Question about Pioneer FH-P5000MP CD / Cassette Player
Searching for wiring harness sequence.
I am tying to find the wiring sequence for a Pioneer FH-P5000mp CD/Cassette unit. It has a 16 pin wire harness, consisting of two rows of eight. I already downloaded the installation manual, which explains what each wire color goes to. What I want to know is what plugs in to each pin. Can someone help provide this information?
Joe1968
  • joe1968 Nov 06, 2007
    Thank you very much Mixmaster.
  • Anonymous Mar 30, 2014
    I need 16 pin wire diagram for kdc148 so I can jam
  • 626 Answers
Found a service manual here, but you have to pay for it (only 4.95 USD). It has the wiring block specs you are looking for.
http://www.smpcshop.com/FH-P5000MP-p-3345.html
Best of Luck.
Posted on Nov 04, 2007
Im in need of a wire harness and dont know where to get one its for a pioneery fh-p5000mp
Fixya is unable to suggest sources of Pioneer wiring harnesses other than Pioneer.
May 11, 2018 | Car Audio & Video
Will the pioneer deh p3100ub fit a 92 civic?
Yes, it should slip right in, but I recommend you buy the adapter for the wiring harness. Look here for details and instructions are pasted below:
http://www.crutchfield.com/p_130DEH1700/Pioneer-DEH-1700.html?tp=5684
1992-95 Models
See Figure 4
Removing the radio will require removal of the front part of the center console.
The original equipment radio has a coded theft protection circuit. Before beginning removal, be sure to know the code for re-installation. The code is erased whenever the battery is disconnected or the No. 32 (7.5A) fuse from the under hood fuse/relay box is removed. When power is re-connected, the word "CODE" will be displayed and will require entry of the 5-digit code for that particular unit.
WARNING All SRS wire harnesses are covered with a yellow insulation. Read the SRS precautions found in this section and install the short connectors as described.
  1. Disable the SRS system as described in this section.
  2. Remove the center instrument panel by removing the four philips screws on the top and sides.
  3. Disconnect the 4-pin connector from the cigarette lighter.
  4. Remove the two screws, then disconnect the 16-pin connector and the antenna lead.
  5. Carefully pull the radio/cassette player out.
To Install:
  1. Plug in the 16 pin connector and install the two retaining screws.
  2. Plug in the antenna lead, the cigarette lighter and carefully install the unit.
  3. Install the center instrument panel. Re-connect power to the car, and enter the 5-digit theft protection code for the radio/cassette player.
  4. Enable the SRS system.
Aug 14, 2011 | Pioneer DEH-1700 CD Player
Problems with Metra METRA PR01-0001 PIONEER 16-PIN UNIVERSAL WIRING HARNESS?which wires are which
I don't know what pins are what on the METRA harness, but the wires coming from the back of the Pioneer unit should be:
black ground
red accessory (KEY)
yellow memory constant power,
blue is remote,
orange is for the dimmer,
green with black is left rear neg.and green is positive,
violet black is right rear negative and violet is positive,
white is left front positive and white with black is negative,
gray black is right front negative and gray is positive.
If you don't have the pioneer harness (and so these wire colors dont' mean much to you) just message back here, and I'll map those wire colors to pin positions on the back of the unit.
May 21, 2009 | Pioneer DEH-1500 CD Player
Wiring diagram
Try here:
http://cgi.ebay.com/Pioneer-FH-5071ZM-Car-Tuner-CD-Player-Service-Manual_W0QQitemZ290221309136QQihZ019QQcategoryZ39996QQcmdZViewItemQQ_trksidZp1638Q2em118Q2el1247
Dec 29, 2008 | Car Audio & Video
Can someone tell me how to set the stations? Thanks!
owners manual.
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/128163985FH-P5000MP%20OPERATION%20MANUAL.pdf
Jun 05, 2007 | Pioneer FH-P5000MP CD / Cassette Player
Pioneer FH-P5000MP CD / Cassette Player Logo
389 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
