Question about Hunter 20537 / 20538 The Vista Iron Ceiling Fan
Replace receiver on hunter 52" 5-blade ceiling fan
  • 51 Answers
SOURCE: Hunter ceiling fan
Sounds like the remote receiver units (located where the mains connect to the fans) took a surge and have failed.
Posted on Jul 25, 2007
Richie_asg1
  • 1036 Answers
SOURCE: hunter ceiling fan
Motors work with magnets. These may be permanent, or more commonly elecromagnets. These are the rotor, and the field magnets. Another type of motor just uses a field magnet and iduces flux in the rotor.
Either way, it sounds like one of the main coil windings has either burnt out or mechanically broken.
If you want to remove it and test the coils with a meter (check resistance of each) this should show the fault.
If a coils burn't out. it's scrap .
Posted on Jun 11, 2008
rtpflh
  • 546 Answers
SOURCE: 52 inch hunter ceiling fan with remote, making clicking noise
does the fan wobble at high speed? if so change the order of the blades to try & balance it.i.e. number the blades on a piece of tape on each--switch blade # 1 & #3-better or worse? 2&5;better or worse?etc. untill it runs smoothest.
Posted on Sep 21, 2009
espressonist
  • 1711 Answers
SOURCE: My 52" Hunter Ceiling Fan
The two bulbs are just having a separate live cable in parallel with the one of the motor.
So since you have mentioned that you had a burned bulb this sometimes causes a short inside the receptacle of the bulb. So you just need to disassemble the receptacle of the burned bulb and check both the wires live and neutral they are loose or disconnect or even melt and disconnect.
Is a simple operation since you need to check only two wires however it not so easy to remove the bulbs and reconnect the wires.
Posted on Oct 16, 2010
  • 6 Answers
SOURCE: Hunter ceiling fan 52 ",
Hey dale. Sounds like either the integrated remote pack inside the fan housing might be bad, or the reversal switch part. If it has a switch on the fan housing to change it from forward and reverse, you could try going to a hardware store and replacing that switch. If that doesn't work, then it is probably a bad remote receiver pack iside the fan, it will be a bigger, probably black little box. If this is the case, your better off getting a new fan, as it will cost about the same. If your fan doesn't have a little switch to change blade direction, 9 out of 10 times it is the receiver pack. If your fan does have a switch for fan direction, there is a good chance it is a bad switch. It could also be both. After 10 years with the fan, you might seriously want to consider purchasing a new fan.
Posted on May 21, 2011
How can I replace the receiver on hunter tribeca ceiling fan
The black & white on one end go to the house wiring. The other three go to the fan wiring. Black to black, white to white & connect last two wires together.
Aug 17, 2014 | Hunter 52" Ceiling Fan With Light And...
Hunter ceiling fan fan is working but lights are not
Make sure light wire is connected at the ceiling & at the bottom. Otherwise it's probably the receiver. 1-888-830-1326 ( Hunter parts )
Jan 05, 2013 | Hunter 52" Ceiling Fan With Light And...
We got 4 HUNTER ceilin fans in one room. Model 27185-060 with remote FCC ID:IN2TX11 Two of them are runing clocwise another two in opsite side Wat can we do to run all in one direction?
Your Hunter ceiling fan is equipped with a small switch that changes the spin of the blades from clockwise to counter-clockwise. Regardless of the make or model of your ceiling fan, this switch is typically located on the center motor housing where the fan blades are attached. good-day!
Aug 19, 2011 | Hunter 52" Ceiling Fan With Light And...
May 17, 2011 | Hunter Ceiling Fan Remote Receiver...
I need to know where I can purchase plastic blades for my 52" LG 5 blade fan for use on my covered porch
This URL would be a good place to start looking:
http://www.become.com/ceiling-fan-blades-Hunter-fan-blades?&fltr_brand=hunterfan&updatesearch=Update%20Search&max_price=&dcid=582&scolor=-1&sws=hunter%20replacement%20blades&pcolor=-1&min_price=&updatesearch.y=0&v=list&updatesearch.x=0
If this information helps you I would appreciate you going to the rating section of FixYa and providing me with a rating. Thank you. Paul
Sep 22, 2010 | Hunter Designer's Choice 5-Switchblades Lg...
Remote control works the light on my Hunter ceiling fan but blades do not move
Can you hear the motor run even though the blades are not turning? If so, the manifold/flywheel may be bad and perhaps have broken away from the motor shaft.
Aug 28, 2010 | Hunter "Lexus" Traditional 52" Ceiling Fan...
Sep 21, 2009 | Hunter 52" Ceiling Fan With Light And...
Hunter 20537 / 20538 The Vista Iron Ceiling Fan Logo
41 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Brandon Berry
Brandon Berry
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
