SOURCE: Whirlpool Thin Twin
Before you run in there with a hammer, is there any way to simply turn off the buzzer alert? I have a different dryer, but I can disable the buzzer. Please check the operator's manual first. If you've gotten to the point of no return, you can disable the buzzer - carefully. Never leave any exposed wires dangling about.
Posted on Mar 16, 2008
SOURCE: whirlpool thin twin dryer starts and stops after 5 seconds
In the back of your thin twin dryer is a small white flat fuse attached with a screw, a clip, and two spade clips and wires. This is a thermal fuse and if tripped will cause your dryer to do nothing. Check with multimeter for continuity and replace if necessary. Also inside machine is a black tubular capacitor that will cause dryer to not run. Again, remove after properly discharging capacitor. Using multimeter check capacitor for continuity and potential. Obviously disconnect all power to machine before even thinking about repair. 240 volts will kill you dead.
Posted on Mar 19, 2008
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
SOURCE: Whirlpool Thin Twin washer won't start, just makes humming sound
The belt is broken and needs to be checked for any other part that has failed causing the belt to burn.
Posted on May 26, 2008
SOURCE: whirlpool thin twin washer dryer
How do i stop the loud pounding noise on the spin ,ajust the balance???or what else,i think the women that first used it put 2 heavy rugs and threw it out of balance?
Posted on Oct 25, 2009
Mar 06, 2016 | Whirlpool LTE5243DQ 24" Thin Twin Electric...
Mar 01, 2015 | Whirlpool Thin Twin Washer and Electric...
Jan 14, 2015 | Whirlpool Thin Twin Washer and Electric...
Dec 01, 2010 | Whirlpool LTE6234D Top Load Stacked...
Aug 19, 2010 | Whirlpool LTE6234D Top Load Stacked...
Apr 18, 2010 | Whirlpool LTE6234D Top Load Stacked...
Apr 07, 2017 | Whirlpool LTE6234D Top Load Stacked...
Nov 17, 2008 | Whirlpool LTE6234D Top Load Stacked...
Jun 10, 2008 | Whirlpool Washing Machines
Mar 16, 2008 | Washing Machines
47 people viewed this question
