Question about Pioneer Audio Players & Recorders
I have a vintage Pioneer amp SA-7100. When I switch it on the power red light fails to come on. The 'protection' red light beside it does come on for about 3 seconds before going out. No sound comes from amp. We recently had a power cut on the national grid and I suspect the amp got damaged then. Can this be fixed? I have checked all the fuses - one on rear, and 3 inside and they all look intact. Help!
  • Pioneer Master
  • 3,368 Answers
You probably have a blown output transistor. It can be fixed contact your service shop. It may be covered with your homeowners insurance.
Posted on Nov 27, 2014
simplemitch
  • 752 Answers
SOURCE: PIONEER DC-Z92 CASSETTE DECK AMPLIFIER
Is this one of the units that has a ribbon cable ( looks alot like an IDE hard drive cable) that connects all the components together? It also has a squre plastic fan that protrudes slightly from the rear (by about a 16th of an inch)? If so, it's the power module which consists of 2 boards (along the fan housing). You can probably find replacements for about $70, but I wouldn't bother. They quit making new replacements several years ago and any board you get now is just a pull from old stck units.... and they fail about 2 minutes after you put them in. Pioneer knows this but still sells the defective parts.
Posted on Oct 13, 2007
petraman7
  • 1175 Answers
SOURCE: Gem Sound XP-350 both channels failed
Speaker fuses are generally fast-blow styles 250 volt glass
If an amp shuts down, with speakers connected, it sounds like one of the power supply lines does NOT like what it's "seeing" . Probably output transistors bad ( or module)
Take it to a tech.
Scott out.
Posted on Jan 08, 2008
megatronix
  • 57 Answers
SOURCE: Technics SU-V2 keeps cutting out
An amp will cut out if the output protection circuit kicks in. This circuit compares output power against the preset level. Each channel has it's own, independent protector. There are calculations that can be done, but for a novice the rule of thumb is to "never use a speaker with a power rating less than the amp AND a lower impedance than stated". Typically using a 4 ohm load on a 8 ohm system is inviting disaster. Even if the system does not become a smoke generator, you might notice that though "louder", the sound quality is deteriorated. Many "audiophiles" often hook up some combinations of speakers to have "surround" without really understanding that the collective impedance actually changes (generally lowers).
Posted on Jan 21, 2008
Grubhead
  • 5151 Answers
SOURCE: Bryston 4b amp, left channel blows the back panel
I would check out whatever drives the left channel first. If it is a transistor, you can put a ohm meter on the terminals and see if it shows a short (amp turned off). If there are two transistors for the left channel, and you find a short on one only, replace the other to be on the safe side.
Posted on Mar 25, 2009
petraman7
  • 1175 Answers
SOURCE: NAD C270 amp won't switch from red power/protection to green.
The AH may denote "slo-blo" style as opposed to Fast-acting
A fast-acting fuse will look like a single strand of wire ( maybe wiggly looking) ..A Slo-blo will have an element in it and a spring
Posted on Apr 11, 2009
How many fuses?
Simply disconnect from the power source, take the top off and have a look. There is usually only 2 on the input side of the power supply. If blowing fuses check the DC rectifiers or your connections.
Mar 08, 2016 | Pioneer Vintage Legendary Sa-9500 Ll Sa...
Pioneer sa 7100 manual
Take the case off and look for evidence of smoke or burn marks anywhere in the amp. If you see some, see a specialist.
Dec 14, 2013 | Audio Players & Recorders
Pioneer sx-850 goes into protection after several minutes of use. It seems to be after warm up or when room temperature is too high. Summer temps.
Did you check whether the protection assy is working properly? The protection circuit is checking the current of the power transistors as far as I remeber. So there are several possibilities for that fault.
You should grab the service manual or at least schematic (http://elektrotanya.com/pioneer_sx-850_sch.pdf/download.html) and then go step-by-step. I recommend to start up with the protection assy itself. If this works properly go for the power amp. It is also not unlikely that the power supply is the cause of the problem.
Good luck.
Dec 05, 2013 | Pioneer Vintage Sx 850 Stereo Receiver...
Protect mode
Protection circuit.
Checek the wiring of the amp and speakers, don' forget to look for shorts at the speakers. Make sure no wires are touching each other
Apr 30, 2010 | Volfenhag 1600 WATT CHROME AMP AMPLIFIER 2...
Need plug wiring diagram pioneer deh-46dh
Orange-12v all the time
Red-igintion switch
Yellow- to lighting switch terminal
Black- chassic grd
Green-front L spk +
Green/black -front L spk -
Gray - F R +
Gray/black- F R -
Green/red- R L +
Black/green- R L -
Gray/red- R R +
Black/gray- R R -
Blue- Control to power amp if using.
Apr 10, 2010 | Pioneer DEH-46DH CD Changer
Pioneer VSX-1019 with a flashing red MCACC
you can "release" the error by pressing the "down arrow" and the "zone 2 on/off" for 2 seconds.
Mar 11, 2010 | Pioneer VSX-1019AHK A/V receiver
Hi, I have a Pioneer SA-520 Amplifier (vintage 1982 or thereabouts). It works brilliantly except for the (getting worse) thump on my woofers when I switch it on. I know this is one or more caps that need...
Actually, it sounds more like its speaker protection relay is not protecting the speaker(s) while the electronics stabilize on power up. The relay should pick a few seconds after Power.
Jan 18, 2010 | Audio Players & Recorders
No sound coming out of speakers when turned on
If you get absolutely no sound, not even a pop when changing the standby switch, this probably means the rectifier OR the switch has failed. The red light just means power is getting to the power transformer... probably fuse is OK.
Sep 27, 2009 | Peavey Music
Vintage pioneer SX550 "sputters" when first turned on
Hi...
I own a few Pioneer SXseries recievers..I repair these and others like them in my own business.
What it needs is new power supply capacitors. Parts are cheap. Labor is a couple hours
Jan 29, 2009 | Audio Players & Recorders
My "Power Acoustik OV2-420" has a problem. Some advice please!!!
It appears that the output transistors have failed. To eliminate other possible causes, read through the following page. Let me know if you have any other questions.
Amp in Protect Mode - Troubleshooting
Oct 04, 2008 | Power Acoustik GOTHIC OV2-1200 Car Audio...
132 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
