Question about Fellowes Office Equipment & Supplies
How to clean Sensors in Fellowes C11M Paper Shreder
5 Suggested Answers
SOURCE: I have a SX102M paper shreder that wont shrede
It's the paper sensing microswitch. Wire a small toggle switch and drill a small hole for it on the far right side of the top housing. Just remember that the switch has to be turned off when you are finished shredding or the motor will keep running till it burns out
Posted on Feb 25, 2009
JayBlair
  • 328 Answers
SOURCE: paper jam. Ready lite comes on but shreder will not start shreding
Common problem with paper shreds blocking the sensors on top and bottom of cutter asm. You may have to remove the top of unit to properly clean. When removing top, be very careful with the short ribbon cable. Lift top slowly and then reach under and disconnect from main board. Once top is off, you can cycle motor by hand and try to remove shreds with needle nose pliers. Of course, disconnect power first.
Posted on May 15, 2009
sonicboomele
  • 1557 Answers
SOURCE: I have a brand new P58Cs and it runs continuously
most of these shredders have tiny clip sensors that have little levers that are depressed when paper is fed into the teeth if the sensors get jammed closed then the shredder rollers will keep going try cleaning the rollers free of all loose bits of paper and you should be right
take care
Posted on Jul 22, 2010
SOURCE: OUR FELLOWES CROSS CUT SHREDDER
It worked!!! Now my Fellowes DM8C is working like a brand new shredder. At first, I cleaned the sensors several times and it did not work. Then, I disassembled the shredder head, removed the two sensors, cleaned them with a wet cotton towell, put them back in place, reassembled the shredder head and voilà! My shredder automatically starts when the sensors detect paper and stops a few seconds after the paper has passed through. GLEOSA
Posted on Jul 02, 2011
OUR FELLOWES CROSS CUT SHREDDER WILL KEEP ON RUNNING AFTER THE PAPER HAS BEEN SHREDDED. ARE THERE SENSORS THAT COULD POSSIBLY BE COVERED IN PAPER DUST?
If you look into the slot you feed the paper into, you should see a two little bumps that are facing each other in the center of the slot. These are the sensors that tell the unit to turn on/off. You can try cleaning them with a paper towel or long q-tip. If this does not fix it, then the sensors will have to be replaced. Most Fellowes machines have a 3-year warranty, you can call Fellowes at 1-800-955-0959 to see if yours is under warranty.
May 25, 2011 | Fellowes Office Equipment & Supplies
We have a CR220 fellowes shredder. It will shred 1/2 of a peice of paper, then the basket full light comes on even tho the basket is empty.
you can try cleaning the "bin- full" sensors. they are located on the inside of cabinet, on the bottom of the shredder "head". one will be to the left side of basket and one to the right. they kind of look like little glass eyes mounted inside of black rubber casings. paper dust on these will do this sometimes. if that doesn't do it then it sounds like your "bin-full" sensors are bad. a known problem with these shredders. fellowes has come out with modified sensors. if it was purchased within 2 years, it should still be under warranty.
hth,
razors
Mar 10, 2011 | Fellowes Office Equipment & Supplies
I have a brand new P58Cs and it runs continuously instead of cutting off after paper has passed through - The Fellowes website says to clean the sensors (already, after just one day??) but because of the...
take care
Jul 22, 2010 | Fellowes Office Equipment & Supplies
Runs continuously when in the on position.
there is paper jammed in front of the sensor. it was likely caused by feeding too much paper into the shedder at one time and now a chunk of shedded paper bits it blocking the sensor from seeing that the shedder is clear
Dec 18, 2009 | Fellowes DM8C Cross-Cut Shredder
My fellowes shredder won't stop after shreding paper
Clean the sensors upper and lower with a cotton swab and rubbing alcohol.
Jul 13, 2009 | Fellowes Office Equipment & Supplies
Fellowes Paper Shredder P70CM paper jam
Clean the upper and lower sensors with a cotton swab moistened with rubbing alcohol.
Jun 21, 2009 | Fellowes P70CM Shredder
Paper jam. Ready lite comes on but shreder will not start shreding
May 15, 2009 | Tech Solution TS-4500 Shredder
Shredder does not turn off
You need to clean the paper feed sensors. You can call Fellowes customer service at 1-800-945-4545
Feb 11, 2008 | Fellowes Powershred P-55C Light-Duty...
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
