Question about Whirlpool 3.2 cu. ft. Plus Washer
Roper heavy duty 8 cycle 2 speed how do you change motor
aborcass
  • 2651 Answers
SOURCE: Fill Cycle Won't Stop
heres hteaprt numbr for both the water level switch and the connecting tube, before i replace he switch make sure the tube is connected to rear of tub nad isnot cracked or kinked, and connected correctly to the switch for that matter. a hole in the tube would hamper he switches ability to sense when unit is full
3356466 water level switch,3347780 pressure switch tube
Posted on Mar 16, 2008
SearsTechToo
  • 261 Answers
SOURCE: whirpool washer LSN8244AQ0 motor spins but agitator does not move.
Ok this is a old school machine. Have a look at the drawing below. So no agitation or spin? How about the pump, does it drain? Now if it drains and thatis it then item 13 below is a coupler that is probably out. You can pull the machine out and tilt it back and using a flashlight examine for black dust and touch to see if it is soft in spots and the two white flanges are intact. You may have to remove the pump and motor to inspect.Use part 285753A .
Posted on Oct 15, 2008
  • 1028 Answers
SOURCE: Water not draining out w/ spin cycle
sounds like water may be going out but no spin in last cycle lean washer back and ck underneath for oil leak on top off transmission is a silver colored disk shaped object this is part of clutch if there appears to be a lot of oil on it good chance there is oil on clutch also causing it not yo spin..also ck to see if basket spins after short pause at end of rinse cycle ..start a rinse cycle at setting on timer with lid shut allow to run undisturbed ..once agitation stops in rinse timer should stop then start motor back up to drain ..there should be another short pause then washer should start spinning if does not pause suspect suspect timer if it does pause but doesn't start spinning suspect transmission..remember allow washer to advance by itself DO NOT RAISE LID TO CK..a small load of clothes will let you know if washer has spun
Posted on Oct 26, 2008
SOURCE: won't spin or agitate
coupling.between motor and gearcase.
Posted on Nov 14, 2008
  • 423 Answers
SOURCE: washing machine won't spin dry
If this is a top load clothes washer, almost all units will not spin if the door is open during the cycle time when it should be spinning. If the door is closed, check if the door safety interlock is broken (on most washers, you will see a pin on the door pressing into a little depression)
If these things check out, you probably have a failed transmission deep inside the clothes washer. Fixing that is non-trivial.
Posted on Aug 20, 2009
I HAVE A Roper heavy duty 8 cycle 2 speed combination water won't come into washer machine nor will it work on any wash cycle, but will spin
If u have no water I SUGGEST CHECKING WITH A METER UR INLET WATER VALVE THE COILS MAY HAVE GONE BAD
ALSO MAY WANT TO CHECK THE WATER PRESSURE SWITCH MAY BE STUCK OPEN
Jun 02, 2015 | Roper Washing Machines
What is the capacity size of washer model fws1339ac1
Dimensions/Weight/Electrical Height: 43 5/8" Width: 27" Depth: 27" Approximate Shipping Weight: 180 lbs. Electrical Requirements: 120V/60Hz. Features Control Location: Top Console Capacity: Super Capacity Tub Size (cu. ft.): 3 Agitator Style: Twin Spin Cycles: 13 Wash/Rinse Temperature Combinations: 3 Motor Speeds: 2 Heavy Duty Motor (Hp): 3/4 Total Front Serviceability: Yes
Aug 30, 2012 | Frigidaire FWS1339A Top Load Washer
Roper heavy duty super capacity 8 cycle fabric softener mess
check to see when and where you are to add the softener read the manual for tips look in the trouble shooting guide
Jul 06, 2012 | Roper RAS8445KQ Top Load Washer
ROPER 5 CYCLE HEAVY DUTY. PART NUMBER 3952435
sounds like you have a bad motor coupling(part number 285753a, this machine equivelint to a belt.you tube has a few videos to aid you in this repair, search:: motor coupling whirlpool washer
Nov 23, 2008 | Roper RAS8445KQ Top Load Washer
Won't spin or agitate
Nov 11, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Amana Heavy Duty Extra Large CapacityTop Loading Washer 2 speed - 10 cycle Mod. LW8413W2 Mfg. No. PLW8413W2A S/N R-9504056772 Occasionaly,At the end of a wash cycle it will continue on to the next...
my heavy duty 7 speed motor cut off because of over heating and the belt was changed can you suggest a suitable model of fan belt for it. ?
Jul 07, 2008 | Washing Machines
Washer problem
THE SPEED SELECTOR SWITCH MAY BE SHORTED CAUSING THE MOTOR TO TRY AND RUN ON BOTH THE LOW AND HIGH SPEED WINDINGS. THIS WILL PULL TOO MUCH CURRENT AND TRIP THE BREAKER.
THE MOTOR WINDINGS FOR THE HIGH SPEED COULD BE SHORTED CAUSING EXCESSIVE CURRENT DRAW.
Apr 10, 2008 | Kenmore 22422 Top Load Washer
Whirlpool 3.2 cu. ft. Plus Washer Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
