Question about HP DeskJet 3520 InkJet Printer
HOW TO RESET HP 3520 PRINTER - HP DeskJet 3520 InkJet Printer
3 Suggested Answers
  • 11 Answers
SOURCE: flashing on/off light on hp deskjet 3520 printer
Introduction The printer lights indicate the printer status. These lights can be on, off, or blinking (flashing), depending on the status of the printer. The sections below describe the most common combinations of blinking lights, how to fix the issue, and how the issue is caused. NOTE: The light patterns included in this document are described as blinking or flashing lights. For the purpose of this document, "flashing" means the same as "blinking." Blinking lights Printer lights can can blink for more than one reason, so the solution can vary. These solutions need not be performed in a specific order, but solutions for the most common issues are presented first. Blinking lights are often accompanied by an error message on the computer screen, which might help determine the solution. Issue: Power light is blinking
c00374282.gif Solution
Close the cover.
Cause
Printer cover is open. Solution
Insert appropriate media in the In tray.
Cause
The printer is out of paper. Solution
  • Change the printer's print mode setting.
  • Change the printer's paper type selection.
  • Use a different brand of label media.
Cause
The printer has difficulty picking up label media. Solution
Follow each of these steps until the problem is resolved:
  1. Remove the paper from both paper trays.
  2. Press the power button once. Wait a moment for the paper jam to clear.
  3. If printing labels, verify that a label did not become detached while passing through the printer. If the paper jam was not resolved, continue on to the next steps.
  4. Remove the rear access door.
  5. Remove the paper jam through the opening at the back of the printer.
  6. Replace the rear access door.
  7. Reload the paper into the paper In tray.
  8. Print the document.
Cause
There is a paper jam. Solution
  1. Remove and then reinsert the print cartridge(s) into the printer.
  2. Clean the print cartridges automatically using the Clean Cartridges option in the Printer Assistant.
  3. Manually clean the print cartridges and print cartridge cradles:
    • Open the printer cover and wait until the carriage moves to the center.
    • Press the Power button to turn off the printer.
    • Disconnect power cord from the back of the printer.
    • Remove the print cartridges and place them on a piece of paper with the nozzle plate facing up.
    • Lightly moisten a cotton swab with distilled water.
    • Clean the face and edges of the print cartridges with the swab. Do not touch the print cartridge ink nozzles or copper contacts.
    • Wipe the underside of the print cartridge cradle walls using a clean, moistened swab.
    • Reinsert the print cartridges.
    • Close the printer cover.
    • Connect the power cord to the back of the printer.
    • Press the Power button to turn on the printer.
  4. Calibrate the print cartridges.
  5. If the light is still flashing, replace the print cartridges.
Cause
There is a problem with a print cartridge. Solution
  1. Print a printer self-test by holding the power button down with a pencil and opening and closing the top cover four times.
  2. Check the nozzle self-test pattern in the self-test print out. If one or more of the solid rectangular areas are missing, an electrical contact problem may be present.
  3. Remove and then reinsert the print cartridge(s) into the printer.
  4. Print the document.
  5. If the problem persists, follow the steps listed above for cleaning the print cartridges and print cartridge cradle.
  6. Try printing again. If the problem continues, replace the print cartridges.
Cause
The print cartridge has partial loss of electrical interface with the carriage connections.
Posted on Mar 04, 2009
omerboo
  • 424 Answers
SOURCE: Driver for HP Deskjet 3520
Alternative driver download link: HP Deskjet 3520 Color Inkjet Printer Driver
Posted on Feb 02, 2010
Clean printhead and breather hoses hp 3520
try to reset the the black printhead , and clean the it
Mar 23, 2013 | HP DeskJet 3520 InkJet Printer
How do ou update the driver on an hp deskjet 3520 printer?
Log on to HP.COM. Go to Support and download the driver for your printer. Go to your download folder and run the file you just downloaded.
Jul 02, 2012 | HP DeskJet 3520 InkJet Printer
How do you install the hp3520, if i lost the cd
How do you install the hp3520, if i lost the cd check the vids
Nov 19, 2009 | HP DeskJet 3520 InkJet Printer
Installing a printer without software disk
If you have the internet when you install the printer windows should automatically look for updates on it...if not you can always good to hp.com and find the drivers for it...or google search hp deskjet 3520 drivers.
Sep 02, 2009 | HP DeskJet 3520 InkJet Printer
try to click at this link....use windows 2000
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=305968&lang=en&
May 26, 2009 | HP DeskJet 3520 InkJet Printer
hello..
just follow this link
ftp://ftp.hp.com/pub/softlib/software2/COL4001/dj-13176-3/3500_enu_win2k_xpinfu.exe
copy and paste to your internet explorer
Nov 11, 2008 | HP DeskJet 3520 InkJet Printer
Printer problem
That could be a signal of a problem. Reset the printer and make sure you get an OK light (usually solid green)
is the printer connected directly to the PC or is it a network printer?
Jun 13, 2008 | HP StorageWorks SAN Switch 4/32B Power...
HP DeskJet 3520 InkJet Printer Logo
81 people viewed this question
Seeker5211
Seeker5211
