Question about GPS
Garmin fishfinder 160c the screen does not light up and is very hard to see
4 Suggested Answers
Editor925
  • 285 Answers
SOURCE: To wireup 160c Garmin fishfinder, there are seven
You only need the red and black wires to supply power to the unit. The red positive wire goes to a positive terminal on your battery or positive side of a bus bar or switch, the black negative wire goes to the negative terminal on the battery or negative common bus bar. Do not try to earth the black wire to an aluminum boat hull... You are asking for trouble! Best to run the black wire straight back to the negative battery terminal or negative bus bar that is wired to the negative battery terminal. The other colored wires on the 160C plug are used for interfacing with NMEA2000 compatible devices, like a compatible GPS.
Posted on Jun 15, 2009
budgie140
  • 502 Answers
SOURCE: Is Garmin Fishfinder 90 working?
possibly.most ive owned will flash random numbers when out of the water.the fact its flashing or reading numbers at all,means its working.youll have put it in water to see how accurate,obviously
Posted on Jul 08, 2010
  • 12 Answers
SOURCE: garmin 160c sonar failure
Check your battery voltage, this can occur with low voltage. Charging the battery often resolves this issue.
Posted on May 23, 2011
Garmin fishfinder 160c sonar failure
Hi Lakshmaan:
The first thing I would check would be the electrical connections from the transducer, and the transducer wire.
Jun 07, 2016 | Garmin Color Fishfinder 160c
How to solve sonar failure(Showing on Display) in garmin 160c fishfinder.
I would guess that "sonar failure" would mean that no signal is being received from the transducer.
Trouble shoot accordingly.
I am thinking about buying a garmin 451 chartplotter, can I connect this to my garmin 160c fishfinder for sonar capability?
Hi James!
According to the owner's manual, the 451 can be used as a fishfinder when connected to a transducer. I would contact Garmin directly to see if the ducer from your 160c is compatible with a 451. If it is, you're in business! You'll likely have to cut/splice cable, but it'd be far easier than replacing the thru-hulls. (The 451 does come with transducers.)
It has been my experience that Garmin is REAL good when it comes to answering questions from consumers.
http://www.garmin.com/us/support/
Dec 26, 2014 | Garmin Boating
HOW CAN I CKECK HOW LARGE IS THE FISH TO FISHFINDER 160C?
the bigger the icon the bigger the fish no fish finder can tell you how big a fish is
Apr 15, 2013 | Garmin Color Fishfinder 160c
Garmin 160c sonar failure
May 23, 2011 | Garmin Fishfinder 90
Can I get an inboard transducer for my Garmon 160C fish finder?
Yes you can. You would need Garmin part #: 010-10224-00. You can order this part off the Garmin website if you do a search for 160 and look under the accessories.
Jun 16, 2010 | Garmin Color Fishfinder 160c
Can i hardwire to a 12 volt battery?
Yes you can but you should put a 7.5amp fuselink inline
Mar 05, 2010 | Garmin Fishfinder 160c Portable
To wireup 160c Garmin fishfinder, there are seven clored wires. The book shows red and Yellow to hot. Black and blue to ground. Do the white, green and brown connect? Can the black and yellow be connected...
Jun 14, 2009 | Garmin Color Fishfinder 160c
GPS Logo
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
