Question about Briggs & Stratton Garden
24 hp engine. one bent push rod, second rod missing
  • same463 May 11, 2010
    Are you wanting to replace the rods? Need B & S model number off engine.
  • 21 Answers
Just found the same problem on my father in laws mower (24 hp briggs) I took the engine off of the mower, drained oil, turned on its side and removed lower case. There was the missing pushrod wraped around the camshaft gear. no clue on how in the hell it did that! It also ended up breaking the govenor (quick look) will look for more damage tomorrow.
Posted on Jul 27, 2009
I own a 1968 Imperial 440 V8. The intake valve push rod of the #1 cylinder bent and was causing knocking noise. I replaced it and the motor ran fine. The #1 cylinder started missing. Again it was a bent...
bent push rods come from improper movement of the rocker and valve
This can be from an incorrect length push rod-- some v8 engines run different lengths for inlet and exhaust
from rocker arm jamming on the shaft or rocker ball
hydraulic cam follower pumping up and jamming the valve spring to a solid block
bent valve stem above the valve guide
valve spring Colette moved or misplaced incorrect rocker for that valve-- some engines run different length rockers for inlet and exhaust
what to do-- if this engine was running all right for some time then the rocker can be omitted. if the problem has been occurring since the cold weather the the oil may be too thick and not allowing the follower to leak down properly
check the follower or replace it , change to a lighter viscosity oil for the duration of the cold weather
unless you have had a recent head change or other mechanical work done the problem will be in those areas.
Feb 21, 2015 | Cars & Trucks
Briggs & Stratton Model 287707 14.5 HP has bent valve push rod and neither valve works
I am not familiar with this small engine but probably is broken camshaft or timing chain or gear.
Apr 13, 2014 | Measuring Tools & Sensors
Only getting oil in one side of valves ? 24 hp briggs, twin
clean all the passages i usually drain the oil and replace with diesel fuel run for 30 seconds drain and replace with oil sae30
Aug 31, 2012 | Briggs & Stratton Briggs Stratton Intek V...
24 hp engine. replaced head clinder now won't start
check the valve adjustment they sound to tight and the valves are not closing
Aug 23, 2012 | Briggs & Stratton Garden
Craftsman 16 HP Electric start 41" mower - on a overhead valve briggs and stratton two stroke engine the hollow push rod bent. We pulled the head and everything seemed in working order. The replacement...
On any pushrod engine you have to make sure that the timing is correct or nearly correct when first firing it up, if you had the cam in the wrong position the pushrod had no place to go when the cam lobe came around=bend push rod.
Sep 24, 2010 | Garden
My 24hp Briggs and Stratton ohv engine has bent push rods on one side. The top valve can be pushed in but the bottom one will not push in. Is the valve stuck in the open position? If so how can it be...
unable to answer if valve opened or not but does sound like ur bottom valve is bent or piston made contact and bent it to fix need to remove head and replace valve also need to inspect piston face is not damaged from possible contact
Apr 12, 2010 | Craftsman 24 Hp 48" Deck Yard Tractor
I have crafsman 48" riding mower with a 24 hp intek motor
Bent push rods are a function of the valve guide coming loose in the head. The valve binds and you end up with a bent pushrod. Fix: Replace head. $94.00
Jul 13, 2009 | Briggs & Stratton Briggs Stratton Intek V...
24 hp engine. one bent push rod, second rod missing lost some power, no other problems
This happened to me,the engine sat for some time and the valves were varnished with stale fuel,they stuck in the guides.This bent the push rod and it was only running on one cylinder.The missing push rod worked its way into the crankcase through an oil passage . I took the engine sump of and found the push-rod. I cleaned removed the head,cleaned the valves and guides replaced push rods and gasket and it ran fine after that.I use fuel stabilizer now,it keeps the varnish from forming.
Jun 23, 2009 | Briggs & Stratton Garden
My Biggs and stratton446777 rockers dont move as it spins over
you my have a broken rod pull spark plugs out and see if pistons are moving,if so check for bent push rods,if push rods aren't bent then you may have bad cam
Apr 28, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
749 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
