Question about Irons
Castelgarden hydro lost all power battery ok sensor seat ok and at bk solinoids ok ignition ok just wont light up dash lights and start by key
Iron heating sporadically and sensor lights working sporadically
sounds like a loose connection in the power transfer, some piece of metal may be broken or the cord itself may be damaged in some place, you could try replacing the cord. I would just go and buy a new iron. They aren't all that expensive anymore. Good luck with whatever you decide to do. I hope you solve your problem. If you want any further help or have any other questions, please let me know, otherwise have a Good Day.
Mar 29, 2008 | Rowenta DZ9080 Iron with Auto Shut-off
2000 vw passat security system problem
Sounds like the push button start is aftermarket
It's been bypassed to add the psh button
That will make electrical problems
If your not. Handy with that keep away
Hope it helps
Sep 03, 2014 | Irons
I have a Morphy richards steam elite 42221 the problem is that the water light comes on even when the tank is up to max. If I turn the power on and off the generator works for a short time then the light...
What did you use to clean your device ?
hard water can cause all sorts of troubles and this might be one of them, Yes anything can be fixed if you please
try strait vinegar in your unit, it will not damage and it works very well against hard water deposits that can cause problems like this, if this dose not work get back to me and we will try to find out what is the problem and make it right again
Oct 20, 2013 | Irons
Iron just stopped working, no lights, no heat no iron Opened back panel to make sure no loose wires or damage inside. The inside still looks bran new and the wire cap connectors are intact. Iron may be 2-3...
check plug fuse, if ok, check continuity of the live, neutral and earth conductors for a break. if ok, element may be faulty. Any smell of carbon burning?
Oct 26, 2009 | Irons
Sunbeam iron won't power up.
I bought a new replacement iron at Sears for $17.99. It is not worth fixing my old one .
Jun 17, 2009 | Sunbeam Irons
Light comes on, but iron will not heat up
oliso iron turns on when plugged in green light flashes but iron will not heat up
Feb 13, 2009 | Irons
Autoshut off red light keeps flashing
I had the same problem and eventually removed the tilt sensor. This is the molded board that you see when you open the back of the iron. By removing it, you will also loose the timer off function. The thermostat will still be operational.
Oct 14, 2008 | Braun SI6285 Iron
Premature shutting off
the only thing you can do is change out the motion sensor which is 1n the machine or disable it
Apr 21, 2008 | Irons
Irons Logo
32 people viewed this question
Top Irons Experts
Are you an Iron Expert? Answer questions, earn points and help others
