Question about Homelite Garden
John deere bc1600 trimmer engine died suddenly while running.
The trimmer engine died suddenly and I cannot restart because I cannot pull the starter string. The string is stuck.
woobie dog
  • 1273 Answers
SOURCE: I need to know how to re-string my John Deere
Hello, W/D here.
I'm afraid that mental pictures are the best I can do, but bear with me; I'm good at it....We'll go over the spool parts, and the first time you wind tha spool, don't put any line on it....just read the directions while you hold the spool in your hands. Get a feel for what you are going to do. See how it will fit where it needs to go.....
All right......
Pull the spool out of the head.
Just look at it. You'll see that it is actually two spools.
Look at the divider between the spools. See the notch?
Look at the middle of the spools, or the core, where the line winds on the spool. See the small holes, one for each spool?
Flip the spools upside down. Look at the bottom. Note the notches in the rim of the bottom, and the arrows indicating the direction to wind the line. Look near the notches. There should be numbers next to the notches. This is the line size that fits your machine.
Take a brief look into the hole where the spool will attach to the head. We'll talk about that in a minute.
All right, let's do it. Remember, no line for the first walk thru. Take your line and snip the end at an angle, say about 45 degrees. Now take the pointed end and poke it about 1/8" into the small hole in the core of the inner spool (the spool closest to the bottom of the spool assembly). The purpose of placing the line in the hole is to anchor the line while you wrap (load) the spool. Start wrapping the line on the spool, going in the direction of the arrows. When you have that spool wrapped almost to the diameter of the rim, place the line in the bottom rim notch that is 180 degrees from the notch that is in between the spools. The line should fit into the notch snugly. You want about 6" of line to hang out past the notch and cut it so you have a 6" tail hanging out.
Now, fill the outer spool the same way. When you get it full, you'll pass that line into the notch in between the spools, and anchor it into the notch on the rim. Again, leave about a 6" tail, and cut it off.
Hard part's done. Get the spool close to the head, and thread the tails into the grommets on the machine head. Once both ends are in the grommets, straighten up the spool (align the notches holding the tails with the grommets) and push the spool into the head.
Almost there! When the spool is firmly set in the head, you'll feel a bit of a click, Grasp the tails, and tug on them enough to pull them out of the notches that were anchoring them to the rim.
Let's check our work. Push the spool in, simulating bumping the spool on the ground to advance the line. Once you have pushed it in, tug again on the tails. You should pull about an inch or so from each side, and then the line will stop.
Once you have that, you're done!
Now, about the hole in the bottom of the spool where it connects to the trimmer head....Sometimes, the line will be difficult to advance, so you should clean it out a bit from time-to-time. The trick that will help you is that, after cleaning it, put a little graphite dust in the hole. This lubricates the advancing mechanism without leaving an oily residue that will collect debris. Don't do it this time, maybe not next time, just some time. I probably do this maybe every eighth or tenth time I wind the spools or so. I buy the graphite usually at Lowe's or similar. It's used for locks, but you an also get it at Hobby Lobby where it's used for Cub Scout race cars (Pinewood Derby). Same stuff.
Sorry about no pictures. Turns out you didn't need them after all!
You've been a great student, and it's been a pleasure.
Best regards, --W/D--
Posted on Aug 18, 2009
  • 120 Answers
SOURCE: Pull cord on TB25CS trimmer came out all the way, won't recoil
http://www.m-and-d.com/pdfs/MTD/TB25CS-41BDT25C063PL.pdf
Probably the recoil spring is broken.
Posted on Aug 24, 2009
SOURCE: gas/oil mix john deere C1200 trimmer
50:1
Posted on Jul 13, 2010
  • 5 Answers
SOURCE: The pull cord on my
well its not going to start with electric because the cord is out of it...
just take it apart becareful do not pull the recoil out or your in a mess....
but this should help you out if you need to know more just ask...
Posted on Aug 18, 2010
SOURCE: Have a Toro 51990A string trimmer. It starts, but
toro trimer model 51990a part drum with eyelet
Posted on Aug 27, 2010
John Deere 350C Dozer starter will not turn engine over?
Sounds like have a head gasket. Water in cylinders. Water
don't compress. Don't try to start with water in cyl., it will
bent the rods. Pull injectors or etc.
Aug 18, 2012 | Garden
I have a John Deere Gas Weed Trimmer, Model BC1600, Quik-Fire Start. It was given to me. Can I get a manual, it needs some parts. Thanks,
There is no electronic manual available for this model. It is listed as a Homelit UT5198. Here is a great parts breakdown list with diagrams and the prices to buy for every part on it.
http://www.ereplacementparts.com/homelite-bc1600-ut15198-trimmer-parts-c-18807_20299_20514.html
May 13, 2011 | Yard Machines Garden
I need a parts list and manuel for a John Deere BC1600.Any Idea
www.ereplacementparts.com, search for bc1600 homelite is the same trimmer
Mar 02, 2011 | Garden
A,b,g Tractor Carburetor Float Dltx10: i had my john deere riding mower running then shut...
My John Deere only starts with a hammer. I have the Kawasaki engine and it is famous for bad starters, so I carry a hammer and tap on the bolt when I want to start it. So, you either have a bad solenoid in your starter, or the contacts are dirty, battery connections are dirty. Or the battery is dieing. Check it out. Hope this helps.
May 07, 2010 | John Deere A,b,g Tractor Carburetor Float...
I have a john deere 455 tractor mower, while running on full power it suddenly dies and sits on idle for 30 - 60 seconds before regaining power.
Can be a number of things but first would replace fuel filter also see if injector return line is plugged.Can be fuel shut off valve going bad it's located near injection pump,governor maybe a place to look but without knowing if engine is putting out alot or no smoke {color} it's hard to diagnose it.Have you checked your fuel tank for proper venting?
Feb 22, 2010 | Garden
John Deere 425 AWS no start, no nothing???
Sounds more like a bad starter than a bad coil.
A failing coil usually shows up during hot weather. The engine will start and run fine, then when it heats up, it just dies out. After a few minutes, it cranks again. Then the cycle repeats itself.
The ignition module and coil pack are the same part.
Are you sure full voltage is getting to the starter? There is likely a starter solenoid between the ignition key and the starter. These solenoids can be problematic and prevent the full 12 volts from getting to the battery.
Oct 16, 2009 | Garden
My John Deere 345 dies for no apparent reason
You have dirt in the fuel tank and it sucks the dirt up on the filter that is attached to the pump. After the machine stalls, the dirt falls off and it will restart and run for a few min.
Oct 02, 2009 | Garden
Garden Logo
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
