Question about Acer Aspire L100 PC Desktop
The motherboard is broken
The same things happened to me, i went and checked it out and they said it was the mother board that was broken.
  • Frank Zabroski
    Frank Zabroski May 11, 2010
    Please be clear as to the type of help you are requesting
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 381 Answers
If you want to know the board is totally broke remove the memory,video card,lancard,IDE connection or SATA..only board and Power Supply (ATX) then boot on..Then Listen the sound their is no sound or Beep the board is Broke but if you hear the beep the board is good so find the other Parts is the real Broke..Good Luck.
Posted on Jun 25, 2009
2009 212 40 watt mk2 in shop mother board went out is this common and what would cause it
"Mother board went out" is a statement of a tech that is incapable of troubleshooting things to the component level. Most common things are broken pots and connectors. There is nothing common to cause a "motherboard to go out". You should find a tech capable of analyzing the problem that has proper test equipment and skill to repair the unit. There is likely a part with cost less than $2 that has failed. Common problems include: broken connectors, broken pots, circuit board cracks, Bad solder connections. Bad solder and bad jacks are most common with bad pots third in line. Bad electrolytic caps are next in line.
Jun 13, 2011 | Line 6 Spider Valve MkII 212 40 watt 2x12...
Looking for power up issue help please. Attempted to put comp. in to sleep mode by pressing keyboard button. Nothing happened. Went to windows xp start button and hit standby, nothing happened. Did this...
few things to try you can disconect the hdd the dvd rw drive and anything elce conected to it appart from the motherboard and moniter then try again (just becouse you tryed to check the psu it my well still be completly broken ) i would probly suspect the motherboard in this case thought i would try a new psu first as this cost less (10 pounds from ebay) hope this helps ps reset the bios and cmos too
Jul 10, 2010 | HP Pavilion a1250n (EG194AA) PC Desktop
No power
check your processor it might be incompatible with your new motherboard.
  • Check out you motherboard manual for supporting processor list, or view on your motherboard manufacturer's site.
Thanks
Iqbal
May 17, 2008 | Asrock P4i65GV Motherboard
No power
check ur smps and power connector Mother board ok
next power switch for on/off ok check front panel byy
May 17, 2008 | Intel Motherboard
No Boot
if u didn't get any thing on display even check signal cable the problem is in the monitor
or you are getting check signal cable the problem is in the mother board or Ram first change the ram even thou you are not getting display change the mother board
Apr 16, 2008 | Computers & Internet
Mother board driver issues
Don't panic. If you take the cover off the side of the computer and look at the motherboard you will find a jumper that says cmos. You can switch the jumper and wait a minute or so then switch it back and it will boot up its defaults. If you cant find the jumper just take the battery out of the motherboard and wait a couple minutes and then put it back in. that will do the same thing and it should boot up fine.
Mar 02, 2008 | Intel Motherboard
Pentium 4
the motherboard and the power box should be replaced. you hade a short and the power box went out and the mother board shorted out as well. If you replace the mother board you will see. This happens alot to people. Check out the numbers on the board at type it in the web and find out what kind you have. you can find motherboards cheap on ebay.
Dec 15, 2007 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Inspiron 6400 DC input fault
please remove the power supply pin from the mother board short the pin witres colured green and black if the power supply is working then there is no problem with the power supply check ur memory card to if the pwoer supply is working iff its ok and still not working contact a chiplevel engineer to correct the mother board as there is problem with powersupply section in ur motherboard
Oct 22, 2007 | Dell (8N816) Motherboard
Acer Aspire L100 PC Desktop Logo
206 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
