Question about Oster 12-Bottle Wine Cellar - Black
Our wine cooler has stopped working. We can't
Our wine cooler has stopped working. We can't adjust the temperature which shows a constant display of 71. When we try to adjust the temperature, to say 51, the display flashes about 3 or 4 times and then returns to 71. The cooling unit appears not to be functioning at all -- at least we don't hear any electrical component turning on. We are not able to set the unit to a cooler temperature. What should we do? Thank you, Mary Anne Fleetmafleet@juno.com303 278-0928
  • 10,515 Answers
This cooler has a temperature control board. It seems that you have defective control board.You need to get it repaired or replaced.
Replaced would be a wise idea as repair would cost you more than 50% cost of the new board.The motherboard is not available easily.
You need to contact them at :-
(800) 334-0759
You can also fill a form to contact them :-
https://secure.oster.com/ContactUs.aspx
Hope i helped you.
Thanks for using "Fixya".
Posted on Jun 23, 2009
I have a igloo 48 bottle wine cooler, and it will show error code "LC" and then you can not adjust the digital temperature or turn the light on. It fridge still feels code? Any ideas would be great!
Could be the temperature sensor. There should be a support number in the manual you can call. Hope you can get it fixed. if not check out my blog for help choosing your next cooler. The Best Wine Coolers The Complete Guide Vino Coolers
Jun 07, 2016 | Furniture
Wine cooler frost buildup
Some dual temperature wine coolers build up frost in the rear and top of the main compartment. Check the defrost timer, located either inside the main compartment near the light, or outside on the back of the wine cooler near the compressor. Look in the owner's manual for the correct settings for the defrost timer and adjust yours as needed. Make sure that you have the wine cooler in a spot where the outside temperature remains at or near room temperature to reduce frost buildup.
Aug 11, 2012 | Danby DWC283BLS Wine Cooler
My wine cooler will not run at all. The compressor is Ok. The cooler uses relay 41006036 rev E. I do get continuity on both the pot and the thermistor. What is the correct resistance for the thermistor...
Hi
Please check this link to read detailed information related to wine cooler as per your query:-
http://www.winecoolerexpert.com/wine-cooler-faq.html
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
May 05, 2011 | Marvel (6SBARBSG) Wine Cooler
How to adjust the temperature of the wine cooler
How is temperature adjustment set for proper cooling,my Haier holds [9] btls of wine ,please help.
Jan 05, 2011 | Haier BC112G Wine Cooler
COOLER IS GETTING POER BUT NOT COOLING. TEMPERATURE CONSTANTLY SHOWING 72 DEGREES.PLEASE SUGGEST TROUBLE SHOOTING. #K0700305460011335 MODEL: OW0912H6H
Check the lint trap behind your cooler to make sure it isn't clogged... I had the same problem and after vaccuming the lint trap, my cooler started cooling again
Feb 06, 2010 | Oster 12-Bottle Wine Cellar - Black
Digital temperature display is missing part of the
You are going to have to replace the display. Easy fix even if you are not very familiar with this system
Jan 02, 2010 | Oster 12-Bottle Wine Cellar - Black
My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
Nov 20, 2009 | Avanti WC3201D Wine Cooler
Chamber wc902 wine cooler which wont set temp
I have the same issue especially when there is a power outage. To reset it, press the preset until "1" appears, then adjust the temperature as low as it will go by repeatedly pressing the temperature "-" button. Usually works.
Oct 08, 2009 | Tower Chambrer WC601B 7 Bottle (6+1)...
Temperature guage shows "LL"
Probably a bad themp control. try jumping it out. If the unit runs get a generic cold control with a variable temp adjustment. A water fountain control would work as well. Jeeze these dayum chinese pieces of **** are so bad.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 08, 2009 | Haier BC112G Wine Cooler
Motor never stops.Inside temperature too cold
it has to be the thermostat,solution,replace stat.have the new one ready,as you take out the old one,and its hard to go wrong if you take your time,good,Luck eire!ps. motor won't stop unless stat cuts out!!
Dec 15, 2007 | Haier HVF042 Wine Cooler
Oster 12-Bottle Wine Cellar - Black Logo
369 people viewed this question
Top Oster Furniture Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
jasbo
jasbo
Rob Sinbad
Rob Sinbad
Are you an Oster Furniture Expert? Answer questions, earn points and help others
