Question about Smeg FAB40PS Top Freezer Refrigerator
How do I defrost my freezer part of my fridge freezer without turning it all off I have a fab30vs7
2 Suggested Answers
  • 257 Answers
SOURCE: how do I defrost freezer compartment without
There should be a hole behind the temp controls in the refrigerator top, you insert a large flat head screw driver in there and turn until you hear a click, then you will hear the fan stop, This is defrost mode. It will advance on it's own if everything is working properly. Tip: Hold the screw driver even and flat to make contact with both edges of the slot when turning.
Posted on May 19, 2011
After defrosting the freezer it will not cool
Don't panic about the hot sides of the freezer. It is quite common on all the freezer (make/model).
After defrosting, your removing the full temerature out of the system. It will take atleast 30 ~ 60 mins to come back to set temperature. This again depends on the load inside.
Jun 06, 2010 | Kenmore 13.7 cu. ft. / 388 liter Upright...
How do i switch off freezer part of neff american fridge freezer?
turn off the thermostat on the freezer and the refrigerator and that should shut it all down.
Apr 03, 2009 | Refrigerators
Frozen vents from freezer to fridge
you most likely have a defrost problem.or a clogged drain.you need to check your defrost heater defrost timer and thermostat.if ice is formed over drain then you can unclog drain with hot water.you will see when it is unclogged,water will run down drain without running over into bottom of freezer.
Mar 09, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Whirlpool ARC7470AL FRIDGE FREEZER
you have one of three problems and only one problem
the defrost timer is bad
the defrost heater is bad
the defrost thermastat is bad
only one of the above is the problem but no way to know without checking each part with and ohm meter
May 07, 2008 | Refrigerators
Defrosting a fridge freezer
No. All the cooling comes from the freezer unless you have one of the few split systems. A hairdryer will help but the fridge will warm up some.
Apr 15, 2008 | Freezers
Fridge & freezer no longer cold
if you only removed the ice you can see without removing the back panel then you need more defrost time yes. but the frost will come back, something in the defrost system has failed. so the answer is yes to both questions off for longer and something more serious too.
Apr 06, 2008 | Freezers
Fridge freezer
fully defrost it 48 hrs with the doors open and that can often cure it.
Feb 11, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Smeg FAB40PS Top Freezer Refrigerator Logo
19 people viewed this question
Top Smeg Refrigerators Experts
John Tripp
John Tripp
Michael Galve
Michael Galve
ashburton
Are you a Smeg Refrigerator Expert? Answer questions, earn points and help others
