. Press Auto Reset to exit Adjustment Mode.
HOPE THAT HELP
Posted on Dec 06, 2008
Daniel S
  • 4323 Answers
SOURCE: Problem on Minolta DIALTA DI
Hi
Error code C070 or C0070 is related to toner not seated properly. Power off the machine and gentlly take out the toner bottle. Turn on the machine without the toner bottle, let the machine go through its normal routine when the indicator comes on for toner install toner bottle. If the code comes back you have a problem with the Toner Bottle motor, gear, or Main Board.
C0500 means Heating Roller warm-up failure. Open and close the right side door. There's a switch hidden under the frontcover activated by the side door. Sometimes the grey plastic arm attached to the sidedoor is not actuating that switch properly.
To reset the error Localize hole on right side of control panel. In hole is switch. Press it. Machine will restart. Enter "3" from the 10-Key Pad when dot appears at the center on the left side of the screen while the start-up screen is being displayed. (Enter code 0000) You'll enter Initialize Mode. Press Trouble Reset. If error apears again, remove Fixing Unit and check lamp, thermo fuse or thermistor. Hope this helps... Please post back if you need more information.
Daniel
Posted on Jan 01, 2011
wheatlandsvc
  • 1110 Answers
SOURCE: code 1300 minolta dialta
On a Di250 this C1300 code means that your laser scanner motor has frozen up. This unit is a small circuit board with a motor that spins a 6 sided mirror. The laser bounces off of the mirror and writes the image onto the imaging unit. You are going to have to have a service person come out and replace the motor. The cost will depend on your location but I would estimate it to be around $400.00 for parts and labor.
Good Luck and Thank You for using Fixya.
Posted on Jan 04, 2011
wheatlandsvc
  • 1110 Answers
SOURCE: an error code occur ed
C0500 is a fuser warm up failure code. The procedure to reset is simple. First look at the right side edge of your control panel. This is where the meter count is and the "slide" that controls how dark/bright your display screen is. Now just to the left or front side of where the slide is you will see a small hole in the panel. You need a small paper clip or a tooth pick to insert into the hole. Next with the machine turned on and showing the code, insert something into the hole until the screen goes blank and begins to restart. You should see something that resembles the copier sitting on top of the globe. Keep watching the screen and at the far left side of the screen there will appear a small dot. As soon as the dot appears press the 3 key. You should now see a screen with several boxes. At the lower left is "Trouble Reset" - Press this box to reset the code. Do this reset procedure ONLY 1 time for every 10 minutes. If the code comes back you can try again in 10 miutes. If the fuser is heating and the machine just can not "see" it then you can do further damage to the machine if you try to reset several times very quickly. If the machine warms up and makes copies you are all set. If the code comes back you have a failure in the fusing unit and will need it repaired.
This procedure works on the Di250 Di250F Di251 Di251F Di350 Di350F Di351 Di351F.
Please provide positive feedback if I was helpful.
Posted on Jan 06, 2011
SOURCE: c1300 error code
minolta dialta di250 makes a light copy not a dark copy i also fill the toner power but it make print light what we do? kindly solve this porblem.
Posted on Mar 11, 2011
I have a photo copier machine minolta dialta di 470 that show error code c-0400
open the front door upper left is small access cover remove and depress the trouble reset. if the code comes back replace the scanner lamp and board.
May 03, 2014 | Konica Minolta Office Equipment & Supplies
Error code c0400 on minolta Dialta Di470
As I said before, Open the front door upper left is small access cover remove and depress the trouble reset. if the code comes back replace the scanner lamp and board.
How to remove the Code 13 & 14 of DI 450 Minolta copier
open and close the front door. If not replace the Laser or PWB-B Board
Mar 03, 2014 | Minolta DiALTA Di183 Copier
Dialta di-450 code c-0042
fusing fan motor is dirty or burned out. worse case the control board is bad.
Jan 22, 2014 | Konica Minolta Office Equipment & Supplies
Error code c0-f24
Konica Minolta MINOLTA BRAND DIALTA... - Fixya
www.fixya.com/.../p4705803-konica_minolta_minolta_brand_dialta_89...
Konica Minolta MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603AFOR USE IN MINOLTA DI-520 / MPN:8935902 SKU:1745166 - Recent Questions, Troubleshooting & Support. Recent; Popular · Answered ... Error code c0-f24.
Code c0510 in dialta 520 how to reset - Fixya
www.fixya.com/support/t16313340-code_c0510_in_dialta_520_reset
Feb 2, 2013 - Code c0510 in dialta 520 how to reset - Konica Minolta MINOLTA ...Home · Forum · Fax Machines · Konica Minolta · MINOLTA BRAND DIALTA 8935-902 BLACK TONER TYPE 603A FOR USE. ... BLACK TONER TYPE 603A FOR USE INMINOLTA DI-520 ... My minolta dialta copier has a c-of24 error code,.
C-0600 there is a code shown in my di520C-0600 tell me ...
www.fixya.com/support/t16673596-c_0600
Feb 14, 2013 | Konica Minolta MINOLTA BRAND DIALTA...
Cannot close the M1 part of Minolta Di 450
M1 is a counter for maintenance need to get service mode access to clear the counter and clear the message.
Dec 30, 2010 | Minolta DiALTA Di183 Copier
Minolta dialta Di 470 donne code c 0210 puis
C210,transfer/separation corona malfunction.Change or clean the corona wire and the corona holders(white Assembly).
Jan 10, 2010 | Minolta Office Equipment & Supplies
MInolta Di 183
Abnormally high toner density detected Black ATDC (auto toner density control circuit)
Replace black IU, check toner motors, make sure toner is loose not clumpy. Change dev reset toner level.
Thanks.
Mar 25, 2009 | Minolta DiALTA Di183 Copier
DI 450 KONICA MINOLTA ERROR CODE C0070 AND C0F24
if it;s not the bottle home position it may be you toner happer motor...clean it and try to take the bottle our and close the door and than put bottle back in
hope that help
Feb 25, 2009 | Konica Minolta DiALTA Di200 Copier
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
