Question about Kenmore Dryers
Cleaned out duck work now blows cold air
Dryer was taking long time to dry ?
  • Kenmore Master
  • 5,323 Answers
ELECTRIC Dryer no heat or little heat:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
Posted on Mar 31, 2015
dididsaythat
  • 291 Answers
SOURCE: Electric Dryer
Dont see a model # or make  but here some tips
You really need a volt / ohm meter to check for Continuity & Volts
Its well worth the investment... $15.00 bucks give or take a few
I would check to see if you have 220v to back of dryer where the cord mounts to dryer,
If dryer is getting only 1 leg 110 volts instead of the 220 will it not heat.
Check themostates & heater for Continuity... Most models, Now have a..
Hi-limit fuse that need to be checked for Continuity and replaced if bad
if you dont have a ohm meter you can hook the wires together
with a small piece of wire and by pass the themostates and hi limit fuse to see if thats the problem or not
Posted on Oct 17, 2007
kachbibi1
  • 979 Answers
SOURCE: Kenmore 90 series electric dryer blowing cold air only
1st check the breakers
2nd check wiring in back to see connections are secure.
3rd check element. It would be burned in two.
4th check thermal overload switch which is located underneath top of dryer. Easy to remove top. Probably 4-6 screws.
Posted on Jan 15, 2009
dealt_soul
  • 296 Answers
SOURCE: blows only cold air
Check connection to heating elements. My have bad heating elements
Posted on Jan 19, 2009
  • 14 Answers
SOURCE: whirlpool gas dryer #LGR4634JQ1 not drying or shutting off
MIGHT NNED A NEW IGNITER
OR GAS VALVE SWITCH
STEVE'S APPLIANCE
516-300-3249
Posted on Apr 06, 2009
  • 686 Answers
SOURCE: Maytag Gas Dryer MDG308DAWW doesn't blow hot air, no clicks heard
Look at the bottom of your front panel and see if you can see a screw on either side about 2-3 inches from the very bottom edge of the front panel. If so take them out and pull the bottom away far enough to disengage the top of the front panel from the top panel. If this works for ya. then now you have it openened, if not repost me.
Posted on Apr 13, 2009
Dryer wont heat for more than 10 minutes when cold
did you clean the vent line?THAT COULD MAKE IT RUN HOT THE AIR CAN'T BLOW OUTSIDE,BUT WITH THE DRYER HAVING HEAT WHEN IT STARTS AND THEN AFTER LIKE 10 MINUTES NO HEAT IT SOUNDS LIKE YOU HAVE BAD GAS COILS,WHEN THE COILS ARE STARTING TO FAIL THEY WILL WORK FOR LIKE THE FIRST 10 TO 20 MINUTES AND WHEN THEY HEAT UP NO GAS,WHEN THE COOL THEY WILL WORK AGAIN,I WOULD CHANGE THE COILS AND CLEAN OUT THE DRYER AND VENT LINE,THIS SHOULD BE DONE ONCE A YEAR SO YOU DON'T HAVE A FIRE AND YOUR CLOTHES WILL DRY ON TIME,EVERYONE THINKS SOMETHING IS WRONG WITH THE DRYER AND ALL THAT HAPPENS IS THE VENT LINE AND THE DUCT WHERE THE LINT FILTER SLIDES INTO FILLS WITH LINT AND THE AIR CAN'T BLOW AROUND GOOD ANYMORE,ALSO WITH A SHOP VAC VAC UP THE LINT WHERE THE BURNER AND MOTOR IS AND THEN SET THE VAC UP TO BLOW AND BLOW THE MOTOR AND GAS BURNER OUT,DO THIS AND YOU'LL HARDLY HAVE ANY PROBLEMS WITH THE DRYER
Sep 30, 2017 | Whirlpool Cabrio WGD6400SW 7.0 Cu. Ft. Gas...
Ge front load dryer
Your issue probably causes by vent duck was blocked either at the rear or from inside the duck. Take off the vent where it hooks up to the rear of the dryer. Turn on the dryer, if it works with hot air again then you have to clean your vent duct. Else, you need a service man to find down what is wrong with the thermostat, burner, etc...
Oct 15, 2013 | Washing Machines
Only a few keys work but it was working fine last night - i cant even type in the password to access the desktop
keyboard error maybe cussed by :
1. the data cable was loose --> open the keyboard from the laptop and the data cable from the laptop than clean the data cable wait until dry and plug in again use the duck tape to strengthen the cable data connection in the main board.
2. dirty --> open the keyboard from the laptop open all the key (carefully) than use vacuum cleaner to clean all of the dirt or use blow it with air compressor
3. moist --> open the keyboard from the laptop than dry it on the sun or yo can use hair dryer
May 13, 2011 | Computers & Internet
Clothes comming out grey and has a soot like stuff on door and inside drum that we cleaned off with carpet cleaner. Cleaned out lint from under link catcher and it was very black.. How do I clean all of...
