Question about Frigidaire Microwave Ovens
Frigidare Gallery microwve will not operate because door will not close properly. I suspect the problem is in the door latch but can't seem to figure out how to take the door apart or even if possible. Any thoughts would be appreciated.
  • Official Brand Answer
  • 2,267 Answers
Good Morning Friend,
I understand that your Frigidaire Gallery microwave will not operate because the door will not close properly. Being that you are dealing with your microwave, I suggest contacting your local authorized technician. You do not want to try and take apart anything on your appliance, as you do not want to damage your appliance any more, or even worse, bring harm to yourself or your family. The technician will be able to diagnose your microwave and determine what is causing the door to not close properly and your appliance to not operate. Hope this is helpful.
-Best Regards-
WP
Posted on May 17, 2014
MicrowaveSvc
  • 9098 Answers
SOURCE: Goldstar Microwave MV1501w
Chances are the panels separate as shown in the photo I have attached below.
Panel replacement can usually be done without removing the door from the microwave.
In cases where it is felt that door removal is necessary, I recommend detaching the door from the hinges.
I generally do not advise removing the hinges from the microwave.
Whenever the hinges are removed, great care must be taken to put them back in the very same position they were in.
Failure to do so can cause microwave leakage, which can cause risk of skin burns, fire, and disruption nearby electronic devices.
By the way, where did you get the part? I'm trying to find a good Goldstar / LG source to recommend.
Posted on Oct 12, 2007
  • 126 Answers
SOURCE: door latch not functioning well
the door switch needs adjusting recommend a service tech to do this
Posted on Dec 22, 2007
  • 579 Answers
SOURCE: door will not latch
The door switch mechanism is broken. Microwave doors have a special arraingement of double switches to ensure it is not open during cooking. Because everything is made from plastic nowadays, stuff like this breaks easily. The switches are commona nd cheap but the mounting parts may not be.
Posted on Dec 31, 2007
Drummernick
  • 440 Answers
SOURCE: door latch on Emerson microwave oven
u will need new door asemble to relly fix it ok thx nick
Posted on Feb 10, 2008
  • 300 Answers
SOURCE: the latch on kenmore micro #721-62622200 is broken at bottom
In order to have the correct operation of the door latch mechanism and latch switches.
  1. Ensure correct adjustment of the Door and the Latch switches.
  2. Wipe off any dirt or grease around the door key where it touches the latch switched and door hooks with a soft cloth. Maintaining the smooth movement of the latch mechanism and switches etc�
  3. After replacement of the latch mechanism and/or Latch switches. Make sure to confirm a smooth operation of these parts are in order.
to view the exact diagram of how to do this manually just click the link http://www.applianceaid.com/micro8.html
Posted on Mar 07, 2009
Hi, My Bosch built in microwave won't start when I close the door unless I slam it. I suspect the switch. Think so? Can I get at ithe switch to replace without removing the whole unit from the
You will need to remove microwave to access casing, remove casing and check door micro-switch. The switch activator will need adjusting to enable door interlock to activate.
Sep 29, 2014 | Bosch 500 HMB5050 Microwave Oven
Frigidaire Mod: FGMV174KFB Door won't latch
I understand the door will not latch on your Frigidaire microwave, model# FGMV174KFB. Typically, this would not be a do it yourself repair, as you are working with your microwave, and there are no step by step repair instructions. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to fix the latch on your door with ease. Hope this is helpful.
-Best Regards-
WP
Jun 30, 2014 | Frigidaire Microwave Ovens
Door won't close
Check latch assembly and look for broken spring.
Nov 04, 2017 | Microwave Ovens
When I turn the micro on it does not turn nor heat unless I lift up on the door. Seems like door needs to be adjusted slightly
The problem you're seeing is nearly always a result of a safety switch that is not being activated by the door. The result is that the oven thinks the door is not shut fully. Pressing the door closed at the latch or downward from the top opposite of the hinges will usually provide enough movement to activate the switch. One of these methods is what I suspect you are doing to get it to work.
Inspect the prongs on the door. Make sure both are not damaged or broken in anyway. The size and shape are critical for effectively engaging the safety switch. Repair or replace parts as needed.
The switch itself is usually connected to the latch striker assembly or to a switch deeper inside the oven - to the latch itself - to detect its position. The striker assembly is partially visible behind the two openings of the door frame - the two prongs on the door push them down and when fully closed, keeps them down. Since accessing these parts requires disassembly of the oven by qualified persons to maintain safe operation - the oven should be service professionally to ensure that the door is closed completely before allowing the microwave to function.
Sep 03, 2013 | Dacor DCM24 Convection/Microwave Oven
My Kitchenaid khms155lss-2 has a problem latching completely. Once finally latched the microwave would start and then stop during the cooking time because the door became unlatched. I have to stand by the...
