Question about Xerox Phaser 6110 Laser Printer
Trying to replace the xerox phaser 6300 imaging unit and it will not release to change to replace with new unit
Soulvisitor
  • 1113 Answers
SOURCE: Xerox Phaser 6250
How Brave is Jan?
Doubt it be the fuser(100 000life), "just magenta dots".... fuser would be "all smudged" or "black marks" , "the print rubs off" , "paper is creasing or jamming"
Can prove it by stopping a print (open door) when paper is1/2 way threw machine, you need to stop it before it goes threw the hot bit, so you can tell if the hot bit (fuser) puts the marks on the paper.
Transfer roller one would expect to effect whole print Smudged/Faint,uneven density
It will be the imaging unit ( 30 000 pagelife Ouch$ ) or possible leaking toner (if aftermarket)
Remove imaging unit and inspect film you should find image of lines, dots are usually chips or sticky stuff on drum surface, carefull no oily human fingers on surface please.
When stopping machine mid print and perfecting your timing, pull out the imaging unit and look at replica of your print notice if marked and where.
Hope this helps
Posted on Nov 19, 2007
SOURCE: Phaser Imaging Unit install error
Worked like a charm! Thank you for the detailed information. The step by step instructions were right on target.
Posted on May 20, 2008
  • 22 Answers
SOURCE: Is it possible to reset xerox phaser 6110mfp
The image unit can be reset.
This is done by use of a small program that Xerox certified engineers use. The process is really simple and only takes about 30 secs, if you have access to the program ( I do... :) ) It can also be used to reset transfer belt life etc ....
Posted on Mar 07, 2010
Semi-Driver
  • 434 Answers
SOURCE: Xerox Phaser 7300 color misregistration
Apparently, turning the unit off for 30 seconds, then back on will force the Phaser 7300 to do a color alignment procedure (according to Xerox support).
Then, if the problem persists, you are instructed to follow a very detailed troubleshooting procedure which I will leave with you in the following link:
Xerox Phaser 7300 Misregistration Issues
I hope this helps!
Posted on Mar 15, 2010
  • 57 Answers
SOURCE: Xerox phaser 7760 saying "non-phaser imaging unit"
There is a snippet on the Xerox website to solve imaging unit recognition problems, link below. http://www.support.xerox.com/support/phaser-7760/downloads/engb.html?operatingSystem=winxp&fileLanguage=en_GB Usually this problem only occurs if the NVRAM has been reset or the engine board has been replaced without backing up the NVRAM. You can download the snippet to your printer through Centreware or by downloading the 'File Downloader' utility from the same page above.
Hope this helps.
Posted on Jan 22, 2011
How do I replace the imaging unit on a 6700 Xerox phaser
If you are not a technician, don't try to do it yourself. Take it to a repair shop.
Oct 06, 2014 | Xerox MAGENTA IMAGING UNIT, PHASER 6700
I have tried using a new fuse to cause an imaging unit to reset on a Phaser 7400 but the fuse will not blow.
If the unit is remanufactured or if you know how, you will have to disassembly the imaging unit and replace the fuser that blowns or simply just solder it. http://www.uninetimaging.com/downloads/technical/xerox/english/Xerox_Phaser_7400_Reman_Eng.pdf
Graphic 27.
Mar 30, 2014 | Xerox Phaser 7400/DXF Laser Printer
Xerox phaser 6360 imaging unit stuck
The lid lifts a lever on the right side of the printer that moves a set of gears that releases the imaging unit. If the lever is broken or disconnected, it will not release. You may have to remove the right side panel to resolve it. You have to release the top, by removing 4 screws, and then the panel will release.
May 18, 2012 | Xerox Phaser 6360 Laser Printer
Xerox phaser 7400 giving error - replace imaging unit- what solution now?
Did it specify a color you should replace? The machine has 4 image units (CMYK) each with a different part#. Replacing them is easy, no tools required. Open the top door, lift out the entire image unit, move the toner over to the new unit, and lower the image unit. Here are the part #'s for the 7400 for each color. Iteminc.com has these online.
C - 108R00647
M - 108R00648
Y - 108R00649
K - 108R00650
Good luck, hope this helps. Thanks for using FixYa!
Aug 05, 2011 | Xerox Phaser 6350/YDT Laser Printer
Hope this helps.
Jan 09, 2011 | Xerox Phaser 7760DN Laser Printer
Phaser 7300 - one color fading on diagnostics page
Are you using third party toner? That is one thing that causes that problem. Use only xerox toner.
The other thing is that your image unit could have come defected, if it was brand new. Try changing the image unit and that should fix that problem. Good luck. 016-1993-00 image unit & toner 016-1977-00
Oct 02, 2009 | Xerox Phaser 7300DN Laser Printer
Xerox Imaging Drum reset ? for Xerox Phaser 2135
The only way to reset the image unit drum is installing a new one. The new image unit has a fuse which once blown it resets the counter on the machine. You can call www.iteminconline.com I have their information in my ad place. They are good techs. I once called for a 7300 image unit reset and they said it was almost the same as a 2135 and they gave me this information. well goodluck.
Jul 24, 2009 | Office Equipment & Supplies
Xerox Phaser 7750 Imaging Unit Percentage Question?
turn macine off wait 5 min repower and run recheck
Apr 06, 2009 | Xerox Phaser 7750GX Laser Printer
Xerox fuser for Phaser 6300 installed in Dell 5100CN- Fuser ID er
I would only use the part designated by the manufacturer.
Feb 24, 2009 | Dell 5100cn Laser Printer
Too much yellow disbursing
Sounds like the yellow imaging unit it defective to be honest. I know its new, but may be bad out of the box.
May 20, 2008 | Xerox Phaser 7300DN Laser Printer
Xerox Phaser  6110 Laser Printer Logo
21 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
