Question about Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
Program control board may mfi2568aes - Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator
2 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: I Have Maytag mfi2568aes I replaced both the HV
On most the motherboard will reset itself once unplugged. I believe you need to test the low voltage power supply transformer. This by far will not be a one answer solution so if you could follow through the service manual and technical notes with me I will be glad to assist you. Any time a board is disconnected on your model the motherboard should reset back to factory settings once disconnected from a power supply. Hope you have not discarded the old boards and you can put them back in and see if something is different. Let me know later what you decide to do. For now I will leave these=> Service Manual and=> Technical Information I will return later to see if you respond. Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Posted on May 14, 2010
Testimonial: "Thank you. Your Tech information was the KEY to the fix."
Maytag MFI2568AES- ice maker making ice but cannot harvest
Sounds like the thermostat inside the ice maker that allows the heater to come on during harvest cycle is bad. You will need to replace the ice maker.
Ice Maker Kit For Maytag Refrigerator Model Number MFI2568AES
Sep 24, 2015 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag Refrigerator Model Model #MFI2568AES
This a common problem with these units the high voltage in the main control board is the problem, the main control board in the back will need to be replaced. This runs about 250 dollars for the part. You can order it from this link.
http://www.repairclinic.com/Maytag-Refrigerator-Model-MFI2568AES-ID-657261-Parts?n=2
Nov 09, 2013 | Refrigerators
Maytag MFI2568aes:none of the keypad controls work. Is it the control board that is no good?
Check the harness up at the top of the door. Remove the cover and be sure everything is plugged in correctly. Sometimes the harness will work loose do to door movement.
Aug 18, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Our frig ice cube door chute keeps slaming and the lights are going crazy on the push button board. model MFI2568AES SER 10967637JR
Your control board is bad. Unplug refrigerator and replace it, follow instructions on board to reprogram and you should be good. It's on the back outside of refrigerator under panel. Or, call a repairman to do it for 400.00 plus. Hope this helps,
Oct 24, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag Bottom Freezer Fridge 25 cubic ft. Model-MF 12568AES Code- 0302 Serial #- 10040844JN Problem- Control panel not responding and no water and ice through dispenser.
the control panel is a p c board . maytag call's it a jazz board . and will need to be replaced . not a uncommon problem. also the water will work after tempts a stablized . with the new board . one board fits all but has to be programed for your model . this is a job for your appliance tec . the board comes with very good instructions . . if handy with electronics its not hard .. **** hope this helped ..
Apr 04, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
I replaced my HV Control Board on my maytag
First did you program the board correctly and second make sure all the connections to the board you replaced are in correctly.
Aug 31, 2009 | Maytag MFI2568AE Side by Side French Door...
Malfunctioning Maytag and memory board flashing
You need a main control board and it will have to be programed but the new board comes with instructions
Mar 27, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag MFI2568AES Stainless Steel Bottom Freezer French Door Refrigerator Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
