Question about Dell Inspiron 1525 Laptop
My Dell Inspiron 1525 has been connected to wireless networks in the area and working perfectly. Suddenly this morning the connection was disabled and now it tells me there are no networks available. However I am using an old Samsung desktop just two feet away and it´s connected to the same wireless network and working perfectly. How can that be? Any ideas?
  • Dell Master
  • 32,281 Answers
Sometimes when you boot up the wireless card does not get an IP address from the wireless router. If you have an wireless icon on the task bar with a red X on it then right click on this icon and click Repair, if not go to the Control Panel - Network Connections - right click on the wireless connection and Repair. This will force the wireless router to issue the wireless card with new IP address.
If this doesn't work check the Device Manager to see if the wireless card is enabled and functioning, if not reinstall the wireless driver and configure it to match the wireless router settings.
Posted on Jun 24, 2009
Dell inspiron 1525 says limited or no connectivity
Could be an issue with the router. Try resetting the router.
Mar 08, 2017 | Dell Inspiron 1525 Laptop
Is my Dell Inspiron 580 desktop capable of wireless internet?
to no if you have wireless connection go control panel on your computer then find network and internet look for wireless connection click on it
Sep 22, 2012 | Dell Inspiron 1525 Laptop
Cannot access internet or no network connection.
Dell Inspiron 1525: Unable to Connect Wireless Network
setting up the right option for wireless network connection at Dell 1525. Here's the following:
  1. Go to Control panel
  2. Select Windows Security Center
  3. Select Windows Firewall
  4. Click on Change settings
  5. Here you might see User Account Control will ask for your permission to continue, simply grant it.
  6. Click on the Exception tab at the middle
  7. Scroll down to Wireless Portable Devices and check the box next
  8. Click Apply, then hit OK
  9. After close the program now you can try to connect again and watch the result.
With assumption you're already make the wireless enable in BIOS setting. In the device manager you should see what the type of wireless wlan card you used and make sure it's already turned on via your switch on your laptop. If it was, then you need to find out the right wireless device driver for Dell Inspiron 1525. Here's the following:
  1. Visit Dell Support site and open the Network tab in the table.
  2. Find your wireless device and download the driver for it.
  3. Aim to a folder on your computer or any external drive if you have it.
At the Inspiron 1525 laptop
  1. go to start
  2. Right click at My Computer
  3. Click Properties
  4. Click Device Manager and Network Adapter .Here you should see a WLAN Mini-Card or might you only see "Unknown Device".
  5. Right Click on it and go to properties to select the Update Driver. Now you should browse the folder to select the driver you're already download at the first step.
NOTE:
Just follow the instruction appears completely. After installation the wireless wlan driver at Dell Inspiron 1525 finish, then reboot the machine and know your wireless connection should be works properly.
Jun 07, 2011 | Dell Inspiron 1525 Laptop
Dell Inspiron 1525 - No wired or wireless network
I suspect the Vodafone wireless adapter software is controlling the Dell wireless adapter. Start> in the search box type CMD
  • Reset WINSOCK by typing netsh winsock reset catalog
  • Reset IPv4 TCP/IP by typing netsh int ipv4 reset reset.log
  • Reset IPv6 TCP/IP by typing netsh int ipv6 reset reset.log
Next make sure the vodafone applcation is not running
Check you are getting a ip from the router by Start> in the search box type CMD
  • ipconfig /all
This will return a list of numbers - what you are looking for is a IP number for your wireless connection
A very useful tool to use for wireless issues is xirrus, http://www.xirrus.com/library/wifitools.php If you can copy the program onto the PC thats not working and install and run, this test if your adapter is working and also will display all the networks broadcasting in your area. Which will prove the hardware works.
Apr 03, 2010 | Dell Inspiron 1525 Laptop
Dell inspiron. "unidentified network" problem
Try disabling firewall software that must be preventing access to network. disable and reenable the lan card might also help
Feb 01, 2010 | Dell Inspiron 1501 Notebook
Dell Inspiron 1525 not connecting wirelessly to Sky broadband
If your wireless router is configured with SSID, encryption, MAC address filtering (if enabled) etc. then the Dell wireless card needs to be configured with these settings to allow it to communicate with the wireless router.
Check the settings on your PC's wireless settings, and configure the Dell the same way.
Sep 08, 2009 | Dell Inspiron 1501 Notebook
My wireless will not work
Check your Settings in the Control Panel (Network Connections, as well as Hardware (to be sure the device is enabled!)
Also Check Power Settings in the Control Panel.
Go to Dell.com, Download the Drivers and Software (Everything Relative to Networking)
Reinstall them,
Apr 21, 2009 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Good morning this is carlos reyes I have bouht a gateway loptop last month and the network wireless is not working so please I need your help im in miami florida
open control panel
network connections
if you see the connection there right click then if you see enable click it if not click repair
if you have no connection in there let me
do you see the icon in task bar for wireless
Jan 14, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 Laptop Logo
232 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