Ok.Agreed,latch is not cracked or worn out.But check the grip of latch.Open the door.The hold the latch in your hand and see,if its loose or tight.It should be tight.Press the latch towards down and move it left/right slowly --- slowly.And inspect the latch.It will move,there will be a moment but the position of the latch in the door frame should be tight.If you feel that latch is got very loose,then the door frame needs to be disassembled and latch assembly has to be repositioned and fitted.In most of the cases this latch breaks/cracks and it needs replacement.But in your case,its different,you mentioned that if you keep your oven door pressed then latch remains closed..So if latch is broken/cracked it will not get closed properly.So as per that i think,you will have to check the opposite side of the door frame,where this latch gets into.On that side,there is a interlock type part.Which holds this latch.That part is operated by spring.If in-case that interlock type part or the spring,any of this is got loose then latch will get released after few minutes.--------------- But first as regular troubleshooting,you inspect the latch.Do you feel its loose or getting very easily moved,then open the door frame and check the latch.----------- For that you will required door disassembly diagram:--- Click the link,see part number 3 is door latch.-------- http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http://c.searspartsdirect.com/lis_png/PLDM/W0505176-00002.png -------------- If the latch is properly positioned and intact then ,you will need to disassemble the opposite side cabinet to check the internal part,which hold the latch.For that you will require complete disassembly:---Click this link for complete disassembly:-- http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Microwave-Parts/Model-KHMS155LSS2/0593/0123370?pathTaken=&prst=0&shdMod=KHMS155LSS2 -------------- The door latch itself or other parts holding the door latch,none of the part is costly then $10.The cost of part is under $10.---------It just require you to figure out,either is cracked /broken part or just loose misaligned part.-------- This will help.Thanks.Helpmech.
Feb 10, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
My microwave lights blinked off right after i closed the door after checking meal and re-entering time. i unplugged it and tried a different socket nothing happens no sound lights for time or inside the...
I suspect the interlock monitor switch in your microwave oven is the culprit. This is one of several switches operated by the door latches. It's designed to blow the fuse if you try to run the microwave with the door open. The switch is probably stuck, or is out of adjustment (which can happen if the oven door gets closed hard), and when you restarted the oven it blew the fuse. It is possible to adjust or replace the switch as necessary, but it might not be worth it. You should have a professional do the repair as there's a chance of microwave leakage if repairs involving the door aren't done properly. Between labor and parts, the repair cost might come close to (or even exceed) the replacement cost for a small oven.
Hope this helps, and thanks for using Fixya!
Nov 09, 2010 | Emerson MW8778 Microwave Oven
MICROWAVE WILL NOT HEAT. F9 APPEARS IN THE DISPLAY WINDOW
F9 indicates a problem with the door latch.  There is a safety switch that will not allow the microwave to operate if it detects the door is not closed properly.  Even though physically it may seem the door is shut, the safety switch is not relaying the message to the onboard computer.  You need another door latch switch.
Mar 10, 2009 | Kenmore 63663 Microwave Oven
The latch on kenmore micro #721-62622200 is broken at bottom
Mar 07, 2009 | Kenmore 62622 Microwave Oven
The closed door doesn't always hit the limit switches
I strongly suggest that you do not attempt to adjust the hinges.
The door switch mounts are either cracked or need to be adjusted.
Door switch mount trouble is usually caused by slamming the door.
This may be a little more info that you need and it's from a Sharp service manual, but the general principles apply:
1. Disconnect the power supply cord, and then remove outer case.
2. Open the door and block it open.
3. Discharge high voltage capacitor.
If the door sensing switch, secondary interlock switch and monitor switch do not operate properly due to a misadjustment, the following adjustment should be made.
4. Loosen the two (2) screws holding latch hook to the oven cavity front flange.
5. With door closed, adjust latch hook by moving it back and forth, and up and down. In and out play of the door allowed by the upper and lower position of the latch hook should be less than 0.5mm. The vertical position of the latch hook should be adjusted so that the door sensing switch
and secondary interlock switch are activated with the door closed. The horizontal position of the latch hook should be adjusted so that the plunger of the monitor switch is pressed with the door closed.
6. Secure the screws with washers firmly.
7. Check the operation of all switches. If each switch has not activated with the door closed, loosen screw and adjust the latch hook position.
After adjustment, check the following.
1. In and out play of door remains less than 0.5mm when in the latched position. First check upper position of latch hook, pushing and pulling upper portion of door toward the oven face. Then check lower portion of the latch Figure C-3. Latch Switch Adjustments hook, pushing and pulling upper portion of door toward the oven face. Both results (play in the door) should be less than 0.5mm.
2. The door sensing switch and secondary interlock switch interrupt the circuit before the door can be opened.
3. Monitor switch contacts close when door is opened.
4. Re-install outer case and check for microwave leakage around door with an approved microwave survey meter.
Dec 05, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Door-activated power switch is loose and/or has a short
Fixed this problem! The door latches were greasy and sticking in the closed position (i.e., pushed down so not latching and engaging fully when the door was closed) and this created the problems described above. Solution was to squirt some Windex into the latch holes to dissolve the grease. The switches popped back into position (must be spring-loaded) and the door closed and latched properly, allowing the oven to function properly. I swabbed out the hole with a q-tip, let it dry for 20 minutes and all is well.
Nov 17, 2008 | Whirlpool MH6150XMS Microwave Oven
Microwave Ovens Logo
112 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
