Question about Xerox WorkCentre 3210 - Multifunction - B/W - laser - copying
Xerox 3210 has streaks on scanned copies only
Scanned copies have streaks on left side. Three different vertical rows of streaks in varying width. Streaks are not shown on plan copies.
  • 208 Answers
SOURCE: Streaking Printer
On that product, it is just as likely that a single color drum is bad. Not the developer. That is a more likely problem then the developer.
Posted on Dec 20, 2007
  • 2072 Answers
SOURCE: Xerox Phaser 8400 Streaking
You can go into the trouble shooting menu and do the "eliminate Light stripes" procedure a few times.
Then you can do Jet substitution from the same menu.
If that does not work then most likely you need a new print head.
If you have used non xerox ink sticks that is your most likely cause of the problem. cheaper is not always better
Posted on May 30, 2008
copiersplusw
  • 136 Answers
SOURCE: Dark streaks on copies from Xerox XC356 copier.
Replace the Drum Unit, Do you know how to rebuilt this unit, if not you can get an after market product, The Drum unit release is in the Middle of the Copiers you will see a door , open the door, then ONLY , and i do mean ONLY, touch the "Green" release lever for the drum take it out and replace it or rebuilt it f you now how, if this does solve it, which i am certain it will but, if it doesn't something is wrong with the fusing unit and needs to be dismantled, wish i could give you our contact info however, been informed not too so sorry. rules of fixya.com
Posted on Mar 05, 2009
  • 990 Answers
SOURCE: I have a Xerox Copier XC1045. Our copies are
Hello sir; That problem not caused by toner, is by drum cartridge, replace it will take care your problem.
Posted on Apr 23, 2009
Arius
  • 446 Answers
SOURCE: Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Posted on Jul 28, 2009
Xerox is printing pages with a red line down the left side
Streak in only one color:
Check the condition of the print cartridge, and replace as necessary.
Verify that the print cartridges (C/M/Y/K) are genuine Xerox cartridges,
and replace if necessary.
http://download.support.xerox.com/pub/docs/6180MFP/userdocs/any-os/en/user_guide_en.pdf
May 05, 2014 | Xerox 6180MFP/D Printer
Black vertical lines come and go for scans to computer and copies
I suspect the Document Feeder is not aligned properly and light is leaking in. You will need to have a technician in to check the alignment of the scanner to see if it needs to be readjusted. random black lines on edges usually indicate light leaking into the scan area.
Aug 28, 2017 | Xerox WorkCentre 3220
Images have a streak of color in the middle
The problem you describe sounds like moire.
Try scanning the image at different resolutions until the effect disappears.
Dec 12, 2013 | Kodak i1420 Pass-Through Scanner
Barcode scanner won't read printed labels
1. The printhead in your printer might be scratched (evidenced by thin white streaks through your print). This is common, and the most likely cause. Printhead must be replaced.
2. Material might be stuck on your printhead (usually evidenced by wide white streak vertically through print). Printing surface of printhead can be cleaned with rubbing alcohol and cotton ball.
3. The ribbon might be wrinkling due to uneven tension, producing intermittent diagonal streaks in your print. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment and/or proper media loading solves ribbon wrinkles.
4. Poor pressure and/or printhead alignment. Evidenced by grainy, light or no print on one side or the other of the media. This is somewhat common, but doesn't fit your description as well as 1 & 2 above. Mechanical adjustment solves printhead pressure and alignment issues.
Dec 11, 2012 | Datamax E-Class E-4203 Label Printer
My Canon MF4150 multifunction device started displaying streaks (or black vertical lines) on pages scanned via the ADF. These streaks appear when scanning from Windows 7 (64bit home premium) as well as...
Hello I just figuered out this problem. When the paper is feed thru the ADF ( Automatic Document Feeder ) there is a plastic piece with a plastic film. Check to see if #1 that plastic film is clean and #2 That the Film is not bent and created a crease which is the line that shows when try to print or scan using the ADF. Hope this helps
Dec 28, 2010 | Canon imageCLASS MF4150 All-In-One Laser...
Getting a black strip in copy mode on X6575 lexmark printer. No line in print or test mode
Most likely a page was scanned with 'white out' (Liquid Paper), still wet on the page. As the page feeds over the scanner, (a narrow strip of glass that runs across the width of the page along the feed path) the wet liquid paper comes off on the glass as a thin line and dries. Thereafter, when copying, the scanner light does not go through the liquid paper streak and the result when printed is a thin vertical line that runs the full length of the page.
If this is your problem: follow the path that the paper travels when sending a fax or making a copy, until you find the scanner (narrow glass strip). Take a clean, soft cloth and a small amount of methylated spirit (or white spirit) and remove the now dried Liquid Paper from the glass. Clean the whole strip ensuring that the glass is left clean and dry.
Mar 16, 2010 | Lexmark X6100 Flatbed Scanner
Hp Photosmart c5280 1/ 2inch thick black line
There is something on your scanner glass. Clean the glass with glass cleaner. If this happens when using the automatic document feeder, open the top side cover where the paper feeds into. There is a narrow glass strip there. Clean that as well.
If this fails, the scanner head has a bad sector on the CCD and will need to be replaced. You will probably find that it will be cheaper to replace the printer entirely if that is the case.
Jun 22, 2009 | HP LaserJet 3055 All-In-One Printer
Vertical Light Streaks on text documents, both single and duplex
Clean the glass thoroughly using Isopropyl alcohol. Dont use solvents. Check if there is any scratch on the glass. Repeated scanning with stapler pins can scratch the glass. If it is scratched, you may need to chage it.
S. Mohan, India
Mar 11, 2009 | Panasonic KV S2025C Path-Through Scanner
Black line down the middle of scanned documents.
Try leaving the cover open and run a test scan, once with a fresh sheet as the item to be scanned and then a second time without anything on the table.  You may see what is blocking the light source or possibly a defect in it.
Scanning is done left-right, left-right across the width of the page and the vertical stripe indicates that the blockage is present during each scanned line.
In servicing copiers and multifunction machines, I have found a number of curious contaminents, one of the most annoying was a moth, still alive, that would randomly sit on the lamp, causing some pages to come out OK, others not.
If your copies and printouts are coming out fine, then only the scanner can be at fault.
Jan 13, 2009 | HP Photosmart 2575 All-In-One InkJet...
Xerox WorkCentre 3210 - Multifunction  - B/W - laser - copying  Logo
23 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
