Question about Vehicle Parts & Accessories
Where is the location of camshaft position sensor 2003 Audi A6, 3.0
    Problem Solver:
  • 28 Answers
Behind the main pulley at bottom of engine
Posted on Oct 10, 2014
Edge. where is crankshaft position sensor located?
Hi Rusty, There's two links below showing the position of 2005 Ford Explorer Crankshaft Position Sensor and the 2008 ford edge camshaft sensor location. It seems like they're all in the same position, I hope this helps.....CHEERS
2005 Ford Explorer Crankshaft Position Sensor Location
Apr 02, 2016 | 2003 Ford Ranger
Location camposition sensorslincolnls3.9
Hi James,i have a 2004 Lincoln LS with the 3.0 engine,mine is Cashmere in color,here's a link to your camshaft sensor. Repair Guides Component Locations Camshaft Position cmp Sensor AutoZone com Here's what they look like,2 of them. Camshaft Position Sensor at AutoZone com Best Camshaft Position Sensor...
Nov 13, 2014 | 2003 Lincoln LS
Where is the camshaft position sensor located in a
The camshaft position sensor is located on top of the engine near the ignition coils.
The camshaft position sensor is located on the engine near the timing belt cover and under the upper radiator hose.
The camshaft position sensor is either located near the top of the engine, passenger-s side, or on the right side of the engine near the ignition coils.
The camshaft position sensor is located on the engine near the camshaft pulley.
This sensor is located at the front of the engine near the camshaft gear this is what I got 6 different locations manual covers 99-05
Oct 10, 2014 | Cars & Trucks
Where is 2003 ford focus camshafts position sensor
The camshaft position (CMP) sensor detects the position of the camshaft. The CMP sensor identifies when piston No. 1 is on its compression stroke. A signal is then sent to the powertrain control module (PCM) and used for synchronizing the firing of sequential fuel injectors. The Coil On Plug (COP) Ignition applications also use the CMP signal to select the proper ignition coil to fire. The input circuit to the PCM is referred to as the CMP input or circuit.
There are two types of CMP sensors: the three pin connector Hall-effect type sensor (Figure 25) and the two pin connector variable reluctance sensor
and next the location of 2003 ford focus camshafts position sensor
Sep 13, 2014 | 2003 Ford Focus
Engine misfaire
Check your fuel injector.
Dec 12, 2013 | 2003 Audi A4 3.0
Where is the crankshaft and camshaft sensor located?
Here's some pics of my 2003 Altima Crankshaft Sensor. Often mistaken by the Camshaft Sensor because both are identical sensors. They are each located in different locations. I've seen diagrams with the WRONG labeling. Again, this is so confusing for even a mechanic to understand because both sensors carry the same part number which is rare. http://x.nissanhelp.com/forums/members/digitaldxing-albums-2003-nissan-altima-crankshaft-position-sensor-picture331-2003-nissan-altima-crankshaft-position-sensor.html
Oct 07, 2010 | 2003 Nissan Altima
2004 escape where is the crank position sensor located?
We would recommend taking a look at the front of your motor, by either of the camshafts and where they exit the head(s). The sensor is either a optical or hall effect sensor, so try and find a housing that is near or around your intake or exhaust camshaft ( or just single camshaft) for the location of your camshaft position sensor
Jan 27, 2010 | 2003 Ford Escape
Replacing Camshaft Position Sensor Guide audi a4
The camshaft position sensor is located behind timing belt cover in front of engine.Remove cover, sensor is visable in top right hand corner.Unplug, remove 2 10mm bolts.Reinstall,plug back up,reinstall cover,crank engine.
Sep 11, 2009 | 2002 Audi A4
Camshaft position sensor
The camshaft position sensor is usually located on the cylinder head near the camshaft. It may be under the timing cover. It has a small plug and the sensor is where the plug is plugged on.
Jan 23, 2009 | 2003 Mitsubishi Lancer
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
