Question about Intermec PC43t
How do I disable the requirement that a blank label be manually fed before printing can occur?
2 Suggested Answers
  • 148 Answers
SOURCE: I get 2 labels(1 with data and 1 blank)for every label printed
THE LABEL SENSOR IS NOT SENSING THE BEGINNING OF THE NEXT LABEL
Clean the photo eye that senses the label gap with a q tip and alchol
Open side door release print head and remove label stock you will see small photo eye clean
put printer in manual mode( switch 1 on to and 1 on botom on
turn printer on it should advance one label and hit skip it should advance another
put back in computer mode
should work now if it still skips check yur label desigh=n software and label mode (continuous or sense label)
Best of luck to you
Posted on Jan 04, 2009
MX522 will not print when doc's are fed in using ADF. A blank page is ejected.
Are you feeding the page through upside down?
Most ADF Units require the page to be writing side up as they loop over the scanner and feed out with the text facing down.
Check the ADF Tray as it will have a picture showing how the pages are meant to be placed to be fed through the ADF.
Sep 11, 2014 | Office Equipment & Supplies
Blank labels being fed
Re-calibrate the printer by switching the printer off, press and hold the feed button whilst turning the power on. Release the button when the light flashes red. Once calibrated try again, if no joy then try a different driver
Oct 08, 2009 | Zebra LP 2844 Thermal Printer
LABELWRITER RUNS THROUGH TOO MANY BLANK LABELS
Merely reboot software and then roll unused labels back on machine. That works for me.
Jun 04, 2009 | Dymo LabelWriter Thermal Printer
Blank labels keep feeding out
Disable start up calibration maybe?
May 09, 2009 | Zebra 105SL Thermal Label Printer
HL-2140 printer: error light on: But, paper is in the tray. I have removed the tray several times and returned it. I have turned the printer on and off. THis problem occurred right after printing on the...
pls. try to download the latest driver from your printers website and upgrade your driver. updated driver will fix the problem.
PS, pls vote. tnx
Sep 15, 2008 | Computers & Internet
Zebra 105se blank labels problem
I would say the roller isn't the problem. I had the same problem on many Zebra printers, but often the calibration helped. Then it could do, when printing task label is for larger/longer than the label size is set in the printer system (conflict of software with printer settings after calibration). It could be set too down to bottom in Y axis. Or it could be in the software settings - as action after print - not sure.
Try to open the printer queue while the label is printed and check if the label has proper number of pages or there's 1 page more. If it is the right number - then the problem is on printer side (recalibrate, reflash it). If the number is about 1 higher, the problem is with settings of the label size (barcode software, printer settings) or action after print on PC side.
May 30, 2008 | Zebra 105Se Thermal Printer
Printer keeps printing blanks...
We have found a reset that we use.
We unplug the printer and then we hold down the feed button and we keep holding down the feed button while we plug back in.
It goes through some sort of a reset and this sometimes works.
Jan 23, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Printer is only printing on every other label.
Adjut the sensor or re-calibrate.
To adjust sensor:
Open up the printer where you put the label, where the paper is fed there is are two green levers, one that helps guide the paper (media guide) which is adjustable by flipping down and sliding that is located  on the right and another one that is ON the media assembly(media sensor) check this for a reference as to what I'm talking about, it's not for a Zebra but they have the same functions.
http://www.posguys.com/download/DataMax-I-ClassManual.pdf
Go to page 29 and magnify it(400%) to get a better look
depending on the type of labels you use is how to adjust
1- labels with a knotch on the side, sensor MUST be all the way on the left ( standing in front of the machine , for reference)
2-labels with a gap in between each one, MUST be set towards the Middle of the labels.
Adjust a little at a time to check by pushing the feed button
if this does not work it must be recalibrated.
I don't have a manual for that printer, sorry.
Oct 15, 2007 | Zebra S4M Thermal Label Printer
Intermec PC43t Logo
Top Intermec Office Equipment & Supplies Experts
pkwc
Paul Bade
donjackson
Level 1 Expert
Are you an Intermec Office Equipment and Supply Expert? Answer questions, earn points and help others
