Question about Maytag EPICz 3.7 Cu. Ft.
What does the drain cleanout look like on a maytag epic z
4 Suggested Answers
SOURCE: Maytag Epic not draining.
i had the same problem a couple months ago---i couldnt figure out why it wasnt draining. It kept saying "F-21"...well i called a "expert" and all it was was the lent trap inside needed cleaning....which isnt in the manual.....it is located in the back---truthfully im not sure where.....you have to remove a bolt and some screws and pull off the back and then clean it......hopefully some of this helped you...
Posted on Feb 19, 2009
SOURCE: MAYTAG EPIC FRONTLOAD WASHER NOT DRAINING
The filter is in the front on this one. Under the door, there is another panel. There are 3 screws that a 1/4" nut driver takes off pretty easily. Get a bowl and bucket. There is a white screw cap that you should easily see. Open it slowly with the bowl underneath. Close it again when the bowl is filled and dump the bowl into the bucket. Repeat until no more water comes out then unscrew it completely. Clean out the trap and replace. There is a stop that prevents you from overtightening. See if that works. A six dollar nutdriver is easier and cheaper than any repairman.
Posted on Jul 20, 2009
heatman101
  • 43501 Answers
SOURCE: Maytag Epic Z won't Drain after rinse cycle.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Aug 13, 2011
heatman101
Aug 13, 2011 | Maytag EPIC MFW9700S Front Load Washer
Mani have an error coming on my epic maytag washer it flashes the letter F and then the letters DL please help
Hello the error code F with a DL is usually a clogged or kink in the drain line.
Unplug washer and remove drain hose and clean it out.
Check area where Line connects to washer closley for any debris and remove it.
May 08, 2011 | Maytag EPIC MFW9700S Front Load Washer
Filter clogged
If this is a Maytag Epic, you are referring to the drain pump reservoir. The following link explains how to access and clean the drain pump:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
Make sure you also check the hose that runs from the bottom of the wash tub to the inlet side of the pump. Small articles of clothing can become lodged here. If you have questions, please post back and let me know. I hope this helps you.
NOTE: If the link does not work for you, copy and paste to your web browser. Maytag Epic is manufactured by Whirlpool, so these instructions do apply.
May 02, 2010 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic Z with error codes F20 and F24
my epic will start & wash & then gets F 20 & won't drain until I hit start again
Oct 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washer flashing 02 F. Maytag epic washer won't spin -flashing 02 F about 15 minutes into the cycle. We just had new electrical components put into it.
You need to use the HE detergent. I believe that is a drain problem. By using the regular detergent that causes more suds and in turn clogs your drain
Jul 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag EPICz 3.7 Cu. Ft. Logo
24 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