Sounds to me like that lint is just about to catch fire good. To clean the dryer itself unplug it and from the backside remove the back off of it. Should be 4 maybe 6 5/16" bolts you can remove with a nut driver. Some have the option for a flathead screwdriver. Now clean the duck ways inside the dryer. Now we need to make sure that this was not an even bigger issue. So once you get the dryer back together, and before you hook the vent hose up to it, plug it in and make sure you get plenty of air flow out that vent on the back. If you do the the dryer is cleared. Also check the ventilation tract in the home itself. This gets plugged from time to time and could have led to the dryer also being so plugged. You can either have a duct cleaning service come check and/or clean it out or if you can find where the vent exit on the outside of your home is. Take a high powered air compressor and put an air gun adapter on it and charge the compressor. Wear proper eye protection and, from the outside, blow that air passage clear. It will make a mess but this is what the duct cleaning service will do when they come out so if you can do this you will save some good money. That black is a sign of that lint catching some real intense heat. I would recommend you take care of this before you dry anymore. I would hate to see a place burn down from the dryer catching fire and it has happened.
Mar 21, 2011 | Dryers
Dryer shuts off before cloths are dry,then then you have to wait about 10 mim before you can restrat dryer..cleaned vent duck to out side2 times to besure it was clean..cleaned venting back of...
Check motor for lint build up around motor. Will cause motor to overheat and shutdown on motor
overheat switch and will restart after cooling down.
Feb 11, 2011 | Dryers
Kenmore dryer Model #11074902200, intermittent
if it heats for the first 15 to 30 minutes then no heat the gas coils are failing and need to be replaced,they work when they're cold but when they heat up they fail,the coils are located on top of the gas valve, unplug the dryer,remove the two phillips screws take off the cover and remove the coils one at a time,pull off the wire connector,install the new coil and then push on the wire connector and then do the same to the next coil,also while your in there vac out the inside of dryer,if you have a shop vac,blow off the motor and blow off all the gas parts to clean it good,now take out the lint filter and remove the vent line,take off the back panel and clean out the duct that the lint filter slides into,remove the four screws holding it in and take out the two phillips screws in front of the filter on the top panel,if the vent line is a long run from the wall to the outside i use a leaf blower to blow out the line,make sure the outside flapper is clean also,do this once a year and you'll never have a fire,your clothes will dry on time and your parts will last longer,good luck,if you need any more help let me know,the part number for the coils is 279834 and they are around 25 bucks
Mar 16, 2010 | Kenmore Dryers
Whirlpool modle number LER7646AWO serial number MD1848149 dryer blows out cold air only it started by taking to long to dry clothing then it started to only blow cold air. Eveything else seems to work fine
if it was taking to long to dry that's a sign that you need a clean out on your dryer,you should have this done once a year so you don't have a fire.there is a thermal fuse that will pop if the dryer runs to hot probably from a lint buildup in the vent line or the lint filter duct,when was the last time you cleaned out the dryer?alot of people don't even know they should have the dryer cleaned out,unplug the dryer,take out the lint filter and remove the 2 screws on top where you pulled the filter out.now remove the vent line from the back of dryer and take off the back panel.on the left side you'll see the duct that the lint filter slides into,take the four screws out that hold the duct in place,on some dryers you can remove the duct to clean it and some you can pull it out from the bottom and move it to the right enough to get a vac nozzle into it,if the lint is packed in the bottom use a screw driver to scrape and lossen the pile and remove the big stuff by hand and then vac the rest,also vac the grate on the wall of the dryer half way up the duct and if you have a dryer brush stick it down where the filter goes to clean the duct out good,put the duct back and to the right of it and like 4 inches up from the floor you'll see the white thermal fuse part 3392519,check that with your meter to make sure that's the problem and most of the time it is this,if that's good read out the heater and the termostats to see what part is bad and make sure you have 240 volts going to heater if parts check good,if it was the thermal fuse take the front panel off of dryer by popping the top up with a screw driver and remove the 2 5/16 screws on the inside front panel,disconnect your door switch wires and pull the front panel up to remove it,vac out the inside of dryer,if you have a shop vac put it on blow and blow the lint off the motor and blow the lint from the back forwards so you don't have to pull the drum,put that back together,now if you have a long vent line blow it out with a leaf blower,sart the dryer,go outside and make sure the flapper is blowing open all the way and you should be all set,clean it out once a year so this doesn't happen again
Jan 10, 2010 | Whirlpool Dryers
Not heating up
some times the heating coil breaks or the thermal resistor goes bad
Nov 02, 2009 | Bosch Logixx WFT 2806 Front Load...
Dryer only blowing cold air, washing cycle fine.
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check element, timer , thermostats and safety switch on motor 2 heavy red wires (check wiring diagram for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element washer motor has heat overload sensor
thumbs up
Aug 17, 2009 | Washing Machines
Dryers Logo
47 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
