Question about HP H2F48AA-6PK - 6-Pack HP X4000 Link-5 Wireless 3-Button Laser Mouse w
Why is my mouse not working and the light is flashing ?
H2f48aa
Logik wireless mouse
1. Make sure the mouse is fully charged. The underside should have a red flickering light if it is working properly. If not you need to change the batteries.
2. Plug the USB dongle into the computer. The blue light should light up and flash rapidly as you move the mouse around. If it still doesn't work you need to re-sync the mouse with the dongle.
Turn the mouse off and back on again. Hold it near the USB dongle.
Push the blue button on the dongle. It should flash steadily. Push the reset button on the bottom of the mouse. The blue light on the dongle should start flashing rapidly and your mouse should now work.
Jul 30, 2014 | Case Logic EW-609 3-Button Wireless...
Lights are on but mouse doesn,t work.Inland wireless mouse and keybord. Keyboard works great.
Check with fresh batteries.. Did you sync the mouse with transciever? Push tiny button on transceiver, (maybe hold for few seconds) light flashes quickly.. then push tiny button under the mouse, light stops flashing. Try few times, maybe otherway round. If still not work consider defective.
Dec 11, 2010 | Inland u-Touch wireless Keyboard/Optical...
I just bought a Dynex Wireless optical mouse. My laptop said that it was ready to use but it still is not working. It's on and the batteries are new. I also tried other new batteries. It's still not...
Try pressing Connect on the receiver, then when the light is flashing, press Connect on the mouse. The light should stop flashing and the mouse should be usable. If it's not, check that you have the Dynex mouse driver installed.
Jul 15, 2010 | Microsoft Wireless Optical Mouse
Wireless mouse stopped working. green light works
This can happen when the battery's are starting to die. Replace the batteries and then test the device again.
Oct 09, 2009 | HP Wireless Optical Mouse
New mouse/batteries won't connect with receiver. Light on receiver flashed for about a minute after pressing the connect button on it, then the light stays on, but the mouse doesn't seem to work. Should...
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Sep 05, 2009 | Microsoft Wireless Laser Mouse 5000
Red light flashing top of logitech wireless mouse??? has fresh batteries---still flashing. otherwise, still works fine as usual on toshiba laptop, vista. what's going on??? thanks for any help!!!
The flashing light could be a reflection from the LED and mirror or laser on the bottom of the mouse. I had this similar problem and it drove me nuts until I happened to hold it up to a mirror and noticed the flashing was in sync bot top and bottom of the mouse.
Jun 10, 2009 | Logitech Cordless Mouse
MOUSE LIGHT FLASHES red and green; does not function
The flashing red and green lights means that now it's in discoverable mode and it's time to add it as a bluetooth device.
Mar 14, 2009 | Microsoft Wireless Laser Mouse 5000
The receiver will not stay on
have you got the button on the mouse bottom you must press when you have pressed the one on the receiver to have them connect with each other and every time you change the battries in mouse you must repeat this proceedure.
Nov 20, 2008 | Logitech Cordless Mouse
Flahsing Red Light
Now what you have to do is look for a reset button on your mouse and your wireless mouse signal receiver.
When the receiver and mouse both are on press the reset button on both of them one by one.
This should solve the problem.
Jul 16, 2008 | Logitech MX 700 Mouse
HP H2F48AA-6PK - 6-Pack HP X4000 Link-5 Wireless 3-Button Laser Mouse w Logo
41 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
