Question about Total Gym Gazelle Edge Exercise System
I need to replace rear swing cables on my Gazelle
Need gazelle edge spare parts
Fixya does not sell gazelle edge spare parts.
Sep 11, 2017 | Cars & Trucks
I need a set of swing cables for a gazelle freestyle evolution
This is the Cars & Trucks forum. Post your question in the appropriate forum or use a search engine to find the answer yourself.
Jan 28, 2017 | Cars & Trucks
Where can i get new brushes for 24volt motor on a landlex gazelle s420
most any appliance repair shop or auto electrician will have generic brushes that can be trimmed to fit the holder
take a brush to show as an example
Sep 17, 2016 | Health & Beauty
Need prices for parts to gazelle freestyle elite
Try to contact their Fitness Quest customer support for the prices of the gazelle freestyle. Their number is 1-800-321-9236. You can order and pay for replacement parts with a credit card over the phone. The customer service center hours are Monday through Friday, excluding holidays, 8:30 a.m. to 6 p.m., Eastern Time. Have the model name of your Gazelle Glider, as well as information about the problem and the part that is broken.
Apr 23, 2016 | Baby Gear
Parts for gazelle edge
Rock Auto has some on sale .
Jan 23, 2013 | Cars & Trucks
Tony little gazelle freestyle elite replacement parts
I found something on amazon, here Amazon com gazelle freestyle parts. I hope this was helpful. cheers
Jul 18, 2012 | Exercise & Fitness
WHERE CAN I GET A MANUAL FOR THE GAZELLE FREESTYLE
On these units trace the wire going to the frame there is a sensor and on the movable frame their should be a magnet check the proximity of the sensor to the magnet ( should be about 1/8" clearance ). Now if you have the same problem, then you can test this sensor by using a multi meter on continuity setting follow the black connector to the upper board disconnect it and place leads on to connector MAKE SURE you have a good connection when testing. Have someone get on the unit and start using it, the back and forth action should open and close sensor circuit if not replace sensor if operating the the upper console is defective and that needs replacing . Call them @ 800-780-6744 they should be able to help with parts and a manual.
h
May 26, 2010 | Exercise & Fitness
Need to replace rear brake discs and pads
YOU NEED TO REMOVE THE REAR WHEELS.REMOVE PARKING BRAKE CABLE CLIP FROM CALIPER DISCONNECT PARKING BRAKE CABLE.HOLD THE GUIDE PIN WITH A BACK UP WRENCH AND REMOVE UPPER MOUNTING BOLT FROM THE BRAKE CALIPER.SWING THE CALIPER DOWNWARD AND REMOVE THE BRAKE PADS.TO INSTALL NEW PADS.YOU HAVE TO RETRACT PISTON INTO THE HOUSING BY ROTATING THE PISTON CLOCKWISE.PUT EVERYTHING BACK VISA VERSA.
Feb 24, 2010 | 2002 Jaguar X-Type
Tony Little Gazelle Platinum plus
Broke rear swing cable. Need replacement parts. Does anyone know of any web site where I can order only replacement parts?
Oct 26, 2009 | Exercise & Fitness
Total Gym Gazelle Edge Exercise System Logo
74 people viewed this question
Top Total Gym Exercise & Fitness Experts
Rick Massengale
Level 1 Expert
Tom Chichester
Are you a Total Gym Exercise and Fitnes Expert? Answer questions, earn points and help others
