Question about Garmin GPSMAP 172C GPS Receiver
My Garmin 172C does not pick up satellites
It is used in summertime in a boat. It worked well several years but this year it won't find the satellites. It also shows wrong date and time. What can I do?
SOURCE: garmin nuvi 670
call garmin
Posted on Apr 20, 2008
marcelbakker
  • 174 Answers
SOURCE: Display won't come up anymore
The power switch usually allows you to adjust the backlight with a short tap there should be a scroll bar, use the four way toggle up to increase the back light.
Posted on Jun 16, 2008
SOURCE: My Garmin e-trex will not
It righted itself when I switched it on again outside and 'calibrated' it by moving around with it in my hand. Obviously it is better not to leave the batteries out for so long, overnight, while recharging them.
Once before I had to get back to the factory settings and start again by pressing buttons consecutively quickly but I couldn't do that again. I had forgotten what I did and hadn't written it down. Any ideas?!
Cheers
Posted on Jul 21, 2008
wwjdcgh
  • 114 Answers
SOURCE: no satelite acquisition for garmin 172c
you need to go outside in an open area with no trees around and turn the garmin on untill it receives a sat connection it can take several minutes for it to find it
Posted on Mar 10, 2009
sharcnet
  • 2130 Answers
SOURCE: Garmin 660 turns on but
Please see this link for more information on this problem and why it happens.
http://www.sharc.net/gps_antenna_repair.htm
- Jim
Posted on Aug 19, 2009
What year is serial#4389 36473
Make and model would be useful :>)
US Coastguard Department require all boats to have a sticker near the helm show the permissible number of passengers, total weight and maximum engine size. Usually has the date. Also look for a plate in the forward anchor hatch.
May 18, 2015 | Boating
Garmin gps 60 can not locate satellite
When you turned it on in the hotel, it is not the Garmin. But if you were outside and could see the clear sky, and the GPS evice did not find the satellites within 2 minutes there could be something wrong.
When you switch of an GPS in one place and you switch it on, on a completely different place, it can take a while till it found enough satellites to make up where it is.
But two minutes should do the trick. Don't try this somewhere inside or close to buildings or trees. The device should have a clear "view" to the satellites above the equator.
Aug 02, 2014 | Garmin 60 GPS Receiver
Speed senser on Hummingbird does not work.
You might want to post this question in a different section. This is the computer games section.
Jul 09, 2012 | Hummingbird Computers & Internet
Time and date won't save
Replace the date/time battery. See the instructions on page 87 of the advance user guide.
Jun 11, 2012 | Canon PowerShot A410 Digital Camera
My gps172c fails to receive any sats...same problem last year,boat laid up over winter and in spring when set switched on no sats picked up .Garmin sent me software update and problem solved. Unfortunately...
Similar problem with a Garmin finding current position taking very long time every spring after boat being laid up in winter.
See page 4 and 5 to speed up the process.
When Garmin does a power-up the current version is revealed during the boot. This will ID the update!
The at home(current position) delay maybe due to satellite re-position during the winter and has been the only problem. Once acquired have little or no problem rest of season.
See page 6 on link manual where you can observe the satellite acquisition. During the initial acquisition process it seems to start over many times and eventually locks them in one at a time!
http://static.garmin.com/pumac/GPSMAP172C_OwnersManual.pdf
Hope this helps?
Jul 04, 2017 | GPS
Garmin GPSMAP 172C - cannot find satellites (WAAS)?
WAAS is a seperate service from GPS. It provides GPS corrections so if you can not get WAAS there is no big problems. you unit just wont be as accurate as normal. WAAS only is for North America and EGNOS for Europe. You may want to turn WAAS off for now. I suggest trying a update for the unit. You will need a memory card and Garmin USB programmer. Then just go to garmins site to get the latest update. If you need a USB programmer feel free to Contact GPSCity.ca or GPSCity.com. They are the leading experts in Garmin GPS.
Jul 12, 2010 | Garmin GPSMAP 172C GPS Receiver
The screen is starting to distort and the colors are running together at the top of the screen, Unit is 5 years old
The LCD screen or the graphics driver circuitry has failed. Either way, the unit is effectively unrepairable as it's long past it's maximum design lifespan of three years and so parts and labour will be prohibitive.
Time to update to a new receiver unfortunately, but at least it will also come with a fresh warranty, longer battery life, easier user interface and up to date mapping. In real terms it will also probably cost less than you paid five years ago.
Jun 22, 2010 | Garmin GPSMAP 172C GPS Receiver
I NEED THE MANUAL OR INSTRUCTIONS FOR THE CVS BLOOD PRESSURE
Press Set Time/.Date button and hold down for several seconds. When you let go number - year - will start flashing. Use MEMORY button slowly to correct year. Push Set Time/Date button to set year. Next number will be month - same process. Then date - same process. Then time beginning at midnight using 12 hour clock - same process.
Feb 09, 2010 | Health & Beauty
My remote only show years through 2009, I connected it for updates which it loaded several of, but didn't update the year
the harmony remote updates most of its date and time settings from the computer.
see what the date and time is set to. if its wrong, fix it then update the remote.
Jan 31, 2010 | Logitech Harmony 890 LCD Remote Control
Picking up satellite in Paris
New maps should come with an unlock code did you get one and did you enter it?
Also make sure your battery is fully charged
Thanks for using FIXYA
Sep 23, 2009 | Garmin nuvi 200W GPS Receiver
Garmin GPSMAP 172C GPS Receiver Logo
294 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
