Question about Toro TimeMaster 30" Self-Propelled Lawn Mower w/ Electric Start
My time master wont start.
Why does fuel leak out of the carby. why doesnt it want to start.
Hey iv got as GV650 Aquila it wont start the motor turns over no problem but wont Start any suggestions?
check for spark plugs and try to push start button at the same time while the fuel pump motor refreshes. there is also a fuel filter through the fuel is pumped to the jets. if this filter is jammed by dirt particles then also you can experience the same problem.
Jul 31, 2015 | Motorcycles
Wont draw a prim
check primer bulb for cracks and leaks .
check hose into the fuel tank for cracks and leaks
pull the carby apart and replace stiff diaphragms.
Jul 23, 2015 | Husqvarna 28cc Hand Held Blower HVH 125B
Kohler twin 22 wont start put carb cleaner in carb runs then shuts off
your actions indicate a lack of fuel in the carby or blocked jets. check filter in the tank, water in the carby , blocked fuel hose to carby, blocked inlet into the carby, blocked needle and seat
May 12, 2015 | Kohler Measuring Tools & Sensors
If I pour gas into carbarater it will run but if u try to start it the regular way it doesnt
Can be several things . By pouring fuel into the carby it is going into the inlet manifold making a rich mixture . check the gas has not leaked from the carby. over night, Check the choke flap is closed before starting with the engine cold. Check the carby.accelerator gas pump is working. by working the linkage you will see a spray of gas injected into the carby. throat. If not the remove and repair.
Sep 04, 2014 | Cars & Trucks
I have a 1987 dodge aries k the car cranks but wont start and is leaking gas out of the carburetor does that mean its bad or is there a way to test it
Fuel for the carby may be dirt in the needle valve that controls the fuel into the float bowl. Pull the top of the carby and clean out the needle and seat and check the float level as well
Mar 23, 2014 | Cars & Trucks
I have put a reconditioned carby on my eh holden it wont start cold with out pourig a small amount of fuel down the throughtof the carby onece running it starts each time perfect sit over night no go
fix the choke to work properly for starters next if you still have the original cast iron manifold then get the butterfly in the exhaust to work as well. It heats up the inlet manifold which helps to vaporise the fuel
Dec 31, 2013 | 1964 Holden EH
How do you deal with an airlock in a mitsubishi galant gdi
Try pouring a little fuel onto the carby then start the engine. You may have to do this several times until the fuel enters the carby float bowl.
Nov 30, 2012 | 2000 Mitsubishi Galant
Wont start and gas is leaking
Check your spark, and if fuel is leaking most likely out of the carby undo bowl on carby empty and check float hasn't jammed and check needle and seat isnt dirty
Dec 16, 2010 | Garden
My push mower will start good but wont stay running..could gas that was left in it over the winter be the problem or just the wrong kind of gas
does it have a fuel tap or not, if it doesnt then the fuel that was left in the carby has gone to jelly or harder ,a carby service should do the trick and save you money in the long run
May 15, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Toro TimeMaster 30" Self-Propelled Lawn Mower w/ Electric Start Logo
100 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
