Question about HP VP6210 DLP PROJECTOR RTL Multimedia Projector
Hp vp6210 turn on and then shut down - HP VP6210 DLP PROJECTOR RTL Multimedia Projector
Can l have instraction to conect projector with pc
connect the vga cable to your projector and to your computer.
set your projector input to pc
on your computer you will have to set it to duel screen
usually this is the f8 key or some are fn + f8
or you can get a vga splitter on desktop computers.
hope this helps
Jul 08, 2012 | HP VP6210
I have now Win XP (SP2) on my HP ProBook 6555b. It dont wona shut down!
Hold down the Ctrl key and the Alt key then press the Del key. This will then bring up the Task Manager. Then click on Shut Down then click Turn Off.
This will then shut down your laptop properly.
May 25, 2011 | HEWLETT-PACKARD Hewlett Packard HP ProBook...
Hp 6910p laptop wont turn off. Fan running. what gives?
Something is keeping it from shutting down. This could be caused by a faulty application or driver. My suggestion is to hold the power button down until the unit completely shuts down. Take out the battery, unplug the ac-adapter, attempt to power it on and then put the battery back in. Attempt to restart the computer.
Good Luck!
Mar 29, 2011 | HP Compaq Business Notebook 6910p - laptop...
My HP won't shut down. I hold the button to try a
Try this: Go to Control Panel-Display-Screen Saver-Power-Advanced tab and make sure that after the statement "When I press the power button on my computer" choose Shut down. Then turn off your pc with the power button (if it does not work unplug it, then try the button after Windows complete it's boot-up. Let me know how it went.
WBTech
Feb 01, 2010 | HP Computers & Internet
Printer will not finish shutting down and won't turn back on
Try to unplug the printer wait for about 60 sec, and plug it back in.
Sep 03, 2009 | HP Office Equipment & Supplies
HP VP6210 won´t turn on at all
try to replace all the capacitors on the motherboard. This are the only parts that leak in time. Try otherwise to reset to counter or update the firmware on your machine on the infocus site.
Goodluck !
Sep 04, 2008 | InFocus LP120 / 1000 Lumens / XGA / DLP...
the fuse (if it has one) is on the power supply next to where the plug plugs in. if the fuse is ok, replace the power supply.
Jul 18, 2008 | Office Equipment & Supplies
Projector
Hi, I am not familiar with that model, But usually if you go into the settings menu you will see settings for the display which may be under "Display" "Rotate" "Keystone" "Flip" That model is made to be mounted upside down so somewhere in the menu there will be a setting similar to those I mentioned that will flip the image.
Hope that helps, Sorry I couldn't be more specific.
Feb 19, 2008 | Hitachi PJTX100 Multimedia Projector
HP VP6210 DLP PROJECTOR RTL Multimedia Projector Logo
29 people viewed this question
Seeker5211
Seeker5211
