Question about Kitchen Ranges
Kenmore stove troubleshooting
Kenmore Model C968-63473-1 When oven control knob is turned to the BAKE position, the bottom oven element instantly starts heating EVEN though the oven temperature control is in the OFF position. What needs to be repaired or replaced. Thanks Greg
catriver
  • 878 Answers
SOURCE: Oven will not heat to requested temperature
Shaffy, When baking only the bake element should heat. When broiling only the broil element (upper) should heat. Your oven is a Kitchenaid, you have a 5 year warranty on any electronic element or control board. You may have a temperature sensor that is not working right. The oven just might need to be calibrated, the instructions would be in your owners manual. Your bake element might be failing, it would have to be ohmed out. You also need to verify that the bake element is getting 240V. when turned on. Catriver...post back
Posted on Sep 07, 2006
jsrock516
  • 5911 Answers
SOURCE: I have a Kenmore Stove
You could very well have an Electronic Oven Control (EOC) board problem. There two separate circuits that control the oven BAKE and BROIL functions. If you have replaced the BAKE element, and have ensured it connected properly, the only other component that controls that function, is the EOC. If you post back with your complete model number, I can double check to make sure. The model number will be located on a nameplate somewhere around the oven door opening or lower drawer opening. The reason I need to confirm is because some ranges have a separate relay control board.
Posted on May 28, 2008
SOURCE: ge stove bottom element not working (top working)
The bottom element has probably "blown" out. See if there is a small spot that looks like it exploded. It is similar to an extension cord getting warm and melting in a spot. The only answer is to obtain a new element.
Posted on Dec 18, 2008
pride applia
  • 232 Answers
SOURCE: Largest element heat remains high in every position
you need a new switch no dought
Posted on Dec 24, 2009
blueextc3221
  • 15935 Answers
SOURCE: Control screen flashes F2 and F3; now oven element won't heat.
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 26, 2010
Single element stove oven, doesn't get hot enough
Your oven probably has a feature called a hidden bake element. The element is located beneath the floor of the oven. (Because of this, NEVER put aluminum foil on the bottom of the oven because it will get hot enough to melt the aluminum foil and make it bond to the bottom of your oven.) You can adjust the temperature of your oven through the electronic oven controls. Check your owner's manual for how to do this.
Oct 08, 2014 | Kenmore Kitchen Ranges
Kenmore electric oven will not bake
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Apr 04, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Bake element not working
You will need to replace the oven control ERC
Jan 25, 2014 | Kenmore Ovens
My electric oven & broiler elements are not heating up when the they are turned on. kenmore model # 790.94422300
IF it is a electronic control look at the control panel when u turn it on see if it is flashing a F12 IF IT IS YOUR CONTROL IS NOT WORKING may need to call an appliance guy if its a clock style stove with a couple of knobs u turn for the time u may be in manual mode push the knob in to put it back on automatic also check your fuses
Oct 02, 2013 | Kenmore 40494 / 40495 / 40499 Electric...
I have a Kenmore Ultra Bake. Stove was on bake set to 375. Only the broiler element came on at full power. Tuning off oven did not turn off broiler element. Stove was to hot to move so I turned the braker...
Hi
F3-E2 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 01, 2011 | Kenmore 95002 / 95004 Electric Kitchen...
I have a Sears Kenmore electric drop in range, model # 911.4552092. That's what it says underneath the cooktop. The cooktop works fine, but the stove does not work at all. It suddenly went out while it...
Hello. I can help you.
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Since it is a Kenmore you can get the part at Sears.com. You can price the part there. I can assure you that a technician will charge you at least $125. to do that repair. If the range is old, you may wish to put that money toward a new stove.
Jul 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Oven will not heat.
It bakes poorly Here are two instances of when food "bakes poorly:"
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
    You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
    If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Jun 01, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore oven not working
Hi, You need to unplug the stove, take the back panel off and check continuity on the bake element or after the back panel is removed, plug the oven back in, and turn oven to bake. You should get 240Volts to the two terminals on the bake element. If you have 240 Volts, the element is bad and needs replaced. I can ship you the new element.
Hope this helps
Vic
May 08, 2009 | Ovens
I bought a kenmore toaster oven. There were no instructions.
This controls the heating elements in the oven Briol// Bake// and Toast
Dec 16, 2008 | Toaster Ovens
I have a Kenmore Stove and the bottom (bake) element does not heat up. The top Element is fine. I have replaced the bottom element and checked the fuses and they seem fine. Could it be a control panel that...
May 28, 2008 | Kenmore Kitchen Ranges
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
