Question about Samsung RF323TEDBSR French Door Refrigerator RF323TEDBSR
Our RF323 side by side is making a very loud sound that is not normal.it's coming from the ice maker. sounds as if something that should turn is not turning
SOURCE: Samsung Side by Side Refrigerator RS2556SH - Making loud noise
Hi, had the same problem with my RS21DCNS engineer came and made a modification to drain hole (made the hole bigger!) this allows for a little more ice to form without causing the horrid noise. A new backplate was ordered as all new models have a larger hole in the backplate already. It only takes a few mins and it under guarantee if you bought less than 2 yrs ago, but you will have to empty fridge side to allow them to get to inside at the back. Good luck.
Posted on Oct 19, 2006
Bgillespie
  • 89 Answers
SOURCE: Ice Maker problem
There is a water valve that "feeds" the ice maker. When the Ice maker makes ice it sends a signal to the water valve, it opens for approx. 7 seconds and fills ice tray with water. Another cause of no water in IM could be frozen water line where it feeds the IM.
Posted on Mar 21, 2008
  • 22 Answers
SOURCE: refrigerator
the fan behind the ice maker is iced up poss fault defrost heater gone try total defrost faor a list 36 hrs restart it noise come back then you need to repace the defrost heater hope this helps
Posted on Nov 13, 2008
woodchuck789
  • 4059 Answers
SOURCE: our Samsung ice maker stopped working
Sound like the problem may be a gear broken or damaged in the module which appears to be replaceable in your model. If you can dissasemble it enough to inspect the gears you may can replace the part instead of the entire ice maker. It looks like the motor may be in part 18 on this diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=RS2630WW&productCategoryId=0165000&brandId=1482&modelName=SAMSUNG-REFRIGERATION&diagramPageId=00009&componentDescription=ICE%20MAKER&documentId=M0612092&backToLink=Return%20to%20Sub%20Components%20list
Posted on Sep 09, 2009
  • 1796 Answers
SOURCE: tHE ICE MAKER DOES NOT
Hi!
In case ice doesn't come out, pull out the ice bucket and press test button located on the right side of ice maker (if your model supports it.) `
If the screw auger is stuck, the Ice Maker needs to be replaced as a unit. Unfortunately, the refrigerator can only use ice makers which are made by Samsung Electronics, which means that you have to buy it from them and the ice-maker can only be installed by Samsung or its service agent.
If you need your Ice Maker working, you have to call Samsung at 1-800-SAMSUNG to schedule a service visit.
Good luck and Merry Christmas!!
A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Posted on Dec 18, 2010
GE Side by Side Refrig - loud noise behind the ice maker section Model PSS25SGMB BS
it sounds like the evaporator fan blade is hitting some ice that has built up around the blades i have seen this happen a lot on g.e. SxS lately,if you can remove the ice maker and dispenser you can see the fan blade,if you dont want to do this then shut down the refrigerator and leave freezer door open and heat it carefully with a hairdrier to speed the process up to melt this ice then restart it and the noise should be gone
Aug 30, 2012 | GE PSS25SGNBS Side by Side Refrigerator
How do I stop the loud knocking noises coming from my refridgerator?
Pull the fridge away from the wall and inspect the compressor. Your description sounds like the compressor is hitting something. It is rubber mounted and usually can be pushed away from whatever it is hitting.You do not want to jamb something to stop the noise, as the compressor needs to move freely. Many compressors shake during start up and shutdown, and this is considered normal. Abnormal if the compressor hits something during this movement.
Feb 05, 2012 | Kenmore Refrigerators
I have a samsung side by side fridge and it is an RS285LA. For awhile now it has been making this buzzing sound from what sounds like to be coming from the back. This buzz sound is kinda loud cause I...
its the relay for the ice maker.. they are loud if the don't have water going threw them, you may want to shut off your ice maker. lift the arm to the up position. that turns off the ice maker.. if'n i was of hel vote YES .. jay the pool pump repair guy in longwood fl
Jul 05, 2011 | Refrigerators
Every half hour or so it sounds like a power surge...an electrical sound coming from the upper section of my French Door bottom freezer refrigerator. I do not have the water hooked up for ice making...and...
You have a problem with the control board program. If the ice making button is turned off, the ice maker should stop working completely but it sounds like it's wanting to make ice.
Jun 28, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
My refrigerator is six years old and for the past two months is making a loud buzzing noise. The frequency has increased over time. What could it be? It's an Amana side by side model ASD2626HE. Sounds like...
Saw your post a week late but the sound could be the start relay on compressor is weaking or if the water is turned off to ice maker the water control valve will try to fill ice maker if the ice make switch is left on and has no water. I will send a manual shortly, Sea Breeze
Apr 12, 2010 | Amana ASD2626HE Side by Side Refrigerator
Fan is making a loud noise by the ice maker. Sounds like it is rubing against something. It turns off when you open either door.
the fans normally stop when you open door fan probably has ice or frost in cover area remove food from area and check cover make sure not cracked and pushing in on fan also check and see that fan doesnt have plastic or foil stuck in it if ice dont have to defrost whole system clear food away and use a hair dryer on high directed on fan housing after a few min 8-10 check fan to see if ice or frost is gone
Sep 28, 2009 | LG LSC26905TT Side by Side Refrigerator
When the ice maker start to rotate there is very loud noise
Dripping sound.
During the defrost, water draining from the freezer section will drip into the pan by your compressor in the back and bottom of your refrigerator.
* Air rushing or blowing.
There is a fan in the freezer section and in some models in the back and bottom of your refrigerator to circulate air. This is a normal sound.
* Louder when starting or coming on.
Compressor operates at a higher pressure when first starting and noise should disappear as refrigerator continues to run and balance pressures.
* Popping, crackling, or sizzling about once a day.
If your model is self-defrosting, the defrost system utilizes a heater to remove the ice and frost from the freezer coil. During this period you will hear some expansion noises as heat is applied to the coil and you may experience some sizzling sounds as the melting water drips on the heater.
* Running water.
If you have an ice maker equipped model, the ice maker will call for water as the old batch of cubes is ejected and the ice maker starts to make more cubes. This will last for about 10 seconds and is normal.
* Vibrating or rattling noises
Sep 22, 2009 | Kenmore 25.1 cu. ft. Side-By-Side...
My GE side-by-side refrigerator is making a fairly loud ticking sound--about once every second-sounds like a big clock.
Water line to ice maker is frozen. Thaw out freezer. Put food in dry ice cooler and open freezer door, reset to OFF, and thaw freezer for four hours. It'll work after that.
May 23, 2009 | GE GSH22JFR Side by Side Refrigerator
Loud grinding noise
the gear may be wearing out.
Jul 31, 2008 | Frigidaire FRS26R4A Side by Side...
Open Questions:
Samsung RF323TEDBSR French Door Refrigerator RF323TEDBSR Logo
35 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
