Question about Frigidaire Dryers
Frigidaire dryer code e4a - Frigidaire Dryers
  • Official Brand Answer
  • 2,267 Answers
Good Afternoon Friend,
I understand that you are receiving an E4A error code on your Frigidaire dryer. I do not show an E4A error code for your appliance. I do have an EA4 error code which states improper home wiring. The other possibility is that this could be a false error code. I suggest resetting your dryer, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your dryer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Posted on May 17, 2014
  • 172 Answers
SOURCE: error code E4A on my
This is a board communication problem, you need to replace the control board. If you send me the model # I can tell you what the part number and price would be.
Mike Anderson
Anderson Appliance Repair
(865)945-3808
Posted on Dec 02, 2008
taran_2005
  • 10515 Answers
SOURCE: frigidaire dryer error E4A
This is this is the "program Timeout Fault". Meaning the drying time has exceeded program time for that cycle.Press Pause Cancel and SELECT buttons for 6 seconds to exit test modes. Position cycle selector to NORMAL, temperature selector to HIGH HEAT and touch START. Check for anything that would extend dry times such as: no heat, restricted vent, blower fan blade broken or loose, dryer installed in closet with solid door, or bad connection in moisture sensor bar circuit or dirty bars. If dryer operates normally but code returns, replace electronic control.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 08, 2009
  • 1531 Answers
SOURCE: frigidaire electric dryer aeq7000es1 low heat only code e4a store
this is a door switch issue make sure the door switch is not broken
Posted on Sep 17, 2009
  • 13 Answers
SOURCE: Error Code E4A
Try checking the dryer vent to the outside . It should almost feel like a blowdryer for hair . You have some kind of blockage.
Posted on Oct 11, 2009
richroth
  • 9472 Answers
SOURCE: my frigidaire was not drying
This is a board communication problem If this is a "Affinity" dryer, you may need to replace the control board. But lets try this first: MODEL DIFFERENCES: • Better models have a digital readout display
• Good models do not have a digital readout display
READING ERROR CODES 1. Position cycle selector knob to the 3 O'clock position.
2. Press and hold the Select and Pause Cancel buttons simultaneously for six seconds.
3. Immediately after, press and hold the START and Pause Cancel buttons simultaneously for 4 seconds.
4. Rotate the cycle selector knob to the 2 O'clock position.
On better model dryers, the error code will appear in the digital display. On good models, the five indicator lights of
Drying, Cool Down, Wrinkle Rid, and Clean Lint Filter Spin will flash the number of times for the first digit of the code
and the START indicator light will flash the number of times for the second digit. Take separate counts of each indicator
light, then repeat to confirm in order to be accurate in identifying the proper error code. The code is obtained by counting
the number of times the lights flash. Example E24: The five indicator lights would flash twice indicating the 2 and the
START indicator light will flash four times indicating the 4. The five indicator lights and the STARTindicator light start
flashing at the same time. The control will pause for 2 seconds, then repeat the code.
Note: A letter appearing in the code stands for a number higher than nine.
A = 10 B = 11 C = 12 D = 13 E = 14 F = 15
Example Code E4A: the first digit would be 4 and the second digit would be 10. If this code would appear on a dryer in
the Good model line, the five indicator lights would blink four times and the START indicator light would blink ten times.
Troubleshoot problem by using chart below.
To move on to the next code, press the OPTIONS button. To clear code, press the Select button.
To exit this mode, simultaneously press and hold the Select and Pause Cancel buttons for six seconds.
Let me know what you find and we will take it from there.
Richard Roth
The FixYa Team
Posted on Aug 09, 2011
Error code on a Frigidaire affinity dryer EDE, E4A
try going to google and put in the model # and the brand along with the error code.
Feb 24, 2015 | Kenmore Dryers
I am getting e4a on my gas dryer
Good Afternoon Friend, this is Z. Thank you for your post!
Typically error code E4A indicates that your Frigidaire dryer is experiencing a program timeout fault or max time has exceeded for that cycle. A professional normally checks for anything that would extend dry times such as: no heat, restricted vent, blower fan blade broken or loose, dryer installed in closed with solid door, faulty connection in moisture sensor bar circuit. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair your dryer. Hope this helps!
Aug 07, 2014 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
How do i fix error code E4A frigidaire dryer
Good Afternoon Friend, that's a great question!
Typically error code E4A indicates program timeout fault or the max time exceeded for that cycle. A professional normally checks for anything that would extend dry times such as: no heat, restricted vent, blower fan blade broken or loose, dryer installed in closed with solid door, faulty connection in moisture sensor bar circuit. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair your dryer.
Jul 19, 2014 | Frigidaire Dryers
My affinity electric dryer shuts off after a few minutes, isn't heating, and blinks EA4
That means that the ignitor is most likely failing to start the process to ignite the gas. The ignitor is like a light bulb and can burn out.
Here is a link to the information about that: http://www.managemylife.com/mmh/questions/289969-frigidaire-model-faqg7077ka-error-code-e4a-heat
Aug 14, 2013 | Frigidaire Affinity 5.8 Cu. Ft. Gas Dryer
Frigidaire dryer displaying code E4A, clothes are not drying
Hello - Typically it indicates a faulty issue with the timeout program. Contact a professional to move forward accurately. Technician will check for anything that would cause extend dry times such as: no heat, restricted vent, blower fan blade broken or loose, dryer installed in closet with solid door, bad connection in moisture sensor bar circuit or dirty bars. If dryer operates normally after it has be diagnose and code returns, the main control will possibly need replacing.
Nov 25, 2012 | Frigidaire Dryers
Error code E4H
Hi - Are you certain the error code is E4H? This manufacturer does not have such an existing error code however Frigidaire does have an error code E4A. Typically it indicates a faulty issue with the timeout program. Contact a professional to move forward accurately. Technician will check for anything that would cause extend dry times such as: no heat, restricted vent, blower fan blade broken or loose, dryer installed in closet with solid door, bad connection in moisture sensor bar circuit or dirty bars. If dryer operates normally after it has be diagnose and code returns, the main control will possibly need replacing.
Oct 17, 2012 | Frigidaire Electric Dryer
I got an affinity dryer that threw a code of E4A and e68what is the solution?
Press the start pause button and the cancel button hold them together 30 seconds
Jun 05, 2010 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire electric dryer aeq7000es1 low heat only code e4a store
Sep 14, 2009 | Frigidaire GLGQ2152ES Gas Dryer
Frigidaire dryer error E4A dryer will run for about 45 seconds then shutoff and start beeping and showing the above error code
Hope i helped you.
Sep 08, 2009 | Frigidaire Dryers
Error code E4A on my frigidaire affinity dryer
Mike Anderson
(865)945-3808
Dec 02, 2008 | Frigidaire Dryers
Dryers Logo
535 people viewed this question
Top Frigidaire Dryers Experts
Tim Whalen
Sal De
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
