Question about Pyle PT649D Single Cassette Deck
Why doesn't my Pyle pt649d play
Press play button and release. Doesn't play
    Scholar:
    New Friend:
  • 101 Answers
Hi there! 1) Is the power okay? 2) Are the drive belts and capstan rollers okay? 3) Is the cassette in good working condition? Try it on another machine 4) When did it have was the last time had a good cleanup and lube done?5) If it runs on torch batteries, replace them if you do not have a proper battery tester a digital meter's readings are little more than useless ^Get a geek or technician have a look if these ideas did not solve the problem
Posted on Nov 25, 2014
Doesn't fit pyle
Your supplier of the kit can answer that one.
murf427
Aug 01, 2012 | Metra 2004-2009 Ford Radio Double-din Dash...
Tip
How to hire android app develop?
While hiring android app developer, you should remind these things. Hiring a developer who
  • Doesn't Have a Good Sense of Product Behavior
  • Doesn't Own at Least One Good-Looking App on Google Play
  • Doesn't give Poor Time Estimations
  • Doesn't Have Experience with Releasing an App and Publishing It on Google Play
Hire Android App Developers Android App Programmers
on Feb 13, 2018 | Android Apps
I have a Digihome 19LCDVD911 TV and the remote will not work in DVD mode, why is that?
do not know here but iam surmising that you have to go into menu and select DVD play then it should work ? maybe
Dec 26, 2011 | Televison & Video
I have a ge universal remote and a panasonic tv but i dont have the directions on how to program it or what the codes are to set it up. i need step by step instructions.please help
There are two types of GE universal remotes. Does your remote use the 4-digit code or the 3-digit code?
These codes listed below are not for combination TVs (TV/VCR, or TV/DVD). If you have a combination tv, see the appropriate code list here: http://www.jascoproducts.com/support/universal-remote-codes.asp .
The 3 digit codes for Panasonic TVs are 003, 054, 055, 062, 070, 148, 149, 170, 171, 374, 381, 437 . If you have an LCD or Plasma Panasonic only try 170.
The 4 digit codes to try for Panasonic TVs are 1182, 0171, 0148, 0054, 0170, 0062, 0374, 0381, 0437, 0950, 0003, 0070 .
Next to program the remote: Turn on the TV manually. Press and hold the Code Search or Setup button (depending on your remote). Hold the button until the indicator light comes on and then release it. Then press and release the TV button. Type in the first code for your remote and TV combination. The indicator light should go off. Then point the remote at the TV and see if the TV turns off. If it doesn't, repeat the above steps. Once you have a code that seems to work, check if the remote controls all of the functions that you need (based on the available buttons on the remote). If you have a code that turns off the TV but doesn't control other functions, continue trying other codes.
There is an option to search through all of the codes of the remote to program the remote. Press and hold the Code Search or Setup button. Release the button when the indicator light comes on. Then press and release the TV button. Now press and release the Power button on the remote repeatedly and wait until the TV turns off. Do this slowly (pressing the Power button every 2 seconds). When the TV turns off, press Enter on the remote to save the code. Then test the remote. If the remote doesn't control all the functions of the TV that you want it to, then repeat the search.
Please note that the codes in most universal remotes are limited to those for devices released 6 months or more before the remote was programmed. If your remote is older than your TV, then you may need a new remote.
I hope this helps.
Aug 06, 2011 | GE JASRM24912 Remote Control
NEED A OWNERS MANUAL FOR A PYLE PLD 194
pyle doesn't offer the manual on their website I would contact them directly here:
http://www.pyleaudio.com/ContactUs.aspx
thank you and good luck,
Lee
Jul 18, 2011 | Pyle PLD-194
My mp250 printer shows error p08, I can't use it in any way. I replaced the black ink tank with a new one and tried resetting the printer and it doesn't solve the problem.
Follow the instructions step by step
  1. Turn off printer, cable power still plug in,
  2. Press Stop/Reset button don't release
  3. Press Power Button don't release and than release Stop/Reset button
  4. Press Stop/Reset button 2X , wait until service mode to " 0 "
  5. Turn off printer, cable power still plug in
  6. Press Stop/Reset button don't release
  7. Press Power Button don't release and than release Stop/Reset button
  8. Press Stop/Reset button 4X , wait until service mode to " 1 "
  9. Turn off printer, and loose cable power, wait one minute.
  10. Connect cable power, turn on printer again, now this printer ready to use.
Jul 06, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
F27 came up nearing the end of the spin cycle and just stops after it's spun but doesn't finish and release.
Close the washer and press the START/PAUSE/Cancel button to remove error displayed and restart the cycle. If it doesn't work, it means that the valve at the water entry needs to be replaced..
Hope this helps..
Jun 10, 2011 | Siemens WFXD8400UC Front Load Washer
Does this unit come with speakers
If it has no volume control or terminals for speakers then it is a hi-fi seperate and needs to be connected to an hi-fi amp to work.
Dec 31, 2010 | Pyle PT649D Single Cassette Deck
My htc touch 2 doesn t start anymore... it does ask me to press send button to reset it but it doesn t go
  1. Press and hold the TALK and END buttons, and at the same time, use the stylus to press the RESET button at the bottom of your device.
  2. Release the stylus, but continue pressing the TALK and END buttons until you see the following message on the screen:This operation will delete all your personal data, and reset all settings to manufacturer default. Press Action to restore manufacturer default, or press other keys to cancel.
  3. Release the TALK and END buttons, and then press ENTER on your device.
Mar 11, 2010 | HTC Touch P3450 Smartphone
HTC touch HD is completley frozen
If you have all your items saved to your computer with Active Sync, then do a master reset:
HTC Touch hard reset 14 January 2008
  • Power on.
  • Press and hold buttons marked 1.
  • Press and release 2 with stylus.
  • Release buttons marked 1 when menu comes up.
  • Press directly down on center dpad, marked 3.
You can also get tips & tricks from www.htcwiki.com
It has the latest and great updates, software, even known issues if you ever come across this. HTC does recommend that you do a master/hard reset once a quarter to keep it moving smoothly. Also, ensure you don't have a lot of open running programs. Perhaps once a day, clean the cashe and history. Do a soft reset (aka battery pull) once or twice a week. All depends on how hard you play with this lovely PDA device!
Feb 02, 2009 | HTC Touch HD Smartphone
Pyle PT649D Single Cassette Deck Logo
57 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
