Question about D-Link DP-301U (790069251979) Print Server
D Link DP301U not working with a Canon MXF series printer
I purchased a D link DP301U USB print server for use with the Canon PIXMA MX 700 series printer I have but found out after a couple of calls to D Link that the printer was not on their compatible printer list. Any ideas for getting this to work with that particular printer? The return period has ended though my local supplier and I really don't want to go out and buy a compatible printer since I recently purchased the Canon. Basically I get an error message when I try to finish the installation of the print server. Thanks for any help towards this.
    Problem Solver:
  • 9 Answers
Dont' worry about what the d-link site says. its because they haven't tested it. i got my dp-301u to work fine with my hp1020 on 2 different workstations with the following steps.
1. install printer locally via usb and test.
2. create a second printer as per the dlink manual creating a port. don't worry about the name as we will delete it.
3. once created go into the properties of the 2nd printer and change the port to something local - anything will do to free up the port.
4. go into the properties of the printer that was created in step 1. and change the port to that of the print server.
5. test print. should work fine.
cheers!!
Posted on Sep 21, 2009
  • rnt-it Oct 03, 2009
    I got this to work with a HP 1020 which is also not on the list.
    install the printer locally and test ie via usb.
    install the printer via the print server ie giving it an IP address per the manual.
    go into the properties of the usb installation and change the ports over from the usb to the IP.
    save and do a test print.
    i got it working on serveral machines this way.
Instead of using a usb cable, I want to print wirelessly from laptop or iPad to my Canon PIXMA MP810 Printer. I have a wireless router with spare ethernet plugs at rear. What are my alternatives ? for...
You could purchase a ethernet print server which will allow you to connect your printer to the router via ethernet cable. I recommend the TPLink TL-PS110U. I use this for one of the printers in my office.
http://www.tp-link.com/en/products/prodetail.aspx?mid=0103030802&id=194
Alternatively, you could purchase the TPLink
TL-WPS510U. This is a wireless print server. It will give you some freedom if you wish to locate your printer to somewhere other than beside your router.
http://www.tp-link.com/en/products/prodetail.aspx?mid=0103030801&id=181
May 07, 2011 | Canon PIXMA MP810 All-In-One InkJet...
What is the difference between d link DPR 1020 and DP-301u
One of the main difference between this tow printer is the DPR1020 is made to work with all printer including those multi function printers , because this old DP301U was a older version of print server that don't support those new multi function printers features like scanning and fax. So if you have a multi function printer I will advice you to get the DPR1020 so all features of that printer will work behind this print server.
Aug 16, 2010 | D-Link DP 301U (DP-301U) Print Server
Issue: I have a Canon Pixma iP6220D inkjet printer and it will not connect to my computer wirelessly (my computer does not support Bluetooth). Query 1: What type of wireless technology does the printer...
1) This particular printer is available in versions that connect via Bluetooth or via Infra Red. There does not appear to be a Wifi version. 2) To get it to work via WiFi, you'll need PC with Wifi and 3) a Wifi print server like this
Amazon com TP LINK TL WPS510U 150Mbps Wireless Print Server USB 2 0...
Dec 30, 2017 | Canon PIXMA iP6220D InkJet Photo Printer
Is a canon Pixma MP160 a wireless printer? I would like to make my printer which I now use a usb cord and make the printer a wireless connection instead, and I cannot find in the manual if it is wireless...
Per the information found here, it is not a wireless printer.
If you purchase a wireless print server (similar to a wireless router), you can connect just about any USB printer to it (which would be practically the same as having a wireless printer).
Some wireless print servers that support USB have a maximum of 2 USB ports and 4 or 5 network ports.
The only problem is the additional effort it takes to configure everything to work properly.
Good Luck!
Jan 25, 2010 | Canon PIXMA MP160 All-In-One InkJet...
My Canon pixma ip4000 wont print text from word 2003 but it will print inserts from web clip art or scanner.
you are welcome.I have a canon I series printer and I purchaser the cartyridges dirt cheap online. The cartridge work perfectly and I buy them by the box full.
Here is the link to the company. Good luck and haopy new year
http://www.piloshop.ca/
Jan 03, 2010 | Canon PIXMA iP4000 InkJet Photo Printer
DP301U COMPATIBILITY
I have one of theses D-Link PD-301U. It soes NOT support most All-in-one printers like yours. According to D-Link's Web site, here are the HP Laser printers it supports (note the P1008 is NOT in the list):
LaserJet
  • 1200
  • 1500 (USB 2.0)
  • 2200
  • 2200D
  • http://support.dlink.com/faq/view.asp?prod_id=2135&question=DP-300U%20/%20DP-301P+%20/%20DP-301U%20/%20DP-311U%20/%20DP-G310%20/%20DP-G321
    Feb 09, 2009 | D-Link DP 301U (DP-301U) Print Server
    Cant print from workstations
    Try changing the driver for your HP LJP3005 on your XP machine. Use it with the HP LJ Series II driver.
    Aug 10, 2007 | D-Link DP-301U (790069251979) Print Server
    D-Link DP-301U (790069251979) Print Server Logo
    526 people viewed this question
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Michael Galve
    Michael Galve
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
