Question about Mopar Performance Dodge van/wagon - full size belt, lap buckle half. 1992-93-94, 1994
Where is wiper relay on a 1996 BMW 740 ?
Relay location
How do I find the wiper relay on my 1997 BMW 740il. I ordered a factory wiper relay .its Tan in color, I cant find it. I need help from a professional can you help me.
It's located inside the power distribution panel.
The power distribution panel on your car is located under the hood in the engine compartment. It is located on the right passenger side closest to the firewall.
When you open the cover to the PDP, you'll see a series of blade type fuses in the front compartment and a bunch of wire harnesses in the back- that's where you'll find the tan colored relay you need to replace.
I have attached a youtube video for you to watch because it appears that the most common cause of this relay failure is due to water build up in the PDP compartment which is causing serious wiring deterioration and rusting- not only to the wiper relay but to the other relay components in that block.
So should you be experiencing the same problem when you open the power distribution panel, you'll know what to do.
http://youtu.be/PoX3w-D-kG0
Feb 28, 2015 | 1997 BMW 740il
Where to locate the wiper relay on 96 eagle vision
The car has two wiper relays, intermittent and Hi/LO relay, both are located in the power distribution box in the engine compartment.
Nov 02, 2014 | 1996 Eagle Vision
1997 bmw 328i Wiper Motor Relay Location
There is no wiper motor relay as such but there is a wiper/washer module. Its location can be found by tracing the BRN/GRN/YEL, BLK/WHT/YEL, and BLK/RED/YEL wires back from the motor.
Jun 21, 2014 | Mopar Performance Dodge van/wagon - full...
1996 520 touring front wipers not turning off,changed relay but still the same
there is a stop mech in the wiper motor or cog on shaft
Nov 03, 2013 | 1996 BMW 318
Location of air condition relay? 1998'bmw 528i
From memory it's built into the climate control panel and there is no external relay.
May 28, 2012 | 1996 BMW 528i
Bmw 5 series wipers not working properly when they do they just stay up and do not go down. and sometimes dont work at all.
I HAD THE SAME PROBLEM, AND IT TURNED OUT TO BE THE WIPER RELAY , LOCATED UNDER THE FRONT WINDSHEILD IN ENGINE BAY, REPLACE THE RELAY.
Feb 28, 2011 | 1998 BMW 5 Series
Front wiper relay in 1988 VOLVO 740 GLE
sounds more like dodgy switch
Jul 17, 2009 | 1988 Volvo 740
My wipers stop in the up position
your actually talking about the single wipe mode arnt you?......... this is not a wiper motor issue. Its actually the relay, the relay is located behind the fuse box, behind the glove box. its grey. Happy hunting.
Jul 12, 2009 | 2003 BMW 325
BMW (E39)520SE 08/2001 Auto Touring. Rear wiper/washer has failed. I have located a replacement wiper motor but understand that 'the relay' is also prone to failure. I've still got the fuses to...
after making sure your fuses are ok, go in the trunk and behind the access cover where the battery is located. above the battery should be a fuse panel, which may be hidden under the insulation trim, there should be some fuses and relays there. the relay closest to the rear of the car is probably the relay you are looking for. you can try swapping it with another relay in the panel if the relays are the same. bmw always puts a part number on their relays. i would start with checking the fuses and relay first.
Mar 17, 2009 | 2001 BMW 5 Series
BMW 1996 3 Series Touring Wipers will not stop/cancel
try looking for the relay box and listen to each relay the one that clicks when the wipers are on
is the one to take out and replace it with a new one or second-hand one but make sure to turn off the car first .
Mar 01, 2009 | 1996 BMW 318
Mopar Performance Dodge van/wagon - full size belt, lap buckle half. 1992-93-94, 1994 Logo
Top Mopar Performance Clothing Accessories Experts
Da Doc
ray gallant
Are you a Mopar Performance Clothing Accessory Expert? Answer questions, earn points and help others
