Question about Canon MG5250 Printer
How to reset counter - Canon MG5250 Printer
How to reset Toshiba Studio 256se Total Counter?
Clearing counter
The counter indicating "current number of prints and driving time" used for the PM display function is
reset by entering "0" in it or clearing it in the PM support mode.
Notes:
Even if "0" is entered in the PM management setting value of the setting mode (08), the
corresponding counter for the PM display is not reset. Be sure to clear the counter in the PM
support mode when the maintenance is finished.
The reset condition of each counter is as follows:
• 08-6194: Current value of PM counter [process unit (K)]
• 08-6195: Current value of PM time counter [process unit (K)]
When the current value of "CLEANER/DRUM" on the main screen or "DRUM" on the sub-screen in
the PM support mode is cleared, the counter is reset.
• 08-5568: Current value of PM time counter [developer material (K)]
• 08-5569: Current value of PM time counter [developer material (K)]
When the current value of "DEVELOPER" on the main screen or "DEVELOPER" on the sub-screen
in the PM support mode is cleared, the counter is reset.
• 08-5576: Current value of PM counter [parts other than the PM parts of the process unit]
• 08-5577: Current value of PM time counter [parts other than the PM parts of the process unit]
• 08-6225: Number of output pages (Thick paper 1)
• 08-6226: Number of output pages (Thick paper 2)
• 08-6227: Number of output pages (Thick paper 3)
• 08-6228: Number of output pages (OHP film)
• 08-6244: Counter for tab paper
• 08-6247: Counter for envelope
When the current value of "FUSER" on the main screen or "FUSER ROLLER" on the sub screen in
Notes:
The following counters are cleared by executing the EPU replacement mode.
08-5568: Current value of PM counter [developer material (K)]
Jun 14, 2016 | Toshiba Office Equipment & Supplies
Ricoh CL2000, How do I enter service mode, and reset (CMY page counters)?
What are you trying to do? Some counters do not reset. Only those for consumable items can be reset.
Jan 17, 2015 | Ricoh Aficio Office Equipment & Supplies
Reset counter taskalfa 2550ci
there are many counters that count "page counts" for keeping up with PM, roller life, etc... if you are referring to the total counters they cannot be reset.
Nov 28, 2013 | Kyocera TASKalfa 180 Copier
Lexmark 463de maintenance reset
To reset the maintenance page counter to zero:
1. Touch Reset Maintenance Counter from the Configuration Menu.
2. Reset Maintenance Counter appears in the header.
3. Touch 100K Kit or 600K Kit. Yes and No appear in a menu.
4. To cancel the reset operation, touch Back or No. All other button presses are ignored.
5. To initiate the reset operation, touch Yes.
Dec 03, 2012 | Lexmark "x463de multifunction laser...
How do one enter to Service Mode level 3 of Canon irc3200
That level 3 mode is only for Canon engineers. What counter are you looking to reset? The counters for most maintenance items are reset in service mode level 1. The total counter for the machine cannot be reset without replacing the main controller pcb & the counter pcb.
Jul 25, 2012 | Office Equipment & Supplies
Reset counter sharp ar-5631
what counter you like to reset ,we have error counter .jam counter,paper feed counter ,spf counter,drum counter
Nov 03, 2011 | Sharp AR-5316 Advanced Digital Imager...
How to reset counter on canon dr 7580
You need to run Qumatool to reset the counter
S. Mohan
Oct 14, 2011 | Canon DR-7580
I just fixed a me super but the frame counter doesn t reset when the 36st is reached or when I attempt to open the camera. HOW DO I RESET IT without openning it?
By opening, do you mean the back cover or the top cover?
after rewinding the film opening the back door will reset the counter. if it does not reset, try firing the shutter with the back door opened a few times. this counter is mostly plastic.
with the back door opened try taping the top cover over the counter to free the counter gear.
if it still wont reset the top cover will have to be removed and the counter repaired.
there are no new parts available for this model Pentax so a good used counter could be expensive.
if you take the top cover off, usually the pointer plate on the right side of the counter is rubbing on the counter preventing it from resetting.
Oct 15, 2009 | Pentax ME Super 35mm SLR Camera
T11 Counter Reset
SSCLG can not counter reset the new T Series printers... please check
http://inksystem.vacqum.com
There is an adjustment program for T11 you can download..
follow the readme file and you are good to go
Sep 11, 2009 | Epson Office Equipment & Supplies
How to reset drum counter for fuji xerox 203A
if the Drum LED is still lit after replacing the drum unit, the Drum counter may not be reset.
Reset the Drum counter as follows:
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
Aug 28, 2008 | Office Equipment & Supplies
Canon MG5250 Printer Logo
54 people viewed this question
old marine
old marine
