Question about PNY 8GB USB 2.0 Flash Drive - Blue/Black
How can i unlock my flash drive
Attache 128m flash drive the computer at the library locked my drive, how can i unlock it
PNY Attache 64GB usb flash drive Disk is write protected
Normally I'd make something this simple the very first step. Some USB flash drives come with mechanical switch on them that put them into Write Protected mode.
There can be very small slider switch.
And if this is the case, then you must move the switch to unlock position.
Source: http://www.rescuedigitalmedia.com
Oct 01, 2012 | PNY Attache 64GB USB Flash Drive
Software for removing write protection from a pen drive
There is not a straight answer to your question. Multiple methods of removing write protection exist.
Many USB Pen/Flash drives have a switch built onto the unit which can be toggled to turn on or off the write protection. You can see a picture of a Flash Drive with a lock here: http://www.imation-southasia.com/about_imation/newsroom/Flash_drive.html If your unit has a lock switch - make sure it is in the correct position to allow writing.
Other methods to bypass write protection include formatting the drive. In Windows, you can open Computer (Or My Computer in XP) and right-click on the drive letter representing the flash drive and choose Format. Formatting the drive will erase the information on the drive, but it will render it back to a state that should allow you to write files to the flash drive.
Another scenario to be aware of is that some Flash drives may not allow you to write to them if they were originally formatted with a file system that is not supported by the operating system you are currently using. For example, some flash drives formatted a specific way in Windows may not be able to be written to to when you insert the drive into a Mac computer.
A last resort may be to try the unlocking software Unlocker. You can find this software here: http://www.filehippo.com/download_unlocker/ This software may allow you to unlock certain files one at a time - but it may not unlock the entire drive. It's hit or miss.
Finally - if the USB Key you are trying to unlock was locked by encryption software such as DUSK or TrueCrypt, or manufacturer locking, the only way to unlock it would be to format the drive, thus erasing the data.
Nov 12, 2011 | Electronics - Others
Cannot delete pictures from my PNY card
Check to see if you have the lock switch on, this is a small slider on the side of the card. If it's enabled you will need to slide it to unlock and place it back into the computer/camera. You will then be able to delete the contents of the card.
Aug 01, 2011 | PNY 4GB Micro Attache USB 2.0 Flash Drive
I cant copy pictures from my computer to my flash drive im using transcend 2 GB
flash drive may have a locked (read only) so change the lock status to unlocked
try to copy photos again
Apr 18, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I have songs on a usb and I want to put these songs onto my windows media player library
plug in usb drive....open window media player...let it 'search' computer for music/media files...it will automatically add them to your library
Oct 15, 2009 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
Problems
this measn it is active and getting voltage on the pcd
Jun 08, 2008 | Lexar JumpDrive Classic Portable USB Data...
Vivitar v335 35mm
ATI Radeon 9200 SE 128M DDR AGP 8X VGA with TV+DVI for driver
Apr 17, 2008 | HP ATI FireGL V3350, PCI Express Graphic...
Quantum Error
The host backup application probably still has ownership of the library. You normally need to select to 'open door' or something similar to release ownership back to the library
Jun 20, 2007 | Quantum PX502 (PRA22AAYF) Ultrium Tape...
PNY 8GB USB 2.0 Flash Drive - Blue/Black Logo
Top PNY Electronics - Others Experts
john milligan
Sandy Moore
Sandy Moore
Are you a PNY Electronics - Other Expert? Answer questions, earn points and help others
