SHARP EL-330A HOW TO STOP IT FROM ROUNDING
3 Suggested Answers
SOURCE: SETTING TAX RATE
On your Sharp press
CA
C.CE
C.CE
RATE SET(+TAX Key)
175(No decimals for they are not taken into consideration)
RATE SET(+TAX Key)
To check if all went well press
CA
C.CE
C.CE
RATE RECALL(-TAX Key)
It should read your tax rate.
Posted on Jan 29, 2009
SOURCE: Sharp ELSIMATE EL-240SA - how do you stop this
From the manual:
SETTING THE NUMBER OF DECIMAL DIGITS
Numbers of decimal digits of calculation results can be specified by pressing [C-CE] twice, then press [C-CE]and [M+] simultaneously.
The decimal digit assignment will appear as “F” (for “floating point”), “2” or “0” on the LCD. (The default is “F”.)
Press and hold [C-CE] and [M+] until the symbol changes.
Posted on Sep 29, 2009
What does the 5/4 and F mean on the display screen?
F is for floating decimal. If you do a calculation, it will present the results without rounding. For example, 1/2 would be displayed as 0.5, whereas 1/8 would be displayed as 0.125.
The 5/4 rounds the results. For example, if the number of decimals is set to 0, 1/2 is 1. Similarly, if the number of decimals is set to 2, 1/8 is 1.3.
Good luck,
Paul
http://support.casio.com/en/support/answer.php?rgn=5&cid=004001001004&qid=32&num=1
May 21, 2016 | Sharp EL-1701C Calculator
Change square root answer to fractions
It will usually only be an approximation when you do that. Take sqrt 3 for example, 1.7320508.......the decimals go on and on.
So we usually write 1.7321 or some other rounding off. This means 1 and 7321/10000 which does not divide exactly, so you would have to fudge again, say 1 and 732/1000 or 1 and 73/100, which is not the true answer.
Occasionally you get lucky like sqrt 18.0625 = 4.25 = 4 25/100
which is 4 1/4 exactly.
Dec 18, 2013 | Sharp El-531x Scientific Calculator Green...
HOW DO I REMOVE DECIMAL FROM MY CALCULATOR BECAUSE IT KEEPS ROUNDING MY ANSWERS
If you have the manual for the calculator it should tell you there. If you dont have it you maybe able to download it for free that should tell you how to remove the decimal point.
Sep 25, 2012 | Sharp El-531x Scientific Calculator Green...
EL-531X I NEED TO GET IT TO QUITE ROUNDING MY ANSWER
Hi Jennifer,
This may be because of your settings. To change them press SET UP, then select 0 for FSE. Press the down arrow and choose 3 for NORM1 - the calculator should now stop rounding off your answers.
How to I stop my sharp EL-531X calculator from rounding when converting from decimal to scientific notation?
You need to select the number of decimal places you would like, or if you would like the calculator to behave as normal. Press SET UP and select FSE (press 1) . You now have 5 options.
0: FIX means you can choose a fixed number of decimal places for every calculation.
1: SCI means scientific notation and choose the number of significant values you would like to deal with.
2: ENG means engineering and the power goes up in multiples of 3.
3: NORM1 and 4: NORM2 are the usual or normal settings on the calculator. Most school calculations will use NORM1 mode.
Aug 28, 2012 | Sharp El-531x Scientific Calculator Green...
I have a SHARP EL-738 financial calculator. How do I set the decimal rounding to more than 2 decimal.
Press SETUP 0 0 then select the desired number of digits to the right of the decimal point.
Aug 12, 2010 | Office Equipment & Supplies
Sharp ELSIMATE EL-240SA - how do you stop this calculator from rounding up to whole numbers? I generally need two decimal places. Gordon Gillies
From the manual:
Jul 06, 2009 | Sharp Office Equipment & Supplies
SETTING TAX RATE
On your Sharp press
CA
C.CE
C.CE
RATE SET(+TAX Key)
RATE SET(+TAX Key)
CA
C.CE
C.CE
May 01, 2008 | Sharp EL-330AB Calculator
Rounding off numbers
To stop numbers from rounding off; Press the DEC key.
Mar 07, 2008 | Texas Instruments TI-5019 Calculator
jasbo
jasbo
