Question about Toshiba 52HL167 52 in. LCD HDTV
Now the screen has shadow picture like negative. Any suggestion?
SOURCE: toshiba regza 52xf550u has a 6 inch multi colored
If it flickers and changes colors like my 52" did, I removed the back panel cover, tore off the cheap foil on top and removed the t-con board. Used a head gun as I seem to fix alot of things with it now adays since lead free solder is cheap, heat the points up for about 2 minutes, replace it and throw some air circulation. I also noticed the top of my lcd has two main boards the are supposed to match up a platic pin and slide into place, the boards were warped and wouldn't stay down. I used a dremel polishing wheel, cut it in half and wedged them down and tv is running clean again.
Posted on Jun 21, 2010
SOURCE: 2/5 of the screen has vertical lines multi colors.
Posted on Oct 20, 2011
SOURCE: Toshiba 52RV535U LCD TV The right
I havethe same issue and I was told form a Toshiba service center that it would cost$1400 to fix, WTF Toshiba I paid $2600 for a piece of ****.
Posted on Dec 20, 2011
SOURCE: coloured vertical lines on right hand side of screne
Yor tv have problem with T con board. T con board is one which drives the pixels of the LCD panel. If any of the driver satge in the T con board is faulty then this problem can occur.
Some times bad contacts on the connections of the t con board can cause same problem. Remove the tv and find out the t con bard. Remove the connections to it and the reconnect the connections. Then check, if the problem remains the same then the tv need a new T con board.
You have didn't mentaioned any model number of your tv. So it is not possible to show you exactly how T con board looks.
Normally in all lcd tvs the tcon board is place on the bottom or top middile position. Which will be cover with metal cover or aluminium foil.
Here I have added a link which will lead you to the picture of T con board for toshiba.( Not exact one)
T con
Ajin
Posted on Apr 02, 2012
Jan 27, 2013 | Hitachi 43FWX20B 43" Rear Projection...
Nov 05, 2012 | RCA Televison & Video
Jul 09, 2017 | Samsung Televison & Video
Mar 06, 2011 | Samsung HLN5065W 50" Rear Projection...
Apr 07, 2010 | Craig CTV-41331 13" TV
Dec 28, 2017 | Mitsubishi WS-65511 65" Rear Projection...
Jul 15, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Jul 10, 2008 | Polaroid Televison & Video
Mar 03, 2007 | Toshiba 55H70 55" Rear Projection...
Nov 12, 2006 | Toshiba 44NHM84 44" TV
27 people viewed this question
