Question about LG D5966 Gas Dryer
How to reset thermostat on dlg5966w - LG D5966 Gas Dryer
Thermostat stuck on hold won't reset.
Pull the thermostat off the wall & place back into pins. Should reset.
Nov 27, 2013 | Thermostats White Rodgers 1F80-261...
Dryer ignitor not glowing
The problem may not be a failed igniter but failure of power to get to the igniter. However, the replacement igniter could be defective
Jan 05, 2013 | LG DLG5966W Gas Dryers
Lg dryer dlg5966w wont heat, smells like gas in the drum
I have same problem. I have tried everything. Even new control board. It only intermitantly does this. When it fails to light it pumps raw gas. Only thing to try next is new ignitor.....
Jul 17, 2012 | LG D5966 Gas Dryer
Lg dlg5966w heat element heats up and gas firing will start for 2-5 seconds and stops.
FIrst thing I would do is to make sure the vents are cleared and have the most direct route out with minimal 90 degree bends.
Apr 24, 2012 | Dryers
LG DYER MODEL DLG5966W RUNS BUT DOES NOT HEAT, TOOK THE IGNITER IN TO PARTS STORE THEY CHECKED THE CONDUCTIVITY WITH A METER AND SAID THE IGNITER IS FINE? WHAT ELSE COULD IT BE?
Continuity is great but did they perform an ampere test on the ignitor while the ignitor was hooked up inside the unit? An ignitor typically draws between 3 and 3.3 amperes any less then this would constitute a weak ignitor and the ignitor should be replaced if it is weak because it takes much longer to ignite the gas inside a dryer. An ignitor would always show conductivity except if the element were broken. So to start with wrong test was performed. Secondly there are also run thermistors and hi and low limit thermistors that act as relays that can also be checked in dryers by performing continuity tests on these thermistors click this link http://c.searspartsdirect.com/lis_png/PLDM/K0810208-00003.png this is one of the schematics to your dryer k 550 is a thermistor and k 560 is a thermostat both should be tested as mentioned above. M 110 is the gas vavle which on other units the coil is replaceable but is only sold along with the valve on an LG which also has to be tested that power is going to the solenoid on top of the valve and that it is going to the ignitor. If you have any further questions message me back. I await your reply as to any further questions as well as your finds as well. Thanks again
Rick
Sep 20, 2011 | LG D5966 Gas Dryer
Dlg5966W dryer sensor dry does not work. Clothes do not completely dry.
e42b89b.jpgcheck the ohms value of the thermister using the specs provided in a manual
Mar 11, 2010 | Dryers
Gas Dryer DLG5966W pilot light
The power should turn on a electric igniter once the gas has reached the heat chamber and regulator. If not let me know soon the model number of your LG dryer so I can help you better, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com/
Apr 09, 2009 | LG Dryers
DLG5966W LP Conversion
Turn the change screw down until the brass nut bottoms out on the valve body. It is glued in place exactly where the change screw needs to stop when converting to LP. Hope this helps.
Jan 08, 2009 | LG DLG5988 Stainless Steel Gas Dryer
Lp conversion
You guys like things that go boom. My advice is to get a certified gas tech. To change the orfice to LP you have to take apart the unit from the front.
Sgt 48
Jan 30, 2008 | LG DLG5988 Stainless Steel Gas Dryer
LG D5966 Gas Dryer Logo
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
