Question about SoftMath Algebrator - Algebra Homework Solver (689076614429)
1/(x+5) + 7/(22x+20) = (x+13)/(22x+20)
Solve for x.
step by step, please and thank you.
Multiply throughout by (x+5)(22x+20)
(22x+20)+7(x+5)=(x+13)(x+5)
29x+25=x²+18x+65
x²-11x+40=0
x=[11±?11²-4×1×40]/2
x=[11±?-39]/2
Posted on Jun 24, 2009
For a college chemistry experiment, students need to prepare a solution containing ethylene glycol. They are each given 12 fluid ounces of a solution containing 26% ethylene glycol, to which they will add...
Here's the math -
ounces Total amount 26% solution = 12 Total amount 22% solution = X Amount of Ethylene in 26% solution = .26 x 12 = 3.12 Amount of Ethylene in 22% solution = .22 x X = .22X Calculating of 24% solution - .24 = (3.12 + .22X) / (12 + X) solving for X - .24X + .24 x 12 = 3.12 + .22X .02X = 3.12 - .24 x 12 .02X = .24 X = 12 But the solution should be obvious because adding like amounts of each produces the solution percentage that falls in the middle.
Jun 19, 2014 | ixl.com
ASUS 22x Internal CD/DVD Burner not working
Look into the little jumpers on the back.
If its SATA its np But if its IDE you need to set the jumper to master or slave or cable sellect.
May 01, 2012 | ASUS 22x Internal CDDVD Drive Burner
Solve x^2-22x=10
Just complete the square
x^2-22x-10=x^2-2(x)*11+11^2-11^2-10=(x-11)^2-121-10=(x-11)^2- 131.
Use the identity a^2-b^2=(a-b)(a+b) with a=(x-11) and b= square root (131)
Solutions are x1= 11 + square root (131) and x2=11-square root (131).
By the way, the calculator you are refer to cannot perform symbolic algebra calculations.
Nov 30, 2011 | Casio FX-115ES Scientific Calculator
How many years warranty on lg dvd writer
System comes with 1 year standard return to base parts and labour warranty.
Thank youfor visiting FixYa! We answer yourconcerns promptly for FREE. Please spare a few seconds toclick on YES button and leave ashort comment to let other people know how I help you. Have a good one!
Jul 27, 2011 | LG GH22NP20 22x Internal DVDRW Retail Kit...
My dvd writer is not reading cd
1.If you are qualified only then take the steps below
2.There is some accumumlation of dust particles on the lens of your Drive
3.Switch OFF the system and remove the cover ,Take the drive out by removing IDE/SATA cables,Power connector .Unscrew the drive and take it out now wipe it with some cloth so that no dust particles enter inside while you open the Drive.
4.Take a screw driver and open it there are mostly 4 screws below the drive remove the cover and take out the drive out from the tin cover you will find the lens in a upright position.Clean the lens with cotton bud dipped in spirit or cleaning agent very carefully please be gentle not to damage the lens. After that replace the drive in the same way and plug in the drive now try again your drive will work .
5.Even if your drive does not works now then you need to replace your drive there is some problem with the chip powering the drive .
take the above steps and hope your problem is solved please don't forget to rate me...
Dec 27, 2010 | LG GH22NS50 22X DVDRW SATA Drive OEM...
I bought an intel 3.2 processor and after intalling it work alright but also asking for microcode update for the stepping. please help me solve it. Thank you.
Jul 26, 2010 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Compurt is not recognizing a new LG 22x Internal DVD rec
Change the Master/Slave/CableSelect(CS) jumper on the back of the drive (between the power connector and IDE cable)
STEP 1:
Check that the IDE cable red stripe goes to pin 1 (closest to power plug) flip cable if needed.
STEP 2:
Move Jumper to SLAVE position. reboot. check for drive in os. if it's not there;
STEP 3:
Move Jumper to MASTER position. reboot.
If it's still not working replace your IDE cable and try again
Jun 20, 2009 | LG SecurDisc 20x External Double-Layer DVD...
My prixma IP 1000 has message "Waste Ink Tank full, contact Service Engg."
Please try below steps on your Printer and let me know the result. I hope this should work.
Steps are:
 Reset waste ink tank counter CANON PIXMA iP 1000
STEP 1:- Disconnect printer from AC power
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
This should work. please let me know the result.
Bye.
Oct 18, 2007 | Canon PIXMA iP1600 Printer
Computers & Internet Logo
121 people viewed this question
Top SoftMath Computers & Internet Experts
k24674
ali_zulfikar
ali_zulfikar
Starnley Johnwells
Starnley Johnwells
Are you a SoftMath Computer and Internet Expert? Answer questions, earn points and help others
