Question about Maytag Neptune MAH9700 Front Load Washer
Wat is a control lock on a may tag Neptune - Maytag Neptune MAH9700 Front Load Washer
    Problem Solver:
  • 16 Answers
Control lock prevents any functions on your control. ( this is like a child lock).
I’m happy to assist further over the phone at https://www.6ya.com/expert/donald_a8261495ff0777e2
Posted on May 16, 2014
SOURCE:
My May tag Neptune washer stopped draining. I think my son jerked the door open while water was still in it. The door shuts but the lock door light doesn't come on hence the washer want start.
door switch is damaged and will need replacing should not be able to open the door in use. machine will only work when it knows the door is locked.
Jun 04, 2018 | Neptune Washing Machines
Unlocking a may tag door washer
Fuse open ... must meter all the fuses in the back. Use an ohm meter.
Jun 02, 2016 | Maytag MAH6700AWW Neptune Front-Load...
What is the wiring and winding?
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak Maytag Neptune washer motor/motor control circuit board ...much this is very helpful, my machine is coming up with a "Lr"code which I believe .
Aug 20, 2015 | Maytag Neptune Washing Machines
May tag Neptune 5500. The door locked light never comes on and door is not locked in any cycle. How do I test the switch/lock assembley? And is there a way to trick the machine into thinking that the door...
Grounding in a 120vac environment usually will cause a big spark and pop the circuit breaker. There is a possibility the latch is like a car door latch. If it somehow gets moved to the shut or latched position when the car door is open, it will never close and latch . The latch must be returned to it's normal door open position so that when closed it will latch securely.
Your machine's latch may be blocked by something acting like the car door latch described above. It may be the switch has broken and is the "culprit".
Mar 26, 2015 | Neptune Washing Machines
May tag washer Neptune door won't open
what is your model number is then we can get started then
Oct 25, 2012 | Maytag Clothes Washer Dispenser Bezel...
May tag Neptune washer will not stay locked
it may be a bad door lock or it senses a problem. error code? tech sheet may be in console some had them below.
Sep 17, 2012 | Maytag Washing Machines
Maytag neptune tl what is code Lr
LR is the error code for Locked Rotor.
This could be an issue with the Motor Controller or Control Board.
I have not seen Drive Motor cause this issue to date.
If you want to investigate further I would suggest getting the FAV6800A/FAV9800A Service Manual.
Google this ""Neptune TL Washer FAV6800AWW""
This is a sticky for the FAV6800A/FAV9800A washer DIY support. Go to the 5th post down in the Sticky and you will find a link for the Service Manual.
If you want to go further in troubleshooting and possibly a DIY fix just open a new thread in that DIY forum with Model number and Serial number. That info is found tag behind the console right back side as you face the machine console.
Feb 24, 2011 | Maytag Neptune FAV6800AW Top Load Washer
May tag washer has error code LR at the 6 minutes left on the cycle. is it worth trying to diagnos and fix
Hi
Thanks for using FixYa. Lr means locked rotor, this issue occurs due to locked rotors, you'll need to check the rotor wiring and windings. If the wiring is good and windings are not burnt then you'll need to replace your motor and motor control board. These are sold as one unit, it is a 3 phase motor and one of the phases is bad. A little power surge can damage the boards. Please do rate the solution if the issue is resolved else post a comment for further assistance.
Thanks
Rylee
Sep 11, 2010 | Maytag Neptune MAH5500B Front Load Washer
MY MAYTAG NEPTUNE MAH4000 WILL NOT DRAIN OUT OR SPIN
Check if the "locked"or "door locked" light comes on. If it does not, you need to replace the wax motor in the door lock assembly and the machine control board, which is inside the control panel. The control board is expensive, so instead of buying the whole control board, if you're good in electronic repair and soldering, try checking ebay for the control board repair kit. Search for "MAYTAG NEPTUNE WASHER R11 Q6 REPAIR KIT". It has all instructions how to do the repair. Good luck!
Dec 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
May tag neptune says pf and i can't get it to run
PF CODE STATES ( power has been out) unplug it and try again . it will still say p f but it should program .. if not is't a bad control and will need replacing .. mm
Dec 04, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune MAH9700 Front Load Washer Logo
43 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
