Question about Frigidaire Affinity FAHE4044MW 27" Top-Load Washer with 3.4 cu. ft. Capacity, 14 Wash Cycles, 2 Specialty Cycles, 800 RPM Spin Speed, WaterFall Wash, Fresh Water Rinse and Energy Saver Option
E pa au u5 5e
Error codes
    New Friend:
Im getting the exact same code in my affinity dryer. Does anyone know what to do?
Posted on Jan 18, 2015
  • Official Brand Answer
  • 2,267 Answers
Good Morning Friend,
I understand that you are receiving multiple error codes on your Frigidaire Affinity washer, model# FAHE4044MW. I see that the error codes showing are "E", "PA", "AU", "U5", and "5E". I suggest resetting your washer, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. When you restore power, start any cycle on your washer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
WP
Posted on May 17, 2014
My kleenmaid ked600 condenser dryer is giving me a F4 error code. And not heating. Could it be the thermostat? Where can I locate the meaning of the error codes ?
In case of F0, F1, F2, F3, F4 failures,
contact your service technician without
hesitation.
http://www.kleenmaid-appliances.com.au/assets/pre2011_manuals/Use&Care/DR/KM_DR/KED600.pdf
and then I found this
"F4? Too much lint in the lint filter, front housing, or in the condenser Clean lint from lint filter and/or condenser I would just contact them.
http://www.kleenmaid-appliances.com.au/support/contact-us/
Mar 04, 2016 | Dryers
Samsung dishwasher dms500trw. what does error code f3 mean. i just replaced the hose after e2 code now 2 weeks later i have f3 code?
Samsung DMS500TRW - ProductReview.com.au
www.productreview.com.au > ... > Dishwashers > Freestanding > Samsung
Rating: 2.4 - ‎49 votes
2.4 out of 5 stars for Samsung DMS500TRW in Freestanding Dishwashers (page 2). ... The machine gives an E2 error and will not pump water out. I have to manually cup it out. ... F3 Error. 1 out of 5, reviewed on Sep 30, 2013. Purchased dishwasher in Jan 2012. First broke ... F3 what dose this code mean? Dell asked on ...
Nov 26, 2015 | Dishwashers
Frigidaire electric dryer model FARE4044MW won't start it has a bunch of codes "RR AU U5 SE. I tried restarting unpluggin for 3-5 minutes but it did not change
Thank you for your inquiry, Maria May! I see that your Frigidaire dryer is displaying multiple error codes of "RR AU U5 SE". Those codes mean that the dryer registering the door is opened. I would suggest that this could be a faulty control panel or door latch. I understand that you have unplugged your dryer and it is still not working properly after you reset it. I would recommend you consult with a professional technician if you continue to experience issues. Hope this is helpful. -Matt
Jan 18, 2015 | Frigidaire Dryers
I have ge he sensor model gtdn550ed0ww it keeps showing se pa au u5 I can't find out what that means and it keeps shutting off after a few minutes and then it turns itself back on but it won't dry and only...
Your machine is scrolling the word "PAUSE" across the display. Simply press the START button and it should resume operation. The display will look like this:
pa
au
us
se
Repeat
If pushing the start button doesn't work, check to make sure the door lock is working. This video shows a similar model:
If the door lock isn't bad or doesn't repair the unit, you may have a wiring or control board issue. All these units have a tech sheet included somewhere in the cabinet, with a list of field-replacement parts and a wiring diagram. My guess is that a control board for this unit, or a switch panel, will be hundreds of dollars. Pray for a cheap repair.
Jan 07, 2015 | GE Dryers
While transmissing 'E7" is displayed in vertex repeater. how to rectify this problem?Manual says it is PA Unit Problem.Pls tell me a solution for othis problem.
This error arises when the PA module draws abnormal current. I had this problem because of a bad solder joint in the harmonic filter that is located directly following the PA module. Because of that, the PA sees a mismatch on the output. The VSWR sensor will not detect this because it is placed AFTER the harmonic filter. In my repeater this harmonic filter was inside a shielded module that was really difficult to remove. After I removed it, it turned out one of the caps in the filter was not soldered properly. I am not saying this will be the case in your repeater, it could be another problem but for me this solved the error code issue.
Jun 28, 2014 | Vertex Standard Radio Communications
Error codes troubleshooting
I found the manual, and the error codes start on page 41.
W002 something like input under voltage and E007 IGBT sat, what ever that means.
Save the manual for future usage.
http://www.superiorsolar.com.au/wp-content/uploads/2011/05/aurora_pvi-2000_outdoor_installation_manual.pdf
Apr 30, 2014 | Solar Electronics - Others
Canon pixma mx 700 won't scan showing error code 0x00000015
This is a windows or software error code,Uninstall the scanner/printer software and reinstall from the CD
If you have lost it you may download new drivers from here
http://support-au.canon.com.au/P/search?model=PIXMA%20MX700&filter=0&menu=Download
Aug 16, 2011 | Canon PIXMA MX700 All-In-One InkJet...
E04...how to setle it
That error means that an ink cartridge is empty. To cancel printing, press the Stop/Reset button. To continue printing, press the OK button. After the printing finishes, replace the empty ink cartridge. Printing with an empty ink cartridge may cause machine malfunction.
You can read more about the error codes on Canon website: http://support-au.canon.com.au/contents/AU/EN/8000137001.html
Dec 05, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Frigidaire Affinity FAHE4044MW 27" Top-Load Washer with 3.4 cu. ft. Capacity, 14 Wash Cycles, 2 Specialty Cycles, 800 RPM Spin Speed, WaterFall Wash, Fresh Water Rinse and Energy Saver Option Logo
273 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
